By mistake (sort of) I’ve deleted my application in which I had 10 devices activated. I’ve created a new application under a new name. I then activated all the devices in that new application. This worked great for 8 out of 10 devices. For the other two I get the following error:
When using the CLI it returns the following error:
INFO Using Application AppEUI=0059AC00000FFFFF AppID=binella_as2
INFO Discovering Handler... Handler=meshed-handler
INFO Connecting with Handler... Handler=thethings.meshed.com.au:1904
FATAL Could not register Device error=Could not set device on Handler: permission denied: Broker did not set device: permission denied: NetworkServer did not set device: permission denied: No "devices" rights to Application "binella_as" source=Wrap: /builds/thethingsnetwork/ttn/utils/errors/errors.go:249
The devices that I’m trying to add have the following dev_eui:
- 4e084b97b997d5bd
- bab88701cbd87ed3
It appear as if my devices (or the old application) still exists somewhere and I can no longer make any modifications to it. Maybe someone from TTN can have a look at this?
Thank you!
