Actually i have got risinghf lorawan gateway (Type: RHF2S008). i want to connect it to the “the things network”. My gateway is in Ahmadabad,Gujarat,India and working on 856-867 MHZ.
Now to send data to the TTN network i need tot have package forwarding file for Indian frequency.in my risinghf gateway i haven’t found that one.
i am trying to connect RHFS008 ( risinghf) gateway. i have already get the status of “active (running)”.
but there is problem in starting concentrator .
here is my logs:
Already up-to-date.
HEAD is now at a9d36fc Merge pull request #674 from Airji3d/patch-1
/opt/ttn-gateway/bin
[TTN Gateway]: Use Gateway EUI B827EBFFFE2B285C based on eth0
*** Poly Packet Forwarder for Lora Gateway ***
Version: 2.1.0
*** Lora concentrator HAL library version info ***
Version: 3.1.0; Options: native;
INFO: Little endian host
INFO: found global configuration file global_conf.json, parsing it
INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1 301 parameters
INFO: lorawan_public 1, clksrc 1
INFO: Configuring TX LUT with 16 indexes
INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -16 6.000000, tx enabled 1
INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -16 6.000000, tx enabled 0
INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
INFO: global_conf.json does contain a JSON object named gateway_conf, parsing ga teway parameters
INFO: Found 1 servers in array.
INFO: Server 0 configured to “router.eu.thethings.network”, with port up “1700” and port down “1700”
INFO: packets received with a valid CRC will be forwarded
INFO: packets received with a CRC error will NOT be forwarded
INFO: packets received with no CRC will NOT be forwarded
INFO: GPS is disabled
INFO: antenna_gain 0 dBi
INFO: Upstream data is enabled
INFO: Downstream data is enabled
INFO: Ghoststream data is disabled
INFO: Radiostream data is enabled
INFO: Statusstream data is enabled
INFO: Beacon is disabled
INFO: Monitor is disabled
INFO: found local configuration file local_conf.json, parsing it
INFO: redefined parameters will overwrite global parameters
INFO: local_conf.json does not contain a JSON object named SX1301_conf
INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gat eway parameters
INFO: gateway MAC address is configured to B827EBFFFE2B285C
INFO: Server configured to “52.169.76.203”, with port up “1700” and port down “1 700”
INFO: Successfully contacted server 52.169.76.203
INFO: [main] Starting the concentrator
ERROR: [main] failed to start the concentrator
help me out!!!
please FORMAT your post
root@ttn-gateway:/opt/ttn-gateway/bin# ./start.sh
/opt/ttn-gateway/gateway-remote-config /opt/ttn-gateway/bin
Already up-to-date.
HEAD is now at 304f975 Merge pull request #682 from sascha-hemi/patch-1
Version: 2.1.0
INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1
INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0
INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: Server configured to “52.169.76.203”, with port up “1700” and port down “1700”
SPI enabled? For RPi3 set the core frequency to 250?
Yes…SPI is enabled and core frequency is also set to 250 as well. but it is not connected yet.!
