Hello there does anybody know this module and how to operate it with ttn ?
It works with at commands to program it correctly but than i am lost no clue
No… you can’t use this module on the TTN network.
It has an UART /lora interface so you have to connect it to an MCU (arduino?) and feed it AT instructions.
It then can communicate with another module… so LoRa to LoRa imho
I suggest this module …
thx for the reply I will look at your suggestion
the advantage is that there are many examples and libraries available
Any idea where to buy these they seem out of stock everywhere and are going to end of live
I live in the netherlands
yes they are out of stock everywhere… but you can buy a complete ‘arduino’ like module with 'onboard rn2483A
you can then easy program these with arduino IDE
I just have 10 modules in Custom an should better deny the receive of them.
The moules have FCC and we need CE conformity, That means a quarter transmitting energy. (FCC = 100mw, ce=25mw).
Icould reduce the transmitters energy but then I need a new certification.
Hi BoRRoZ, Hi all,
could you explain why ?
I can not find - in AT commands - the ability to configure “Inverted IQ” : would this be the reason for the impossibility of using it on TTN?
(it’s a real question I’m a newbie !)
Thanks.
Tix
it has modem firmware installed so you only can send/receive data to and from an equal module through uart imho.
but I haven’t seen all documentation (only available after ordering)
Thanks for this return.
this module will remain mysterious for me then: I will focus on the sx1276 then …
also known as RFM95
