ysimonx
(Ysimonx)
October 4, 2020, 8:35am
1
Hello
i just bought 3 things node
i managed to connect them on an application, i see traffic data for event “motion” or “interval”
However, nothing happens when i press on the button… for the 3 of them…
can you help me please ?
this is my sketch based upon the “example” sketch
#include <TheThingsNode.h>
const char *appEui = "****";
const char *appKey = "****";
#define loraSerial Serial1
#define debugSerial Serial
// Replace REPLACE_ME with TTN_FP_EU868 or TTN_FP_US915
#define freqPlan TTN_FP_EU868
TheThingsNetwork ttn(loraSerial, debugSerial, freqPlan);
TheThingsNode *node;
#define PORT_SETUP 1
#define PORT_INTERVAL 2
#define PORT_MOTION 3
#define PORT_BUTTON 4
Decoder payload function
var decoded = {};
var events = {
1: 'setup',
2: 'interval',
3: 'motion',
4: 'button'
decoded.event = events[port];
decoded.battery = (bytes[0] << 8) + bytes[1];
decoded.light = (bytes[2] << 8) + bytes[3];
if (bytes[4] & 0x80)
decoded.temperature = ((0xffff << 16) + (bytes[4] << 8) + bytes[5]) / 100;
else
decoded.temperature = ((bytes[4] << 8) + bytes[5]) / 100;
return decoded;
void setup()
loraSerial.begin(57600);
debugSerial.begin(9600);
// Wait a maximum of 10s for Serial Monitor
while (!debugSerial && millis() < 10000)
// Config Node
node = TheThingsNode::setup();
node->configLight(true);
node->configInterval(true, 60000);
node->configTemperature(true);
node->configButton(true);
node->onWake(wake);
node->onInterval(interval);
node->onSleep(sleep);
node->onMotionStart(onMotionStart);
node->onButtonRelease(onButtonRelease);
node->onButtonPress(onButtonPress);
// Test sensors and set LED to GREEN if it works
node->showStatus();
node->setColor(TTN_GREEN);
debugSerial.println("-- TTN: STATUS");
ttn.showStatus();
debugSerial.println("-- TTN: JOIN");
ttn.join(appEui, appKey);
debugSerial.println("-- SEND: SETUP");
sendData(PORT_SETUP);
void loop()
node->loop();
void interval()
node->setColor(TTN_BLUE);
debugSerial.println("-- SEND: INTERVAL");
sendData(PORT_INTERVAL);
void wake()
void sleep()
node->setColor(TTN_BLACK);
void onMotionStart()
debugSerial.print("-- SEND: MOTION");
sendData(PORT_MOTION);
void onButtonPress()
debugSerial.println("-- PRESS BUTTON");
void onButtonRelease(unsigned long duration)
debugSerial.print("-- SEND: BUTTON");
debugSerial.println(duration);
sendData(PORT_BUTTON);
void sendData(uint8_t port)
// Wake RN2483
ttn.wake();
ttn.showStatus();
node->showStatus();
byte *bytes;
byte payload[12];
uint16_t battery = node->getBattery();
bytes = (byte *)&battery;
payload[0] = bytes[1];
payload[1] = bytes[0];
uint16_t light = node->getLight();
bytes = (byte *)&light;
payload[2] = bytes[1];
payload[3] = bytes[0];
int16_t temperature = round(node->getTemperatureAsFloat() * 100);
bytes = (byte *)&temperature;
payload[4] = bytes[1];
payload[5] = bytes[0];
float x,y,z;
node->getAcceleration(&x, &y, &z);
int16_t r_x = round(x * 100);
int16_t r_y = round(y * 100);
int16_t r_z = round(z * 100);
bytes = (byte *)&r_x;
payload[6] = bytes[1];
payload[7] = bytes[0];
bytes = (byte *)&r_y;
payload[8] = bytes[1];
payload[9] = bytes[0];
bytes = (byte *)&r_z;
payload[10] = bytes[1];
payload[11] = bytes[0];
ttn.sendBytes(payload, sizeof(payload), port);
// Set RN2483 to sleep mode
ttn.sleep(60000);
// This one is not optionnal, remove it
// and say bye bye to RN2983 sleep mode
delay(50);
ysimonx:
Are you sure you’re not triggering motion just before you’re pressing the button?
(Aside, please see How do I format my forum post? [HowTo] )
ysimonx
(Ysimonx)
October 4, 2020, 11:14am
3
Thank you
but, even after a while, without moving any sensor, nothing happens when press a button and release it, on 3 of them…
To be very precise: with your code nothing will happen on button press , but only on its release .
I assume you only changed the appEUI and appKey? (It looks good, but I’ve not compared line-by-line.)
