The WORKBENCH part 1
Yes I’ll mount a fuse between AC and the HiLINK.
X488
Also a 2 color LED, red on power on (plugged in) and green flashing when it can reach a gateway, green continue when the coffee machine/tv is on and a notification is transmitted.
These HiLinks are very good (tested before) , but I’ve never used them on a node, I’m more concerned about possible noise interference with that hall sensor, test before mounting everything :wink:
up to 200 mA load the voltage and ripple are fine.
X489
