I tried to connect it to a mobile phone hotspot, with the same result as on my ordinary internet connection. With one exeption, now I get:
1970-01-01 00:01:25.251 [AIO:ERRO] [-1] HTTP connect failed: UNKNOWN ERROR CODE (0052)
On my ordinary internet connection, I get:
1970-01-01 00:01:52.820 [AIO:ERRO] [2] HTTP connect failed: UNKNOWN ERROR CODE (0044)
But the result is the same; retry evry 1 minute.
Here is the log on the mob. net:
lll`mode : sta(2c:f4:32:50:c6:61)
add if0
1970-01-01 00:00:02.217 [SYS:INFO] FSCK found section marker A0
1970-01-01 00:00:02.224 [SYS:INFO] FSCK section A: 28 records, 6280 bytes used, 1017720 bytes free
1970-01-01 00:00:02.712 [SYS:INFO] FSCK section A followed by erased flash - all clear.
1970-01-01 00:00:02.721 [SYS:INFO] Checking file: [ cups-boot.uri ] OK
1970-01-01 00:00:02.725 [SYS:INFO] Checking file: [ cups-boot.key ] OK
1970-01-01 00:00:02.729 [SYS:INFO] Checking file: [ cups-boot.trust ] OK
1970-01-01 00:00:02.733 [SYS:INFO] Checking file: [ sig-0.key ] OK
1970-01-01 00:00:02.738 [SYS:INFO] Checking file: [ station.conf ] OK
1970-01-01 00:00:02.760 [SYS:INFO] Checking file: [ web/index.html ] OK
1970-01-01 00:00:02.769 [any:INFO] HW pipe bound with fd=0
1970-01-01 00:00:02.771 [any:INFO] AIO registered for HW pipe &aio=0x3ffeea98
1970-01-01 00:00:00.007 [SYS:DEBU] ======= VER ======
1970-01-01 00:00:00.008 [SYS:DEBU] Station Version 2.0.4(minihub/debug)
1970-01-01 00:00:00.010 [SYS:DEBU] Version Commit f63908e
1970-01-01 00:00:00.014 [SYS:DEBU] Station Build 2020-05-07 16:03:53
1970-01-01 00:00:00.020 [SYS:DEBU] Firmware Version 2.0.4
1970-01-01 00:00:00.025 [SYS:DEBU] FW Flavor ID semtech0
1970-01-01 00:00:00.031 [SYS:DEBU] Model minihub
1970-01-01 00:00:00.042 [SYS:DEBU] ======= SYS ======
1970-01-01 00:00:00.044 [SYS:DEBU] CPU Freq 80 / 80000000 / 80000000
1970-01-01 00:00:00.048 [SYS:DEBU] Random Number 1585696536
1970-01-01 00:00:00.053 [SYS:DEBU] Reset cause 4
1970-01-01 00:00:00.058 [SYS:DEBU] Booting USER_BIN 1
1970-01-01 00:00:00.063 [SYS:DEBU] FW start addr 0x00001000
1970-01-01 00:00:00.069 [SYS:DEBU] ESP SDK version 2.0-dev(9ec59b5)
1970-01-01 00:00:00.075 [SYS:DEBU] mbedTLS version 2.6.1
1970-01-01 00:00:00.080 [SYS:DEBU] Free Heap Startup 58280 bytes
1970-01-01 00:00:00.086 [SYS:DEBU] ======= MFG ======
1970-01-01 00:00:00.092 [SYS:DEBU] SN TBMH100868002061
