Hello everyone
I have esp32 rn2483 lora module. Can i build a single channel gateway using these components. Is there any open source code available to build a single channel gateway
Thank you
No for two reasons:
- There is no such thing as a single channel gateway - a gateway has 8 channels minimum
- The RN module isn’t designed for all the things you may need out of a radio listening for multiple random transmissions.
A simple search fo the forum would tell you that Single Channel Packet Forwarders are disruptive to the TTN network and are unsupported. See:
If you value any part of your time, a compliant gateway is less than $100 and doesn’t require you to send days debugging your devices that can’t understand why they can’t use any of the 8 channels they expect to.
