ClementLG
(Clement Lg)
January 13, 2021, 2:19pm
1
I am currently developing an application that use the netblocks LoRa board :
https://www.netblocks.eu/
I have follow these steps :
https://www.netblocks.eu/firmware/connect-xrange-lora-module-things-network-ttn/
but at the end when I restart the application, I canât see the dummy datas on my console.
Have someone already worked with this board ?
Actually I am just beginning LoRa and I must use this board, does someone know if there is a way to connect the board to TTN in a other way ?
feel free to answer, i am just a beginner !
descartes
(Nick McCloud)
January 13, 2021, 3:22pm
2
Hi! Do you have a gateway or a gateway close to you that you can check on TTNMapper.org to see if it is known to be active?
ClementLG
(Clement Lg)
January 13, 2021, 7:03pm
3
Hi, I have two antennas in less than 5 kilometer around me, do you think it is ok ?
descartes
(Nick McCloud)
January 13, 2021, 7:35pm
4
Did you check if they are active on TTNMapper like I suggested?
Even if active, your antenna, their position and whatâs between you and them will make a difference.
ClementLG
(Clement Lg)
January 13, 2021, 8:17pm
5
Yes she is active like this one !
cslorabox
(Cslorabox)
January 13, 2021, 8:26pm
6
Hopefully you mean âgatewaysâ and not simply antennas.
5km would be workable in idea situations, but there are many practical situations where it would not work. Generally for node debugging you want your own gateway somewhere fairly nearby, though not right next to the node in order to prevent overload.
ClementLG
(Clement Lg)
January 13, 2021, 9:22pm
7
Yes sorry it is a gateway
I think the next step of my project is to build my own gateway.
What is the best for beginner ? do you know ?
cslorabox
(Cslorabox)
January 13, 2021, 9:40pm
8
There are countless existing threads here, we donât need to re-visit that again
