Which gateway sends a downlink?
I’m testing the “test mode” with port 224 and activation of the test mode is sometimes difficult for unkown reasons. What I saw however is that when the uplink is seen by multiple gateways it does not work as well as when the uplink packet is only seen by a gatway close by.
My questions:
  • which gateway from all the gateways that receive an uplink sends the downlink?
  • what could be possible causes that my downlink packet does not arrive?
Note:
gateway 1 to node = 5 m (indoor)
gateway 2 to node = 50m (indoor)
gateway 3 to node = >1km ??
Thank you for your support
Regards
Lukas
See “Downlink Configuration (Router)” on https://www.thethingsnetwork.org/docs/network/architecture.html#downlink-configuration-router and the source code for its implementation and its usage.
A post was merged into an existing topic: Is using port 224 in some “test mode” LoRaWAN compliant?
