FRAM will be your friend here
FRAM is one of the non-volatile memory types I want to be able to use it with.
@bluejedi I agree that the save should be made in lmic library, and should adapt to different kind of storage. Maybe it can be made by a function which call a callback in user program to save on or more block of byte.
To be generic I think that all the value modified by OTAA join response and by mac command should be save.
It includes, session keys but also RX2 configuration, channels configuration, current datarate, … (like describe in the link put by @arjanvanb)
But for the state to be correct the time must also be correct (for globalDutyavail and Band.avail for global and band duty rate) or maybe you can ignore theses values if you sleep long enough (maybe more than 3 hours, I did not do the exact calculation).
While a callback is a nice option I think it is not required here and possibly makes things more complex / dependent / slower.
Time is a good point. Many/most nodes will not have a realtime clock nor can they access a (NTP) time server, so I’m curious how the time issue might be solved or (reliably) worked around in this case.
Maybe @htdvisser has some ideas for this.
As an aside, I once noticed the following:
In case of an ESP32, the RTC keeps running in deep sleep, so I guess time is not an issue here, or did i misunderstood the issue?
I think you are correct. Preserving ‘time’ is probably not an issue there, only when the ESP32 is powered off.
…or does it
Yes, you opened a can of worms, don’t be alarmed
Or you can sleep more than 7FFFFFFF ostick => 9h32min and even with rtc clock in hal_ticks you will have some problem (US_PER_OSTICK_EXPONENT = 4).
Again, that is only valid for AVR micro’s, not for the ESPx.
Right, this is a generic LMIC thread, not an ESP one…
Low-power and sleep are so essential that it should just work and be simple.
Yes, and it seems that this combination is the best kept secret
Is this solution still state-of-the-art, using it with MCCI LMIC? Or is there a better piece of code for the task of storing/restoring LMIC state while sleeping on ESP32?
/cc @grazy
In V3 OTAA is the preferred method to join LoRaWAN network.
It is now a good opportunity to switch my devices from ABP to OTAA.
That’s why I would like to know what is required to restore a session after power down the device.
In the end, was there a solution for MCCI LMIC and, for example, an ATmega328P?
MCCI LMIC (and the older classic) show the keys returned when a join request is completed, those need preserving along with the frame count.
It is quite rare for anyone to power down their nodes - particularly on the lightweight AVRs which don’t consume much current at all in sleep mode - so I’m not aware of any implementations but it’s easy enough to code using the built-in flash.
You only need to store the keys each time you get a join accept event - but the frame counter will need storing before power down.
You need to store a bit more, channel definitions provided in the join accept come to mind, RX1 offset, ADR results (power and data rate), DevNonces used for join. There is probably more…
It would be easier to just use a incrementing DevNonce and only save that value and rejoin on reset. Be aware that limits the number of resets to just 65535 times before you need to re-add the device in TTN to generate a fresh set of ‘credentials’.
Thanks for the answers but it is hard to follow the best practices guidelines which says, for example:
“A device should keep the result of an activation in permanent storage
if the device is expected to be power-cycled during its lifetime.”
when the required information is not available or difficult to obtain to implement them.
For a “normal” user, this makes creating a device a trial and error process.
There should be a simple guide where it is described what to save, as always it doesn’t seem easy.
I agree that good and complete documentation with clear steps and practical guidance for this is still missing.
If that would be available with clear working examples (if even in pseudo code) it would be much easier to create fully compliant devices.
Why isn’t something like that still not available after many years? Conlicting commercial interests?
“Normal” users seem to enjoy that sort of thing.
The consensus is that a small device is going to be on all the time, even if it’s in deep sleep, so the code to save the settings is of academic interest. The ESP32 does have code for that because it’s version of deep sleep doesn’t include power to memory.
The only time someone wants to turn off the element that has the settings in is when they have something else that is controlling time - which again is a bit redundant given the very low current levels of many of the appropriate MCU’s in deep sleep mode. In fact it’s got to a point where you can tell if you have succeeded because either your multimeter shows some current draw or it appears to be off - as 0.7µA is usually a bit too low for the average meter to accurately measure.
