Awesome!
With real data!!!
Very nice work !
Last monday we mounted the DYI gateway on the tower . To get power on it, we installed a PoE adapter to the Raspberry PI. The antenna is a simple copper wire J-pole. The pictures are below.
In the initial tests the signal reached 2.42 km NLOS, with a little 1/4 wave antenna.
Márcio
Olá Marcio, poderia entrar em contato para tirar umas duvidas, estou montando meu Gateway aqui em SP Butantã. Obrigado
Hello Xandcapcom
Yes, you can post your questions here in this topic. There are here in the TTN a lot information about gateways and ckeck the tab “labs” in the main page.
Our member, Diego Antunes just installed the 4th gateway in the #TheThingsNetworkCWB community !
Hi Marcio! I see you connected your RPi to the LoRa gateway with jumpers instead of with an adapter board. Has it worked ininterruptedly since you installed it? Are you using a POE as a power supply?
Hello Thayuriko,
Yes, I connected the RPi using jumper wires and (fortunately) it is working flawlessly since the installation. I know, it’s not the best thing to do, but I don’t have the adapter board.
I found the PoE kit (injector + splitter) for RPi on Aliexpress for about US$ 13.
Márcio
Olá Marcio,
Gostaria de lançar um gateway em Belo Horizonte. Consigo encontrar em algum lugar as informações sobre o setup que vocês utilizaraam em Curitiba?
Hello Prates
The setup is very basic, with a Raspberry Pi 3, a Risinghf SX1301 board and a Power over Ethernet (PoE) adapter. You can buy the kit from Welington (wdesan), a TTN Curitiba member, who has a store in Curitiba, or from a seller from Aliexpress who sells RAK831 kits for 915 MHz.
Márcio
Hello! I just deployed a gateway here in Curitiba!
Regards,
Vinicius
Great News!
I think it’s time for a TTN Curitiba Community meeting, isn’t it?
I can help with hosting / logistics
Our first Meetup will happen on Dec 5th. More details on https://www.meetup.com/capivara-coders/events/256914152/
Countdown! 19…18…
… 17
One of the 800 TIG (Oprah Gateway) is here:
help_to_unleash–
vamos !
Boa tarde Pessoal!
Me chamo Pedro, estou estudando IOT a pouco tempo, desta forma tomei conhecimento do projeto TTN recentemente. Achei super legal toda a colaboração da comunidade para expansão deste ecossistema e com isso, trouxe este case para apreciação da diretoria da empresa onde trabalho. Como resultado desta conversa, consegui negociar a instalação de um Gateway na região do Centro Cívico (com a possibilidade de expandir isso, alcançando resultados positivos) para realizarmos alguns estudos e contribuirmos para a expansão deste projeto, desta forma, agora é hora de colocar a mão na massa! Para que isso aconteça de forma mais fluida, gostaria de saber se algum administrador de Gateway aqui de Curitiba não teria a disponibilidade de trocar algumas informações sobre instalação e sustentação desta infraestrutura. Podemos conversar por Skype, telefone, ou até mesmo posso me deslocar até o local de vocês. Este apoio com toda a certeza agilizaria muito esta nossa empreita.
Meus contatos:
Desde já agradeço a atenção de todos.
att.
Pedro Nascimento.
desculpe Pedro apenas inglês
Hi Pedro! Welcome to TTN Curitiba! Let’s get visibility and connect more and more things!!
