This matches what I have seen today with a bunch of devices last showing data in Cayenne integration around 16:00/16:15 depending on their Tx interval = most show last data around 16:10/16:13… 5 hrs down doesnt look good I wonder Is this just a TTN issue or is TTI also seeing problem? Just for comparison between services (back-end or routing or integrations problem I wonder…)
Same problem here. Last transfer today, 14.9.2019 17.15h Berlin time. Can see the gateway traffic, but devices are not updated.
Eckehard
Same for me, Broken since 3:15pm GMT. gateway trafic OK but no data in apps …
Good luck for those who are on the run !
Nico
when using ttnmapper this evening I did not reach any gateway. Even at home , next to my gateway no packets arriving . When checked on TTN console I could see packets arriving to gateway but not visible in Application/Device view.
It looks like also many other gateways must be similarly impacted. Even sending SF12 packets from the balcony, from where I can typically reach 3-4 other gateways, I can not receive packets in TTN .
(well… actually packets must be arriving to TTN , as they are visible in gateway data but not in the Device-Data)
My gateway is connected to ttn-router-eu
My concern is that this issue is not yet listed on https://status.thethings.network/ so not sure if someone already looking into it.
Alexander
same issue here, also ttn-router-eu.
Issue started around 3PM UTC
Hi, same issue here as well; node backend stopped showing data packet, but TTN gateway is showing incoming traffic.
same issue here, also ttn-router-eu. Data from 2 Gateways arrive at TTN, ( as seen on the gateway console ) but not at the application. Last Data seen 2019-09-14T15:05:21.264747674Z with is similar to the Problems reported here.
We have same problem with 2 gateways and several end devices. Gateways are able to receive uplinks from devices but data are not shown in the applications. The problem was detected yesterday at 17:15 Berlin time zone, around 15 hours without data in integrations…
Same here. No data since 17:15h
Thanks for your responses. Good to know it’s not just our account.
In terms of triangulation, can anyone confirm that their routing between Gateway and Application is working, maybe in a different region to EU.
I have pinged a couple of people at TTI to see if that tickles the support team into action.
Gary
same here , not data since sat. around 14:30utc
(EU Server)
no data in Denmark also, since 14/09 15:11h UTC. I can see the data arriving in the Gateways but not in the applications, in 3 different gateways.
Same behaviour for me. Gateway/Sensor in Germany, EU server and MQTT integration, last recievced data was yesterday (14.09.19) at 17:08 CEST (sensor does transmit every 10 minutes). Since then nothing. The packets are visible in the ttn console as gateway traffic, but are not visible in the ttn console in the corresponding application, so it seems routing to the applications is somehow broken.
Hopefully we can get at least some kind of ETA for a fix soon…
Me as well. Gateway appears up. Gateway receives data MQTT callback doesn’t appear to happen.
Soon 24h without a word from TTN staff, this matter is not managed very well… Is there no support/issue mail that could be used to notify the staff something is wrong…
For EU no more ‘me too’ required. As many observed there is an issue. For people wanting to report issues, please use the TTN slack #ops channel. That is the official support channel to notify TTN.
Please keep in mind this is the community network, free to use for all. There are no SLAs in place and we can’t demand response/resolution within a certain amount of time. (I know it hurts, running 2 POCs myself on which this won’t reflect well)
For the last few weeks we have also seen the meshed server in Australia not forwarding messages to Applications on the EU server
Interregion communications being down is a known problem with backend V2. TTN explicitlty advices to run gateways, nodes and applications connected to the same zone.
Ok, but without the first „Me too“‘s in the forum I would still be spending a Sunday looking for issues on my nodes and would not have contacted the TTN. So it was helpful.
And of course there are no SLAs but a downtime of more than 17h might lead people to move to other LoRa solutions which is bad for the overall TTN community. At least I would have hoped for a more active communication on this issue. The status still only shows „Performance issues“.
Anyway, fingers crossed to get things fixed soon.
Best, Niels
