I am posting here because I couldn’t find a better place to post.
I am trying to send data using an ESP32 + RN2903a. The odd part is if my
array of uint8_t is <= 10 things are great:
uint8_t txBuffer[10] // This works great!
however, if the array is larger and padded with zeros such as:
uint8_t txBuffer[20] // this will never send
I am using the #include <rn2xx3.h> library (https://github.com/jpmeijers/RN2483-Arduino-Library
so, bigger than 10, it breaks, 10 or smaller, things are great
I am sending using (I have updated the code to use software serial, and turn off the software serial when the lora chip is sending data… though it doesn’t help):
#include <rn2xx3.h>
#include <ModbusRtu.h>
#include <SoftwareSerial.h>
#define LORA_RESET 4
//create an instance of the rn2xx3 library,
//giving the software serial as port to use
rn2xx3 myLora(Serial2);
SoftwareSerial modbusSerial(32, 33); // RX, TX
uint8_t txBuffer[17];
bool rs485IsInitialized = false;
bool hasValueToSend = false;
// the setup routine runs once when you press reset:
void setup()
// Open serial communications and wait for port to open:
Serial.begin(115200); //serial port to computer
Serial2.begin(57600); //serial port to radio
Serial.println("Startup");
initialize_radio();
Serial.println("Radio Initialized Complete");
//transmit a startup message
myLora.tx("TTN Mapper on TTN Enschede node");
delay(2000);
void initialize_radio()
//reset rn2483
pinMode(LORA_RESET, OUTPUT);
digitalWrite(LORA_RESET, LOW);
delay(100);
digitalWrite(LORA_RESET, HIGH);
delay(100); //wait for the RN2xx3's startup message
Serial2.flush();
//Autobaud the rn2483 module to 9600. The default would otherwise be 57600.
myLora.autobaud();
//check communication with radio
String hweui = myLora.hweui();
while(hweui.length() != 16)
Serial.println("Communication with RN2xx3 unsuccessful. Power cycle the board.");
Serial.println(hweui);
delay(1500);
//print out the HWEUI so that we can register it via ttnctl
Serial.println("When using OTAA, register this DevEUI: ");
Serial.println(myLora.hweui());
Serial.println("RN2xx3 firmware version:");
Serial.println(myLora.sysver());
//configure your keys and join the network
Serial.println("Trying to join TTN");
bool join_result = false;
* OTAA: initOTAA(String AppEUI, String AppKey);
* If you are using OTAA, paste the example code from the TTN console here:
const char *appEui = "SECRET";
const char *appKey = "SECRET";
join_result = myLora.initOTAA(appEui, appKey);
while(!join_result)
Serial.println("Unable to join. Are your keys correct, and do you have TTN coverage?");
delay(1000); //delay a minute before retry
join_result = myLora.init();
Serial.println("Successfully joined TTN");
// the loop routine runs over and over again forever:
void loop() {
if(hasValueToSend == true ) {
modbusSerial.end();
Serial.println("Turned modbus off, waiting half a sec, and sending Lora Data");
delay(500);
Serial.println("Size of array is: " + String(sizeof(txBuffer)));
int result = myLora.txBytes(txBuffer, 12);
Serial.println("Result: " + String(result));
Serial.println("Data Sent");
delay(200);
} else {
if (rs485IsInitialized == false)
Serial.println("Initializing modbus");
rs485IsInitialized = true;
rs485.begin(&modbusSerial, 9600);
rs485.setTimeOut(2000);
wait = millis() + 1000;
state = 0;
} else {
if (rs485IsInitialized == true) {
update();
Any Ideas?
