The Things Indoor Gateway just goes offline after connect
I have recently purchased a The Things Indoor LoRaWAN WiFi Gateway and it is registered with TTN (meshed AU). The green light goes solid and the Last Seen counter resets to zero on TTN, then… nothing. I have two gateways on AU915 here and the other one increments Received Messages for the devices here but TTIG sees zero. The last seen timer increments for one hour and then the gateway is marked offline. Powering off/on repeats the above.
The unit does not have any sort of admin interface so I am a bit stuck how to debug this. Tried on both work and home networks with same behaviour, no outbound filtering.
I have hooked up the serial console and it seems the unit is listening on EU868, snippets from the log
1970-01-01 00:00:18.899 [TCE:INFO] Connecting to INFOS: wss://lns.eu.thethings.network:443
1970-01-01 00:00:19.937 [SYS:DEBU] Free Heap: 23568 (min=23296) wifi=5 mh=7 cups=8 tc=1
1970-01-01 00:00:20.945 [SYS:DEBU] Free Heap: 17784 (min=17664) wifi=5 mh=7 cups=8 tc=1
1970-01-01 00:00:21.949 [SYS:DEBU] Free Heap: 17784 (min=17584) wifi=5 mh=7 cups=8 tc=1
1970-01-01 00:00:22.039 [TCE:INFO] Infos: 58a0:cbff:fe80:2cbb muxs-::0 wss://lns.eu.thethings.network:443/traffic/eui-58A0CBFFFE802CBB
2021-01-30 05:36:54.594 [S2E:INFO] Configuring for region: EU863 – 863.0MHz…870.0MHz
2021-01-30 05:36:54.598 [S2E:VERB] DR0 SF12/BW125
2021-01-30 05:36:54.600 [S2E:VERB] DR1 SF11/BW125
2021-01-30 05:36:54.602 [S2E:VERB] DR2 SF10/BW125
2021-01-30 05:36:54.607 [S2E:VERB] DR3 SF9/BW125
2021-01-30 05:36:54.611 [S2E:VERB] DR4 SF8/BW125
2021-01-30 05:36:54.616 [S2E:VERB] DR5 SF7/BW125
2021-01-30 05:36:54.621 [S2E:VERB] DR6 SF7/BW250
2021-01-30 05:36:54.625 [S2E:VERB] DR7 FSK
2021-01-30 05:36:54.630 [S2E:VERB] DR8 FSK
2021-01-30 05:36:54.634 [S2E:VERB] DR9 FSK
2021-01-30 05:36:54.638 [S2E:VERB] DR10 FSK
2021-01-30 05:36:54.642 [S2E:VERB] DR11 FSK
2021-01-30 05:36:54.646 [S2E:VERB] DR12 FSK
2021-01-30 05:36:54.650 [S2E:VERB] DR13 FSK
2021-01-30 05:36:54.655 [S2E:VERB] DR14 FSK
2021-01-30 05:36:54.659 [S2E:VERB] DR15 FSK
I ordered an AU915, is this a configuration error or have I been sent the wrong unit?
The TTIG is currently connected to V2 of TTN. As a result.of this not alie functionalities are implemented as it seems. For example keep alive messages are not used to update the latest heard timer in V2 console.
I can confirm that after x minutes the TTIG is stated as off-line however, when a packet is received it goes back online.
The cure is to have a node that transmit every 30 minutes or so.
To have your TTIG working in Australia you need to post some information in TTIG AU915 support
TTN is still working on an automated way to resolve this.
I am having the exact same issue the Things Indoor Gateway in Australia. A resolution would be most appreciated.
Just a quick note to let you know that the problem has been resolved.
A feature needs to be enabled which can be requested on the TTIG AU915 support thread.
