The kickstarter gateway on V3
Hi
is there anybody that has successfully connected the kickstarter gateway to to TTN V3 ?
if yes can you please share how to setup this GW on new TTN V3 ?
it has to be possible the gateway is from TTN itself !
After several trials no i could not connect this gateway …
thanks a lot
best regs
gianpaolo
Yes, I have as have many/most others. Have you used Forum search? It have been well covered. Note minimum firmware version needed for migration/ new registration in V3 and (confusing for some) you don’t need to enter an EUI…
hi
firmware is 1.05, where can I find latest fw version and procedeure for update the fw ?
thanks
best regs
gianpaolo
For update information search the forum for the answer… For instance this message not even 24 hours old concerns the same subject…
