Has somebody experience with sleepmode, escpecialy with <LowPower.h> library?
I tried this sleepmode but it kind of doesnt work. I test it with serial print. It should print “sleepmode start” if it starts and print “sleepmode end” when it ends. But, when its time for the sleepmode to start, its kinda instant print as well “sleepmode start” as “sleepmode end”
without any delay. First i thought it could be an error cause of 30/8 =3.75 cycles, but i tried it with 32/8=4 cycles and it still insta prints as well “sleepmode start” as “sleepmode end”. Am i missing something? I marked the sleep mode part in the code with “!!!”
I use Dragoni Lora, OTAA. Everythings works just fine. Ty for your help
Here is my code
#include <lmic.h> //LMIC
#include <hal/hal.h> //LMIC
#include <SPI.h> //LMIC
#include <SimpleDHT.h> //DHT11
#include <LowPower.h>
#ifdef COMPILE_REGRESSION_TEST
# define FILLMEIN 0
#else
# warning "You must replace the values marked FILLMEIN with real values from the TTN control panel!"
# define FILLMEIN (#dont edit this, edit the lines that use FILLMEIN)
#endif
static const u1_t PROGMEM APPEUI[8]={ };
static const u1_t PROGMEM DEVEUI[8]={ 0};
static const u1_t PROGMEM APPKEY[16] = { };
void os_getDevKey (u1_t* buf) { memcpy_P(buf, APPKEY, 16);}
static osjob_t sendjob;
const unsigned TX_INTERVAL = 32;
// RFM95 Arduino
.nss = 10, //Chip Select pin:D10
.rxtx = LMIC_UNUSED_PIN, //Antenna selection pin: not used in our case.
.rst = 9, //Reset pin used to reset the RFM95: D9
.dio = {2, 6, 7}, //
int pinDHT11 = A0;
SimpleDHT11 dht11(pinDHT11);
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
break;
case EV_BEACON_FOUND:
break;
case EV_BEACON_MISSED:
break;
case EV_BEACON_TRACKED:
break;
case EV_JOINING:
break;
case EV_JOINED:
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
Serial.print("netid: ");
Serial.println(netid, DEC);
Serial.print("devaddr: ");
Serial.println(devaddr, HEX);
Serial.print("artKey: ");
for (int i=0; i<sizeof(artKey); ++i) {
Serial.print(artKey[i], HEX);
Serial.println("");
Serial.print("nwkKey: ");
for (int i=0; i<sizeof(nwkKey); ++i) {
Serial.print(nwkKey[i], HEX);
Serial.println("");
LMIC_setLinkCheckMode(0);
break;
|| case EV_RFU1:
|| Serial.println(F("EV_RFU1"));
|| break;
case EV_JOIN_FAILED:
break;
case EV_REJOIN_FAILED:
break;
case EV_TXCOMPLETE:
if (LMIC.dataLen) {
Serial.print(F("Received "));
Serial.print(LMIC.dataLen);
// Schedule next transmission
// !!!!!!!!!!!!!!!!!!!!!! sleep mode part
//os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
Serial.print("sleepmode start ");
for (int i=0; i<int(TX_INTERVAL/8); i++) {
// Use library from https://github.com/rocketscream/Low-Power
LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
Serial.print("Sleepmdoe end");
do_send(&sendjob);
// !!!!!!!!!!!!!!!!!!!!!! end of sleep mode part
break;
case EV_LOST_TSYNC:
break;
case EV_RESET:
break;
case EV_RXCOMPLETE:
// data received in ping slot
break;
case EV_LINK_DEAD:
break;
case EV_LINK_ALIVE:
break;
|| case EV_SCAN_FOUND:
|| Serial.println(F("EV_SCAN_FOUND"));
|| break;
case EV_TXSTART:
break;
default:
break;
void do_send(osjob_t* j){
byte ID=1;
Serial.println("=================================");
Serial.println("Sample DHT11...");
byte temperature = 0;
byte humidity = 0;
int err = SimpleDHTErrSuccess;
if ((err = dht11.read(&temperature, &humidity, NULL)) != SimpleDHTErrSuccess) {
Serial.print("Read DHT11 failed, err="); Serial.println(err);delay(1000);
return;
Serial.print("Sample OK: ");
Serial.print((int)temperature); Serial.print(" *C, ");
Serial.print((int)humidity); Serial.println(" H");
// DHT11 sampling rate is 1HZ.
delay(1500);
static int8_t mydata[6] ;
mydata[0] = highByte(ID);
mydata[1] = lowByte(ID);
mydata[2] = highByte(temperature);
mydata[3] = lowByte(temperature);
mydata[4] = highByte(humidity);
mydata[5] = lowByte(humidity);
} else {
LMIC_setTxData2(1, mydata, sizeof(mydata), 0);
void setup() {
Serial.begin(9600);
#ifdef VCC_ENABLE
pinMode(VCC_ENABLE, OUTPUT);
delay(1000);
#endif
// LMIC init
os_init();
LMIC_reset();
do_send(&sendjob);
void loop() {
os_runloop_once();
