RN2483 end-device does not work
Hi there,
Some days ago I was testing some RN2483-based nodes and everything was working fine: end-devices transmitted messages and everything was shown in both consoles (application and gateway). However, although I did not even change the sketch or the hardware, I couldn’t see the traffic in the consoles anymore.
I’ve been trying to find out what could have happened, I can’t even see the join request of the end-device. I have tried registering a new device in the application (but appears as never seen) and replacing the LoRaWAN module, but still doesn’t work. I copy here the log file from the gateway:
ttn@ttn-gateway:~ $ sudo tail -f /var/log/syslog
Oct  2 07:48:49 ttn-gateway ttn-gateway[364]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Oct  2 07:48:49 ttn-gateway ttn-gateway[364]: # RF packets sent to concentrator: 0 (0 bytes)
Oct  2 07:48:49 ttn-gateway ttn-gateway[364]: # TX errors: 0
Oct  2 07:48:49 ttn-gateway ttn-gateway[364]: ### [GPS] ###
Oct  2 07:48:49 ttn-gateway ttn-gateway[364]: # Invalid gps time reference (age: 1506930513 sec)
Oct  2 07:48:49 ttn-gateway ttn-gateway[364]: # Manual GPS coordinates: latitude 38.97740, longitude -1.85670, altitude 40 m
Oct  2 07:48:49 ttn-gateway ttn-gateway[364]: ##### END #####
Oct  2 07:48:49 ttn-gateway ttn-gateway[364]: INFO: [up] PUSH_ACK for server router.eu.thethings.network received in 66 ms
Oct  2 07:48:49 ttn-gateway ttn-gateway[364]: INFO: [down] for server router.eu.thethings.network PULL_ACK received in 129 ms
Oct  2 07:48:53 ttn-gateway kernel: [1538935.370436] w1_master_driver w1_bus_master1: Family 0 for 00.27de00000000.24 is not registered.
Oct  2 07:49:01 ttn-gateway CRON[13689]: (root) CMD (/etc/myDevices/crontab.sh)
Oct  2 07:49:01 ttn-gateway CRON[13685]: (CRON) info (No MTA installed, discarding output)
Oct  2 07:49:24 ttn-gateway rsyslogd-2007: action 'action 19' suspended, next retry is Mon Oct  2 07:50:54 2017 [try http://www.rsyslog.com/e/2007 ]
Oct  2 07:49:40 ttn-gateway kernel: [1538982.761458] w1_master_driver w1_bus_master1: Family 0 for 00.a7de00000000.a8 is not registered.
Oct  2 07:50:01 ttn-gateway CRON[13824]: (root) CMD (/etc/myDevices/crontab.sh)
Oct  2 07:50:02 ttn-gateway CRON[13820]: (CRON) info (No MTA installed, discarding output)
Oct  2 07:50:03 ttn-gateway dhcpcd[582]: eth0: fe80::16cc:20ff:fe0c:840a router available
Oct  2 07:50:30 ttn-gateway kernel: [1539032.171523] w1_master_driver w1_bus_master1: Family 0 for 00.67de00000000.62 is not registered.
