Sending interval doesn't work
I am trying to make a small lora gps tracker using the adafruit feather m0 rfm915. I have the following code, which works and sends what it should, but transmission runs only once (see serial monitor at the bottom), not in a loop at specified interval. I need to make TX send fom 30 to 30 seconds. Any ideea what i am doing wrong? Thanks in advance.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <TinyGPS++.h>
osjob_t sendTTNjob;
const unsigned long TX_INTERVAL = 30;
TinyGPSPlus gps;
    .nss = 8,
    .rxtx = LMIC_UNUSED_PIN,
    .rst = 4,
    .dio = {3, 6, LMIC_UNUSED_PIN},
    .rxtx_rx_active = 0,
    .rssi_cal = 8,              // LBT cal for the Adafruit Feather M0 LoRa, in dB
    .spi_freq = 8000000,
// 0x70.
static const u1_t PROGMEM APPEUI[8]={ };
static const u1_t PROGMEM DEVEUI[8]={ };
// practice, a key taken from ttnctl can be copied as-is.
// The key shown here is the semtech default key.
static const u1_t PROGMEM APPKEY[16] = {};
void os_getDevKey (u1_t* buf) {  memcpy_P(buf, APPKEY, 16);}
uint8_t coords[9];
uint32_t LatitudeBinary, LongitudeBinary;
uint16_t altitudeGps;
uint8_t hdopGps;
static osjob_t sendjob;
void get_coords () {
  for (unsigned long start = millis(); millis() - start < 1000;) {
    while (Serial1.available()) {
      char c = Serial1.read();
      Serial.write(c);
      gps.encode(c);
  if (gps.location.isValid()) {
    LatitudeBinary = ((gps.location.lat() + 90) / 180.0) * 16777215;
    LongitudeBinary = ((gps.location.lng() + 180) / 360.0) * 16777215;
    coords[0] = ( LatitudeBinary >> 16 ) & 0xFF;
    coords[1] = ( LatitudeBinary >> 8 ) & 0xFF;
    coords[2] = LatitudeBinary & 0xFF;
    coords[3] = ( LongitudeBinary >> 16 ) & 0xFF;
    coords[4] = ( LongitudeBinary >> 8 ) & 0xFF;
    coords[5] = LongitudeBinary & 0xFF;
    altitudeGps = gps.altitude.meters();
    coords[6] = ( altitudeGps >> 8 ) & 0xFF;
    coords[7] = altitudeGps & 0xFF;
    hdopGps = gps.hdop.value() / 10;
    coords[8] = hdopGps & 0xFF;
void do_send(osjob_t* j) {
  } else {
    get_coords();
    LMIC_setTxData2(1, (uint8_t*) coords, sizeof(coords), 0);
void onEvent (ev_t ev) {
  Serial.print(os_getTime());
  Serial.print(": ");
  switch (ev) {
    case EV_SCAN_TIMEOUT:
      break;
    case EV_BEACON_FOUND:
      break;
    case EV_BEACON_MISSED:
      break;
    case EV_BEACON_TRACKED:
      break;
    case EV_JOINING:
      break;
    case EV_JOINED:
      // Start sending data to TTN
      os_setCallback(&sendTTNjob, do_send);
      LMIC_setLinkCheckMode(0);
      break;
    case EV_JOIN_FAILED:
      break;
    case EV_REJOIN_FAILED:
      break;
    case EV_TXCOMPLETE:
      digitalWrite(LED_BUILTIN, LOW);
      if (LMIC.dataLen) {
        Serial.println(LMIC.dataLen);
          os_setTimedCallback(&sendTTNjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
      break;
    case EV_LOST_TSYNC:
      break;
    case EV_RESET:
      break;
    case EV_RXCOMPLETE:
      // data received in ping slot
      break;
    case EV_LINK_DEAD:
      break;
    case EV_LINK_ALIVE:
      break;
    case EV_TXSTART:
      break;
    default:
      break;
void setup()
  Serial.begin(115200);
  Serial1.begin(9600);
  delay(5000);
  Serial1.print("$PMTK301,2*2E\r\n");  // Select SBAS as DGPS source (RTCM)
  Serial1.print("$PMTK313,1*2E\r\n");  // Enable to search a SBAS satellite
  Serial1.print("$PMTK513,1*28\r\n");
  // LMIC init
  os_init();
  LMIC_reset();
  LMIC_setClockError(MAX_CLOCK_ERROR * 5 / 100);
    LMIC_setDrTxpow(DR_SF7,14);
    LMIC_setAdrMode(0);
do_send(&sendTTNjob);
void loop() {
 os_runloop_once();
And the serial monitor output:
07:37:59.860 -> $GPGSV,3,1,11,02,33,049,15,05,24,105,,11,20,044,,12,25,121,*73
07:37:59.907 -> $GPGSV,3,2,11,18,34,199,,20,25,067,,22,00,256,,25,66,125,*73
07:38:00.000 -> $GPGSV,3,3,11,26,16,306,17,29,76,321,,31,42,283,*4E
07:38:00.046 -> $GPGLL,,,,,043757.00,V,N*48
07:38:00.140 -> Packet queued
07:38:00.140 -> 376205: EV_JOINING
07:38:08.020 -> 866599: EV_TXSTART
07:38:13.124 -> 1187829: EV_JOINED
07:38:13.124 -> 1188012: EV_TXSTART
07:38:13.124 -> OP_TXRXPEND, not sending
07:38:14.262 -> 1257189: EV_TXCOMPLETE (includes waiting for RX windows)
07:38:18.782 -> 1540938: EV_TXSTART
Yes you are sending interval is to frequent, please read FUP and TTN you need to only use max 30 sec a day airtime.
And you are also most probably breaking the law.
GPS trackers are not a good fit for a TTN application.
It seems logical that you dont know where the device being tracked is so you need to assume it can be at a long distance from a Gateway, thus you should further assume it may be using spreading factor 12 mode for maximum range.
You can get a location payload in a packet that has an air time of circa 1.2 seconds @ SF12.
Thus the TTN fair access limit useage is 30 / 1.2 = 25 packets a day or one location transmission per hour.
And equally, you can’t assume it is even in range of a gateway - which makes it entirely useless:
“Yes officer, I tracked it as it left the city and then it was in an area with no gateway coverage”
“So where is it now?”
“I don’t know”
