Ttgo T-beam
(QLion) #1
Hi
Does anyone have a example sketch to connect a ttgo T-beam to The Things Network?
(Verkehrsrot) #2
Look here, T-Beam is supported:
(QLion) #3
Thanks!!
(Deux Vis) #4
I ported a simple TTN Mapper sketch to the T-Beam, might be good for starters.
(Nalberto) #5
I just tried using the deep sleep mode and the TTGO t-beam board still draws 44mA.
The product description says:
Sleep current :0.2uA@SLEEP
1.5uA@IDLE
I know the TTGO Lora had issues with deep sleep too. I was just hoping that this one was better.
2 questions
  • What is the minimum current achievable with the TTGO lora just by code and without changing the board physically? Code example would be great too.
  • Can you disable peripherals just by code. I am not familiar with that. Is that just by redefining pins to low or input?
(Linar) #6
Has anyone taken advantage of onboard PSRAM ?
Wi-Fi and BT (Classis & LE) are very RAM hungry functionalities - it seems that very soon the ESP-IDF and app(s) will exhaust all the ESP32’s built-in memory available…
(Deux Vis) #7
That’s strange. Yesterday I tried to measure its current consumption - on USB power - and tis was drawing around 10 mA only - not even sleeping.
Edit : forget that, bad reading on my part : it’s actually 50 to 80 mA on the USB 5V.
(Verkehrsrot) #8
Yes, PSRAM is automatically present since using the new arduino-espressif32 core v1.1.0; i now get 4 MB free RAM.
(Deux Vis) #9
oooh nice, time to update, thanks for the heads-up.
(Verkehrsrot) #10
Be careful when updating. I ran in several issues i had to solve after update.
And one issue is getting I2C timeout errors, which i could not fix yet.
(Deux Vis) #11
No problems on my side, was not using I²C anyway.
My total “dynamic memory” only changed from 294912 to 327680 bytes then. Did you do anything special to get that 4MB figure ?
(Verkehrsrot) #12
Maybe we compare different values here.
My 4MB RAM are shown by ESP.getFreeHeap():
[D][esp32-hal-psram.c:48] psramInit(): PSRAM enabled
[I][main.cpp:490] setup(): Starting PAXCNT 1.3.83
[I][main.cpp:507] setup(): This is ESP32 chip with 2 CPU cores, WiFi/BT/BLE, silicon revision 1, 4MB external Flash
[I][main.cpp:508] setup(): ESP32 SDK: v3.2-dev-39-gaaf12390
[D][macsniff.cpp:83] mac_add(): new   WiFi RSSI -93dBi -> MAC 25CAD083 -> Hash 5A14 -> WiFi:1  BLTH:0 -> **4245260 Bytes left**
(Ineedtoknow) #13
Hello everyone,
I’m interested in getting a T-Beam and I’d like to know if there are any hardware issues with it. Does low power work for all modules on board?
(Verkehrsrot) #14
There are no special low power features on T-Beam, i.e. it is not possible to deactivate the USB driver and the battery charging circuit. For low power you should select other device, i.e. Nexus by Ideetron.
(Ineedtoknow) #15
Does LoRa32 v2.1 have these issues fixed? I could add a gps module to that board.
(Verkehrsrot) #16
No. As far as i see all TTGO boards are based on the same common schematics.
Again, if you’re looking for low power devices, you’re looking for something more elaborated, and again, i would recommend www.ideetron.nl
You may also go for a SODAQ.
(Ineedtoknow) #17
Ok, thank you! I’ll look into them.
(Costel) #18
hello,
i was triyng to program the ttgo t-beam butt i get this error:
LMIC_setSession (0x1, DEVADDR, NWKSKEY, APPSKEY);
exit status 1
‘DEVADDR’ was not declared in this scope
(Deux Vis) #19
Can you share your code ? But please use proper formatting as described HERE
(Costel) #20
Here is my code:
#include <TinyGPS++.h>
#include <lmic.h>
#include <hal/hal.h>
#include <WiFi.h>
// UPDATE the config.h file in the same folder WITH YOUR TTN KEYS AND ADDR.
#include "config.h"
// T-Beam specific hardware
#define BUILTIN_LED 21
#define GPS_TX 12
#define GPS_RX 15
// The TinyGPS++ object
TinyGPSPlus gps;
HardwareSerial GPSSerial(1);
char s[32]; // used to sprintf for Serial output
// DISABLE_JOIN is set in config.h, otherwise the linker will complain).
static osjob_t sendjob;
// Schedule TX every this many seconds (might become longer due to duty cycle limitations).