You could comment/remove the following just to be sure:
The sketch I use looks the same, but it does not have any node->onButtonPress(onButtonPress) defined.
ysimonx
(Ysimonx)
October 4, 2020, 11:19am
5
ok, i will give it a try , thank you
Even more: it also does not have node->configButton(true) (but surely acts on the button release). (Also, it does not send any acceleration details.)
ysimonx
(Ysimonx)
October 4, 2020, 2:08pm
7
Hi Arjan
a) even with the original example sketch, nothing happens with the button
b) when i shake the NODE, keeping the button pressed, the status shows
16:04:06.727 -> Button pressed: No
as it occurs on 3 different NODES, i think this is a problem with software (i don’t know which one)
example with “interval” event
16:04:58.634 -> -- SEND: INTERVAL
16:04:58.851 -> EUI: 0004A30B00EB2EA9
16:04:58.851 -> Battery: 3283
16:04:58.851 -> AppEUI: xxx (hidden)
16:04:58.884 -> DevEUI: xxx (hidden)
16:04:58.884 -> Data Rate: 5
16:04:58.884 -> RX Delay 1: 1000
16:04:58.884 -> RX Delay 2: 2000
16:04:58.884 -> Light: 24
16:04:58.884 -> Temperature: 23.25 C
16:04:58.884 -> Temperature alert: No
16:04:58.884 -> Moving: No
16:04:58.884 -> Button pressed: No
16:04:58.884 -> Color: Blue
16:04:58.884 -> USB connected: Yes
16:04:58.884 -> Battery voltage: 4742 MV
16:04:58.884 -> Sending: mac tx uncnf 2 128600180915
16:05:01.018 -> Successful transmission
16:05:01.018 -> Sending: sys sleep 60000
example with “motion” event
16:07:15.624 -> -- SEND: MOTIONEUI: 0004A30B00EB2EA9
16:07:15.858 -> Battery: 3283
16:07:15.858 -> AppEUI: ***
16:07:15.858 -> DevEUI: ***
16:07:15.892 -> Data Rate: 5
16:07:15.892 -> RX Delay 1: 1000
16:07:15.892 -> RX Delay 2: 2000
16:07:15.892 -> Light: 17
16:07:15.892 -> Temperature: 23.19 C
16:07:15.892 -> Temperature alert: No
16:07:15.892 -> Moving: Yes
16:07:15.892 -> Button pressed: No
16:07:15.892 -> Color: Blue
16:07:15.892 -> USB connected: Yes
16:07:15.892 -> Battery voltage: 4736 MV
16:07:15.892 -> Sending: mac tx uncnf 3 12860012090F
16:07:18.050 -> Successful transmission
16:07:18.050 -> Sending: sys sleep 60000
16:07:20.798 -> -- SEND: MOTIONEUI: 0004A30B00EB2EA9
16:07:21.012 -> Battery: 3294
16:07:21.012 -> AppEUI: ***hidden***
16:07:21.047 -> DevEUI: ***hidden***
16:07:21.047 -> Data Rate: 5
16:07:21.047 -> RX Delay 1: 1000
16:07:21.047 -> RX Delay 2: 2000
16:07:21.047 -> Light: 17
16:07:21.047 -> Temperature: 23.19 C
16:07:21.047 -> Temperature alert: No
16:07:21.047 -> Moving: Yes
16:07:21.047 -> Button pressed: No
16:07:21.047 -> Color: Blue
16:07:21.047 -> USB connected: Yes
16:07:21.047 -> Battery voltage: 4742 MV
16:07:21.047 -> Sending: mac tx uncnf 3 12800011090F
16:07:23.221 -> Successful transmission
16:07:23.221 -> Sending: sys sleep 60000
Well, keeping the button pressed won’t generate button events, I assume. The device will/should act on changes, and will remember its state to return when requested at a later time. But of course, it should have handled and remembered the button press (unless you already had it pressed while booting the device).
It seems GitHub - TheThingsNetwork/arduino-node-lib: Arduino Library for The Things Node has not changed since February. Can you tell which version you’re using? (I was using 2.0.8 it seems.)
ysimonx
(Ysimonx)
October 4, 2020, 2:52pm
9
I tried with both
“TheThingsNetwork” library : 2.6.0
“TheThingsNode” library : 2.0.9
i also tried with
“TheThingsNetwork” library : 2.5.16
“TheThingsNode” library : 2.0.8
(Sorry, just bricked my device by selecting the wrong Arduino board. Oh well. I know how to fix that , but that’s not going to happen right now. Success!)
ysimonx
(Ysimonx)
October 4, 2020, 4:45pm
11
i had the same problem
Arjan, don’t waste your time, you helped me a lot, it’s sunday
stonecroft
(Stonecroft)
November 22, 2020, 5:26pm
12
I have the exact same problem as ysimonx.
I bought my “the things node” last week but due to a flyer packed with the node I understand that this node is probably a little older.
Has something changed with the library or the basic example program last year?
A bit of an old thread - but I am having the same problem as @ysimonx (and @stonecroft , of course).
Did you guys find any solution? Or is it just faulty hardware? Or simply my misunderstanding?
Thx, cheers
Floating
ysimonx
(Ysimonx)
March 25, 2021, 8:34pm
14
Hi @FloatingOne
I did not find one solution. Not sure if it is hardware ou firmware … but i never heard about someone who managed to use it…
regards