Oct  2 07:50:54 ttn-gateway rsyslogd-2007: action 'action 19' suspended, next retry is Mon Oct  2 07:52:24 2017 [try http://www.rsyslog.com/e/2007 ]
Oct  2 07:51:01 ttn-gateway CRON[13982]: (root) CMD (/etc/myDevices/crontab.sh)
Oct  2 07:51:01 ttn-gateway CRON[13978]: (CRON) info (No MTA installed, discarding output)
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: INFO: [down] for server router.eu.thethings.network PULL_ACK received in 61 ms
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: ##### 2017-10-02 07:49:03 GMT #####
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: ### [UPSTREAM] ###
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # RF packets received by concentrator: 0
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # RF packets forwarded: 0 (0 bytes)
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # PUSH_DATA datagrams sent: 1 (233 bytes)
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # PUSH_DATA acknowledged: 100.00%
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: ### [DOWNSTREAM] ###
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # PULL_DATA sent: 3 (100.00% acknowledged)
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # RF packets sent to concentrator: 0 (0 bytes)
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # TX errors: 0
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: ### [GPS] ###
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # Invalid gps time reference (age: 1506930543 sec)
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # Manual GPS coordinates: latitude 38.97740, longitude -1.85670, altitude 40 m
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: ##### END #####
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: INFO: [up] PUSH_ACK for server router.eu.thethings.network received in 66 ms
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: ##### 2017-10-02 07:49:33 GMT #####
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # Invalid gps time reference (age: 1506930573 sec)
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: INFO: [down] for server router.eu.thethings.network PULL_ACK received in 132 ms
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: INFO: [down] for server router.eu.thethings.network PULL_ACK received in 62 ms
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: ##### 2017-10-02 07:50:03 GMT #####
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # Invalid gps time reference (age: 1506930603 sec)
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: INFO: [down] for server router.eu.thethings.network PULL_ACK received in 94 ms
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: ##### 2017-10-02 07:50:33 GMT #####
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # RF packets received by concentrator: 2
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # PUSH_DATA acknowledged: 0.00%
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # Invalid gps time reference (age: 1506930633 sec)
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: INFO: [down] for server router.eu.thethings.network PULL_ACK received in 86 ms
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: ##### 2017-10-02 07:51:03 GMT #####
Oct  2 07:51:03 ttn-gateway ttn-gateway[364]: # PUSH_DATA datagrams sent: 1 (231 bytes)
Oct  2 07:51:07 ttn-gateway dhcpcd[582]: eth0: fe80::16cc:20ff:fe0c:840a router available
Oct  2 07:51:11 ttn-gateway dhcpcd[582]: eth0: fe80::16cc:20ff:fe0c:840a router available
Oct  2 07:51:15 ttn-gateway dhcpcd[582]: eth0: fe80::16cc:20ff:fe0c:840a router available
Oct  2 07:51:29 ttn-gateway kernel: [1539091.510780] w1_master_driver w1_bus_master1: Family 0 for 00.e7de00000000.ee is not registered.
Oct  2 07:52:01 ttn-gateway CRON[14152]: (root) CMD (/etc/myDevices/crontab.sh)
Oct  2 07:52:01 ttn-gateway CRON[14148]: (CRON) info (No MTA installed, discarding output)
I’m using an Arduino board with the RN2483 (LoRaWAN_08_join_otaa_send_unconfirmed), and the gateway is a Raspberry Pi 2B with the iC880A concentrator.
I printed the output of the Arduino sketch and it seems that there’s an error when the module attempts to set the EUI (LoRaWAN.setDeviceEUI(DEVICE_EUI))
Did something similar happen to anyone else? I appreciate any kind of help :grin:
Regards,
Celia
did you find it ?
Hi @BoRRoZ,
I didn’t find it yet, is there an additional way to check that the gateway is working properly?
I changed the location of the gateway some weeks ago, but I used the network with the new location and I found no problem until some days ago. In any case, I’ll notify any advance.
Thank you for your interest :blush:
Hi Celia,
I’m sure you checked and double checked … just some ideas
  • can you reach the gateway with another node
  • start problems gateway (reset a few times)
  • powersupply gateway
  • did you try resetting the rn2483 to factory default
  • resetting the frame counter in console
  • obvious… battery, measure voltage on RN2483 when switched on
  • creating a new application with the ‘old’ node
  • creating a new node with the old application
Hi @BoRRoZ ,
I’ve checked these options, but I haven’t tried resetting several times the gateway or testing the power supply… I’ll test that and as soon as I find the problem I’ll post it :grin:
Regards,
Celia
did you find it?
Hi, I finally found the problem!
My gateway is deployed outdoors, so I though that the antenna could be in bad state due to bad weather conditions. However, everything seemed to be working fine.
I took the antenna and carried it indoors to analyse it in more detail and I found out an strange noise coming from the concentrator. It was the Vcc cable (from the Raspberry Pi to the concentrator) that wasn’t in good state :weary:
I have replaced it and soldered all unions in order to avoid future problems. Now it’s outdoors and everything working fine :grin:
I hope it helps other people with similar issues, thanks for your interest!!
Regards,
Celia