const unsigned TX_INTERVAL = 30;
// Pin mapping
  .nss = 18,
  .rxtx = LMIC_UNUSED_PIN,
  .rst = LMIC_UNUSED_PIN, // was "14,"
  .dio = {26, 33, 32},
unsigned long last_update = 0;
String toLog;
uint8_t txBuffer[9];
uint32_t LatitudeBinary, LongitudeBinary;
uint16_t altitudeGps;
uint8_t hdopGps;
#define PMTK_SET_NMEA_UPDATE_05HZ  "$PMTK220,2000*1C"
#define PMTK_SET_NMEA_UPDATE_1HZ  "$PMTK220,1000*1F"
#define PMTK_SET_NMEA_OUTPUT_RMCGGA "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
void build_packet()
  while (GPSSerial.available())
    gps.encode(GPSSerial.read());
  LatitudeBinary = ((gps.location.lat() + 90) / 180.0) * 16777215;
  LongitudeBinary = ((gps.location.lng() + 180) / 360.0) * 16777215;
  sprintf(s, "Lat: %f", gps.location.lat());
  Serial.println(s);
  sprintf(s, "Lng: %f", gps.location.lng());
  Serial.println(s);
  txBuffer[0] = ( LatitudeBinary >> 16 ) & 0xFF;
  txBuffer[1] = ( LatitudeBinary >> 8 ) & 0xFF;
  txBuffer[2] = LatitudeBinary & 0xFF;
  txBuffer[3] = ( LongitudeBinary >> 16 ) & 0xFF;
  txBuffer[4] = ( LongitudeBinary >> 8 ) & 0xFF;
  txBuffer[5] = LongitudeBinary & 0xFF;
  altitudeGps = gps.altitude.meters();
  txBuffer[6] = ( altitudeGps >> 8 ) & 0xFF;
  txBuffer[7] = altitudeGps & 0xFF;
  hdopGps = gps.hdop.value()/10;
  txBuffer[8] = hdopGps & 0xFF;
  toLog = "";
  for(size_t i = 0; i<sizeof(txBuffer); i++)
    char buffer[3];
    sprintf(buffer, "%02x", txBuffer[i]);
    toLog = toLog + String(buffer);
  Serial.println(toLog);
void onEvent (ev_t ev) {
  switch (ev) {
    case EV_SCAN_TIMEOUT:
      break;
    case EV_BEACON_FOUND:
      break;
    case EV_BEACON_MISSED:
      break;
    case EV_BEACON_TRACKED:
      break;
    case EV_JOINING:
      break;
    case EV_JOINED:
      // during join, but not supported by TTN at this time).
      LMIC_setLinkCheckMode(0);
      break;
    case EV_RFU1:
      Serial.println(F("EV_RFU1"));
      break;
    case EV_JOIN_FAILED:
      break;
    case EV_REJOIN_FAILED:
      break;
    case EV_TXCOMPLETE:
      digitalWrite(BUILTIN_LED, LOW);
      if (LMIC.txrxFlags & TXRX_ACK) {
        Serial.println(F("Received Ack"));
      if (LMIC.dataLen) {
        sprintf(s, "Received %i bytes of payload", LMIC.dataLen);
        Serial.println(s);
        sprintf(s, "RSSI %d SNR %.1d", LMIC.rssi, LMIC.snr);
        Serial.println(s);
      // Schedule next transmission
      os_setTimedCallback(&sendjob, os_getTime() + sec2osticks(TX_INTERVAL), do_send);
      break;
    case EV_LOST_TSYNC:
      break;
    case EV_RESET:
      break;
    case EV_RXCOMPLETE:
      // data received in ping slot
      break;
    case EV_LINK_DEAD:
      break;
    case EV_LINK_ALIVE:
      break;
    default:
      break;
void do_send(osjob_t* j) {
  } else {
    build_packet();
    LMIC_setTxData2(1, txBuffer, sizeof(txBuffer), 0);
    digitalWrite(BUILTIN_LED, HIGH);
void setup() {
  Serial.begin(115200);
  Serial.println(F("TTN Mapper"));
  //Turn off WiFi and Bluetooth
  WiFi.mode(WIFI_OFF);
  btStop();
  GPSSerial.begin(9600, SERIAL_8N1, GPS_TX, GPS_RX);
  GPSSerial.setTimeout(2);
  GPSSerial.println(F(PMTK_SET_NMEA_OUTPUT_RMCGGA));
  GPSSerial.println(F(PMTK_SET_NMEA_UPDATE_1HZ));   // 1 Hz update rate
  // LMIC init
  os_init();
  LMIC_reset();
  LMIC_setupChannel(0, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
  LMIC_setupChannel(1, 868300000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI);      // g-band
  LMIC_setupChannel(2, 868500000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
  LMIC_setupChannel(3, 867100000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
  LMIC_setupChannel(4, 867300000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
  LMIC_setupChannel(5, 867500000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
  LMIC_setupChannel(6, 867700000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
  LMIC_setupChannel(7, 867900000, DR_RANGE_MAP(DR_SF12, DR_SF7),  BAND_CENTI);      // g-band
  LMIC_setupChannel(8, 868800000, DR_RANGE_MAP(DR_FSK,  DR_FSK),  BAND_MILLI);      // g2-band
  LMIC.dn2Dr = DR_SF9;
  // Set data rate and transmit power for uplink (note: txpow seems to be ignored by the library)
  LMIC_setDrTxpow(DR_SF7,14);
  // Start job
  do_send(&sendjob);
  pinMode(BUILTIN_LED, OUTPUT);
void loop() {
  os_runloop_once();