1970-01-01 00:00:00.102 [SYS:DEBU] MTIME 2019-07-06 11:17:50
1970-01-01 00:00:00.104 [SYS:DEBU] PERSO_HASH 0xfcd3e0c8
1970-01-01 00:00:00.109 [SYS:DEBU] AP_PW xxxxxxxxxxxxxxxx
1970-01-01 00:00:00.114 [SYS:DEBU] AP MAC 58:A0:CB:80:0C:10
1970-01-01 00:00:00.121 [SYS:DEBU] EUI 58-A0-CB-FF-FE-80-0C-10
1970-01-01 00:00:00.127 [SYS:DEBU] STA MAC 2C:F4:32:50:C6:61
1970-01-01 00:00:00.134 [SYS:DEBU] ======= CRD ======
1970-01-01 00:00:00.142 [SYS:DEBU] [cups] auth=3 -> https://rjs.sm.tc:9191
1970-01-01 00:00:00.145 [SYS:DEBU] type=0 -> /s2/cups.trust
1970-01-01 00:00:00.151 [SYS:DEBU] type=2 -> /s2/cups.key
1970-01-01 00:00:00.163 [SYS:DEBU] [cups-bak] - not available
1970-01-01 00:00:00.168 [SYS:DEBU] [cups-boot] auth=3 -> https://rjs.sm.tc:9191
1970-01-01 00:00:00.170 [SYS:DEBU] type=0 -> /s2/cups-boot.trust
1970-01-01 00:00:00.174 [SYS:DEBU] type=2 -> /s2/cups-boot.key
1970-01-01 00:00:00.181 [SYS:DEBU] [tc] - not available
1970-01-01 00:00:00.186 [SYS:DEBU] [tc-bak] - not available
1970-01-01 00:00:00.191 [SYS:DEBU] [tc-boot] - not available
1970-01-01 00:00:00.196 [SYS:DEBU] ======= MEM ======
data : 0x3ffe8000 ~ 0x3ffe8d40, len: 3392
rodata: 0x3ffe8d40 ~ 0x3ffe8fd0, len: 656
bss : 0x3ffe8fd0 ~ 0x3fff00a0, len: 28880
heap : 0x3fff00a0 ~ 0x40000000, len: 65376
1970-01-01 00:00:00.223 [SYS:DEBU] ==================
1970-01-01 00:00:00.233 [SYS:DEBU] Start WiFi Scan
1970-01-01 00:00:01.231 [SYS:DEBU] Free Heap: 57528 (min=56816) wifi=0 mh=1 cups=0 tc=0
scandone
1970-01-01 00:00:02.654 [SYS:DEBU] mh_scanDoneCB: status=0
1970-01-01 00:00:02.656 [SYS:DEBU] SSID | CH @ RSSI | auth | b/g/n | wps
1970-01-01 00:00:02.658 [SYS:DEBU] H0401 - Studio de Paris | ch-01@-80 dBm | auth=3 | 1/1/1 | 1
1970-01-01 00:00:02.665 [SYS:DEBU] Pretty fly for a WiFi | ch-01@-89 dBm | auth=3 | 1/1/1 | 1
1970-01-01 00:00:02.674 [SYS:DEBU] WillYouBeMyWifi | ch-01@-92 dBm | auth=3 | 1/1/1 | 1
1970-01-01 00:00:02.682 [SYS:DEBU] Mocor Hotspot | ch-06@-30 dBm | auth=3 | 1/1/1 | 0
1970-01-01 00:00:02.690 [SYS:DEBU] ACEQGiNL | ch-06@-92 dBm | auth=3 | 1/1/1 | 1
1970-01-01 00:00:02.698 [SYS:DEBU] Zyxel_1F18 | ch-11@-57 dBm | auth=3 | 1/1/1 | 1
1970-01-01 00:00:02.706 [SYS:DEBU] WillYouBeMyWifi | ch-11@-91 dBm | auth=3 | 1/1/1 | 1
1970-01-01 00:00:03.236 [SYS:DEBU] WiFi connecting to 'Mocor Hotspot'
1970-01-01 00:00:03.317 [SYS:INFO] DHCP is not started. Starting it...
