I looked at the module you are using. The SX1276MB1MAS has two RF paths. A 868MHz one and a 433MHz one. So you would need to use the ANT_LF antenna connector for your application to work at 433MHz.
It looks like you also have to drive the RXTX_EXT pin in order to switch from receive to transmit. But maybe you are already doing all that…?
Perhaps what people find the hardest to understand is the huge difference there is between the range you get under line of sight conditions and in and around buildings, it can be as much as 1500:1.
In my experience the common reasons for very poor range are;
Damadged modules that have been used with no antenna connected.
Faulty antennas
No antenna connected, or connected to the wrong port.
Modules that include antenna switching not being configured correctly
It’s really wonderful! i can’t imagine 700KM! Thanks for this useful links, i’ll study this articles and focus on for points you mentioned. I will keep in touch with you.
The way I read it is as follows: when pin 4 (CTRL) of U2 is low the common RF input/output (pin 5 RFC) is connected to pin 3 (RF2). So when the RXTX pin is not driven it is permanently tied to ground via a resistor on the board. Thereby setting both RF switches U2 and U5 in receive mode.
If you want to transmit you will have to set RXTX high, transmit a LoRa message and switch back to receive.
In case you are not operating this pin it might explain your poor range. A simple test could be to tie the pin on the board that you are using as transmitter to +3.3V and on the receiver to GND.
It’s not possible to supply a 3.3v via a wire but there is nothing about voltage limiting on control pin(HIGH) in switch datasheet and so i used arduino 5v to set control pin high for transmitter and down for receiver.
so now, in 433MHz and 7dbm i get RSSI: -45 and SNR: 7-9 in a room(2m distance)! difference is very much, is this result acceptable or not?
Looks like your receive values are about 30dBm (1000x) stronger than before. I can’t comment too much on the absolute values you are reporting, but compared to your earlier readings this looks much better to me. If both your modules where in receive mode, whereas one of them was transmitting, that will explain why your range was that bad.
I’m grateful for your help sir. i’ll keep testing in a higher and LOS environment. maybe a better antenna like 4.5dbi gain give better results. Thanks again
Hi, You cannot meassure the RSSI in a short distance with a normal antenna and receiver. Because near the antenna there is not a normal frequency domain propagation, the magnetic field is bigger than the electrical field. This is known as near field.
The limit of near field in air can be calculed as 3·lambda (wavelength), that for 466 MHz is: 3·3·10 exp8 / 466·10 exp6 = 1.93 meters
Below this distance, the electrical field you receive is lower than the magnetic field, so a regular device cannot measure the RSSI properly.
Hello , I am using SX1276RF1JAS evaluation board , am facing now the same problem you had ,that rssi is very bad ,it gives -95 on 4 meters range while i got rssi -21 when using rfm96 module which is also sx1276 based , I make the control on the Rxtx pin and still having the same problem , when i test the connection between the RFo pin and the RFC ,no connection. What i have to do to make the module work as normal .
Hello , I am using SX1276RF1JAS evaluation board , am facing now problem that rssi is very bad ,it gives -95 on 4 meters range while i got rssi -21 when using rfm96 module which is also sx1276 based without amplifier, that is the strange . , I make the control on the Rxtx pin as you mentioned by applying 3.3 v and still having the same problem , when i test the connection between the RFo pin and the RFC ,no connection. What i have to do to make the module work as normal .and how to control between Tx and Rx ,maye be i am doing somthing wrong . Thanks in Advance.
Is your board for the same frequency band (ie 868 or 915) as you are attempting to operate it on? If you have the wrong board for your intended frequency the the chip itself will still work at the frequency your software sets, but all the RF networks surrounding it will be mistuned leading to poor signal strength.
Seizing the opportunity, I would to make a question to you guy. I have 2 SX1278 ( https://www.ebay.com/i/153522718712?chn=ps ) modules each one connected in a ESP32. I having poor signal but I have used GSM antennas. I like to know if they have to work without antenna if I put them near each one? (2 meters distance) I guess my antennas aren’t compatibles. But analog to wifi connections access point and client can work without antenna in short distances.
