Within the last 6 days there was only one outage on my “critical TTIG” (maybe it lost WLAN Connection) lasting some hours. Your latest update seems a big improvement. Is the Update in the US West cluster ok ? When will it be implemented in the EU Cluster ?
Yes @KrishnaIyerEaswaran2, it works fine now.
But still missing the TTNmapper integration (read: not shown on the map with use of the app)
Yes, location is set correctly and visible for the public
After i noticed the new firmware rollout post here, today i reinstalled my TTIG.
Now it delivers time of day in metadata, great!
But: it’s about 1 second late, compared to my MatchX1701 gateway which uses GPS time.
Or the MatchX1701 is wrong?
Need to analyze this further. Will keep you posted here.
‘GPS Time’ is normally understood to be the time at the beginning of 1980. Since then there has been 18 leap seconds added, so there is now an 18 second difference between the time the GPS network uses as a base and UTC time.
I suspect what you mean is ‘time obtained from a GPS’. The time taken from the GPS (and then used by the gateway) can be different from UTC time.
Its often assumed GPSs put out UTC time, this is not always the case.
I know all that, but it does not explain why we see a difference of around 1 second here.
The MatchX gateway uses time obtained from gps for feeding the PPS input line of Semtech’s concentrator chip. The packet concentrator code (Semtech) draws absolute time from NMEA sentences of same gps signal. For me it looks like this code has a bug: if NMEA record arrives near top of second, it is intepreted with the next pps pulse, instead with previous. This makes the absolute time advance by 1 second.
If this is the root cause here, the “new” TTIG time will probably be correct.
I don’t think it was new firmware, but these were changes in the backend instead (like maybe the bridge sitting between the TTIG and V2, or between V3 and V2). Given that, even though the TTIG indeed knows time, maybe the time in the meta data is added at some later stage. I guess that’s unlikely though, if only as for large latency then even for perfect clocks that would yield a time that is in advance rather than late.
If one wants to know, maybe one can compare UART logging to the values in the meta data.
If at powerup\startup the Gateway waits for the GPS (which has also just powered up) to get a fix or the time and then updates its internals with that time and then uses the PPS to increment that time; then the time the gateway uses could indeed be out by a second or more.
If however the extraction of the time from the GPS NMEA data is a continuous process (rather than just at startup) then after at most 12.5 minutes of good reception the GPS ought to be putting out the time that is equivalent of UTC.
But at least the coders at Semtech/Cycleo were aware of that:
And each time an NAV-TIMEGPS UBX message has been received:
get the concentrator timestamp (using lgw_get_trigcnt, mutex needed to protect access to the concentrator)
get the GPS time contained in the UBX message (using lgw_gps_get)
call the lgw_gps_sync function (use mutex to protect the time reference that should be a global shared variable).
Then, in other threads, you can simply used that continuously adjusted time reference to convert internal timestamps to GPS time (using lgw_cnt2gps) or the other way around (using lgw_gps2cnt). Inernal concentrator timestamp can also be converted to/from UTC time using lgw_cnt2utc/lgw_utc2cnt functions.
So, does the TTIG UART log for an uplink show (almost) the same time as the meta data?
(Again, I’d also assume that the TTIG includes that time in its Basic Station uplink message, though I now see that such is actually not too clear from the specification? It might be easy to validate by comparing the UART log to the meta data, if you want to know.)
I’d say simply pick a few random uplinks from the UART log, and manually compare to the time in their meta data in TTN Console?
That’s not realtime, indeed. Also, I don’t know what the TTIG logs for an uplink. And all only matters if you want to know what’s the origin of the time in the TTIG’s meta data. Maybe @KrishnaIyerEaswaran2 can also simply tell you.
Not sure what problem this actually creates for you? If a gateway is equipped with GPS module, you typically can obtain GPS timestamp for a packet. And if there’s no GPS module, you hardly can get a precise enough timestamp.