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
pm open phy_2,type:2 0 0
cnt
1970-01-01 00:00:06.737 [SYS:DEBU] Free Heap: 57904 (min=55408) wifi=1 mh=3 cups=0 tc=0
connected with Mocor Hotspot, channel 6
dhcp client start...
ip:192.168.43.163,mask:255.255.255.0,gw:192.168.43.1
1970-01-01 00:00:11.740 [SYS:DEBU] Free Heap: 56888 (min=54208) wifi=5 mh=3 cups=0 tc=0
1970-01-01 00:00:11.750 [CUP:INFO] Stopping TC in favor of CUPS
1970-01-01 00:00:11.752 [CUP:INFO] Starting a CUPS session in 0 seconds.
1970-01-01 00:00:11.761 [CUP:INFO] Starting a CUPS session now.
1970-01-01 00:00:11.765 [CUP:INFO] Connecting to CUPS ... https://rjs.sm.tc:9191 (try #1)
1970-01-01 00:00:11.777 [any:INFO] /s2/cups.trust:
cert. version : 1
serial number : 01
issuer name : CN=Root CA, OU=TrackCentral (ez5Cj0eN), O=TrackNet.io, C=CH
subject name : CN=Root CA, OU=TrackCentral (ez5Cj0eN), O=TrackNet.io, C=CH
issued on : 2018-11-22 10:23:38
expires on : 2024-11-20 10:23:38
signed using : ECDSA with SHA256
EC key size : 256 bits
1970-01-01 00:00:11.805 [AIO:INFO] cups has no cert configured - running server auth and client auth with token
1970-01-01 00:00:18.258 [AIO:ERRO] [-1] HTTP connect failed: UNKNOWN ERROR CODE (0052)
1970-01-01 00:00:18.261 [AIO:DEBU] [-1] HTTP connection shutdown...
1970-01-01 00:00:18.273 [CUP:ERRO] CUPS connect failed - URI: https://rjs.sm.tc:9191
1970-01-01 00:00:18.276 [SYS:INFO] sys_inState - Ignoring state transition: 5
1970-01-01 00:00:18.278 [SYS:DEBU] Free Heap: 57040 (min=39056) wifi=5 mh=7 cups=-1 tc=0
1970-01-01 00:00:18.285 [CUP:INFO] Interaction with CUPS failed - retrying in 1m
1970-01-01 00:00:18.292 [TCE:INFO] Starting TC engine
1970-01-01 00:00:18.299 [TCE:ERRO] No TC URI configured
1970-01-01 00:00:18.310 [TCE:INFO] Router rejected or retry limit reached. Invoking CUPS.
1970-01-01 00:00:18.312 [TCE:INFO] Terminating TC engine
1970-01-01 00:00:18.315 [CUP:INFO] Stopping TC in favor of CUPS
1970-01-01 00:00:18.321 [CUP:INFO] Starting a CUPS session in 60 seconds.
1970-01-01 00:00:23.285 [SYS:DEBU] Free Heap: 51712 (min=39056) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:00:28.288 [SYS:DEBU] Free Heap: 51712 (min=39056) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:00:33.291 [SYS:DEBU] Free Heap: 51712 (min=39056) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:00:38.294 [SYS:DEBU] Free Heap: 51712 (min=39056) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:00:43.297 [SYS:DEBU] Free Heap: 51712 (min=39056) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:00:48.299 [SYS:DEBU] Free Heap: 51712 (min=39056) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:00:53.302 [SYS:DEBU] Free Heap: 51712 (min=39056) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:00:58.305 [SYS:DEBU] Free Heap: 51712 (min=39056) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:01:03.307 [SYS:DEBU] Free Heap: 51712 (min=39056) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:01:08.310 [SYS:DEBU] Free Heap: 51712 (min=39056) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:01:13.313 [SYS:DEBU] Free Heap: 51712 (min=39056) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:01:18.315 [SYS:DEBU] Free Heap: 51712 (min=39056) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:01:18.335 [CUP:INFO] Starting a CUPS session now.
