Definitely not just an idea. It’s a fully specced design, down to the individual parts (which we have available). A big difference is we’ve also done the calcs to actually prove stability at wind loads - advantage of having mechanical engineers.
We’re assembling a sample in our factory and will post photos soon. We’re leave it running.
One other nice thing is we actually can post statistics from the solar charger (which has modbus) over - what else - LoRaWAN. Yes, the rig itself is a node! I think it’s pretty cool and will share more soon, more surprises on the way.
I’ve got a code for a discount of 5% for the Dragino LG308 LoRaWAN Gateway on Tindie. So if you are going to buy one, feel free to use them.
Code: 338FE091
Of course I have tested the LG308 by myself and I think it has the best price-performance ratio for private makers.
Its easy to use, can be easily configured to TTN (or a private LoRaWAN Server) and is ready to use in <15min.
I also compared it to other gateways (Laird, Ursalink and Multitech):
The range and RSSI was quite as good as the Multitech (~800$) and for me better than the Laird and
Ursalink.
For the sake of completeness: Yes, it is an affiliate code. So you get something, I get something. Win Win.
We have decided to include a special offer for hackers and makers:
Our Offer for Hackers and Makers
Are you part of a hackerspace, makerspace or some other community group and want to build a gateway for a non-commercial project that somehow benefits the public (e.g. a public gateway for The Things Network)? We want to support these use cases! Drop us an e-mail at shop@coredump.ch explaining your project to get the backplane 33% cheaper!
LoRa Carrier grade Gateways - Lorrier LR2 for sale! We start great LR2 Gateways discount for the TTN comunity members.
LORRIER LR2 is an improved carrier grade gateway for building reliable professional IoT network based on LoRaWAN™ protocol. This is a fully outdoor device intended to establish a wide coverage IoT network built by telecommunications operators as well as a local network built by individuals or IoT connectivity service providers. Datasheet
The price for the members is 425Eur / brand new LR2 gateway. The last few pieces left.
Buyers can apply by email tucek.martin81@gmail.com
Your beloved station bike has certainly been stolen from you. Bike wasn’t expensive, but it was yours. With the SolarVeloTracker, you can find your bike again.
This is a small device based on Murata’s CMWX1ZZABZ-078 that uses two IR sensors to detect passage of people across a threshold, like a doorway. The device is capable of detecting the direction of threshold crossing, so keeps track of ingress and egress events seperately. Applications include monitoring human traffic, keeping track of room occupancy, intrusion detection, etc.
The device runs on a 950 mAH coin cell battery or two AAA batteries and lasts up to three years of continuous usage at 10 minute LoRaWAN reporting interval. Typical continuous power usage at this reporting rate is 35 uA.
Edit: In the latest design the IR sensors run at a continuous 50 Hz and draw ~5 uA each. They are set to interrupt the MCU upon threshold crossing, so the system stays in its low power state until interrupted by the sensors. Right now the LoRaWAN Tx is set on a fixed timing interval, but one could switch this to a combination low frequency update, like once per hour or day and a Tx-on-detect kind of scheme for applications where few transits are expected. Lots of possibilities, but the current draw is dominated by the LoRaWAN Tx.
The device is housed in a 2.5 x 2.5 x 1 inch Bud Industries container and is simply mounted via VHB foam tape.
In our initial testing the device has achieved > 95% accuracy.
The device began as a Hackaday.ioproject and we are now commercializing the technology for sale. We have redesigned the prototypes for efficient manufacture and to minimize build costs and have started production and beta testing for prospective customers. Pricing will be set after all production costs are determined but we expect the initial price of each device will be around $60; less at higher volumes.
I’m glad to share with you the release of RoLaGuard: a free and open source LoRaWAN Operations, Cybersecurity & Compliance Management Platform. Despite being the first release, it has a lot of functionality that can help to manage LoRaWAN networks in an easy and automated way, just plug and play to get real time monitoring, diagnostics and solution information to smoothly run your LoRaWAN networks. Platform Main Capabilities:
Asset Inventory:
-Automatic Inventory of devices and gateways
-Tracking
-Classification by importance and labeling
-Geolocalized Map Visualization
-Drill-Down Analytics
Network Overview:
-Status of gateways and devices
-Lost messages, retransmissions, failed Joins
-Frequency between messages
-Devices by gateway
-Signal Strength and Noise graphics
Automation & Alerts:
-Continuous Monitoring and Alerting with Automatic Risk and Importance Classification
-Event Configuration & Management
-Security and Compliance
-Best Practice, Operation and Security Checks
For the moment RoLaGuard supports The Thing Networks and ChirpStack, but we are working to add more Network Servers. Also, you can develop your own data source connector to add support to your favorite Network Server. Please, take a look, share your feedback and contribute.
Hi! Yes, a big part of LAF’s code was used for the engine of this tool. I know that some rules may not apply to TTN, but this tool wasn’t meant only for TTN and this is why we implemented policies so that the user can enable/disable certain checks. Regarding the 4th item, the tool doesn’t flag retransmissions as duplicated since it does other checks first.
The last few months Skylab has been quietly working on a new small prototyping board based on the Semtech LoRa® LR1110 LoRa Edge™ Asset Management Platform. This ultra-low-power prototyping board equipped with LoRa LoRaWAN, GPS / GNSS, WiFi geolocation, for precise in and outdoor positioning, capable of measuring Temperature, Humidity, Barometric pressure, Acceleration and Magnetic field. This LoRa developer board is Arduino IDE compatible and WEMOS pin-compatible which gives extra possibilities. Our team has been working very hard to optimize the last design details and we are happy to announce that we start the first production.
If you have any questions about our new product please feel free to contact us or visit the webpage:
LR1110 LoRa developer board UPDATE. Today we started the production of the first (small) batch of the New LR1110 board. With this development we are one step closer to full-scale production. The first batch of the new LR1110 based developer board was very promising and the PCB is nearly perfect but here at skylab, we strive for perfection. which is why will test and inspect these first boards extremely thoroughly to find and improve every imperfection. we are very excited to start working with the brand new LR1110.