1970-01-01 00:01:18.338 [CUP:INFO] Connecting to CUPS ... https://rjs.sm.tc:9191 (try #2)
1970-01-01 00:01:18.350 [any:INFO] /s2/cups.trust:
cert. version : 1
serial number : 01
1970-01-01 00:01:18.378 [AIO:INFO] cups has no cert configured - running server auth and client auth with token
1970-01-01 00:01:25.254 [AIO:DEBU] [-1] HTTP connection shutdown...
1970-01-01 00:01:25.262 [CUP:ERRO] CUPS connect failed - URI: https://rjs.sm.tc:9191
1970-01-01 00:01:25.264 [SYS:INFO] sys_inState - Ignoring state transition: 5
1970-01-01 00:01:25.269 [SYS:DEBU] Free Heap: 56848 (min=38856) wifi=5 mh=7 cups=-1 tc=-2
1970-01-01 00:01:25.277 [CUP:INFO] Interaction with CUPS failed - retrying in 1m
1970-01-01 00:01:25.284 [TCE:INFO] Starting TC engine
1970-01-01 00:01:25.290 [TCE:ERRO] No TC URI configured
1970-01-01 00:01:25.301 [TCE:INFO] Router rejected or retry limit reached. Invoking CUPS.
1970-01-01 00:01:25.304 [TCE:INFO] Terminating TC engine
1970-01-01 00:01:25.307 [CUP:INFO] Stopping TC in favor of CUPS
1970-01-01 00:01:25.312 [CUP:INFO] Starting a CUPS session in 60 seconds.
1970-01-01 00:01:30.277 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:01:35.280 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:01:40.282 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:01:45.285 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:01:50.288 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:01:55.291 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:02:00.293 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:02:05.296 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:02:10.299 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:02:15.301 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:02:20.304 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:02:25.307 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:02:25.327 [CUP:INFO] Starting a CUPS session now.
1970-01-01 00:02:25.330 [CUP:INFO] Connecting to CUPS ... https://rjs.sm.tc:9191 (try #3)
1970-01-01 00:02:25.342 [any:INFO] /s2/cups.trust:
cert. version : 1
serial number : 01
1970-01-01 00:02:25.370 [AIO:INFO] cups has no cert configured - running server auth and client auth with token
1970-01-01 00:02:32.251 [AIO:ERRO] [-1] HTTP connect failed: UNKNOWN ERROR CODE (0052)
1970-01-01 00:02:32.254 [AIO:DEBU] [-1] HTTP connection shutdown...
1970-01-01 00:02:32.262 [CUP:ERRO] CUPS connect failed - URI: https://rjs.sm.tc:9191
1970-01-01 00:02:32.264 [SYS:INFO] sys_inState - Ignoring state transition: 5
1970-01-01 00:02:32.269 [SYS:DEBU] Free Heap: 56848 (min=38856) wifi=5 mh=7 cups=-1 tc=-2
1970-01-01 00:02:32.277 [CUP:INFO] Interaction with CUPS failed - retrying in 1m
1970-01-01 00:02:32.284 [TCE:INFO] Starting TC engine
1970-01-01 00:02:32.290 [TCE:ERRO] No TC URI configured
1970-01-01 00:02:32.301 [TCE:INFO] Router rejected or retry limit reached. Invoking CUPS.
1970-01-01 00:02:32.304 [TCE:INFO] Terminating TC engine
1970-01-01 00:02:32.307 [CUP:INFO] Stopping TC in favor of CUPS
1970-01-01 00:02:32.312 [CUP:INFO] Starting a CUPS session in 60 seconds.
1970-01-01 00:02:37.277 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:02:42.280 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:02:47.282 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
1970-01-01 00:02:52.285 [SYS:DEBU] Free Heap: 51712 (min=38856) wifi=5 mh=7 cups=0 tc=-2
