Note that this has been fixed now.
A similar error was presented after callaboratorās permissions were changed (even when given more permissions). If a collaborator then opened such application (or gateway) a similar error like above was presented and accessing the application (or gateway) was prohibited.
Has this issue also been fixed already?
I can confirm that the error is still there.
Error:
If the error persists after refreshing, please contact an administrator
Without any information on what you were doing at that time the message came up, there is nothing to act upon.
Iām getting:
An unknown error occurred
when iām trying to access specific devices, either by clicking on it through the end device list, or just by putting the name in the url.
Refreshing, closing and opening the browser does not remove the error.
The error has been there since 11 maybe longer, and it is still there.
I believe this is a different error. You say itās just specific devices. Any idea what could be particularly different about them?
Iām not aware of such error and was not immediately able to reproduce. Can you provide some more concrete reproduction steps (e.g. what rights were exactly set/unset)?
I would have to test it again and write down all steps.
Two months ago I wanted to use a ācollaboratorā account for demonstrations during a presentation, but during the preparations I ran into the mentioned problems in more than one sitiation.
Iāll see if I can do some tests again soon. I will open an issue if the problem is still present.
they have worked fine before, but i can report that i have 20+ end devices where i get:
I have 20+ devices where i get when i try to view them.
it also occurs when going through the end devise list.
It has worked fine before, I started to get the problem Tuesday (25/05/2021) morning.
Please do not open a new topic on the same subject.
Please do not repeat the exact same detail - it has the reverse effect to highlighting the issue.
TTI devs write code most of the time and occasionally check in here, so itās just us volunteers on here the rest of the time.
The two appropriate places for formal support are the #ops channel on Slack or post a GitHub issue.
One other option is Support
I am experiencing the exact same problem. It seems to be browser related. The error occurs on Chrome but not on firefoxā¦
Canāt access apps or gatewaysā¦ on chrome
I am experiencing the same error -
End Devices are working fine when created through the console directly.
The error occurs when creating the end devices using either the CLI and or the API. Iām currently working on automating bulk enrollment of devices (100+). Although I am testing the process with only a single device.
When using the API, I am posting the following to /api/v3/applications/{my_app_id}/devices endpoint and I get status 200. I am also posting the same to the endpoints for the JS, NS and AS Reg.s - also status 200.
"end_device": {
"ids": {
"device_id": "lt-100e-1062375d",
"application_ids": {
"application_id": "globalsat100"
"dev_eui": "000DB5351062375D",
"join_eui": "70B3D57ED00200A7"
"name": "LT-100E-1062375D",
"description": "LT-100E-1062375Dadded using TTN Enroller",
"network_server_address": "eu1.cloud.thethings.network",
"application_server_address": "eu1.cloud.thethings.network",
"join_server_address": "eu1.cloud.thethings.network",
"root_keys": {
"app_key": {
"key": "78FA7A693AC10421E3C267E6F93572A0"
When viewed in web consoleās end device list, they are displayed properly, but when trying to view the specific end device I get the error.
The same happens when I try creating the device using the TTN CLI integrated into my own CLI - status 200, device returned, showing in TTN console, but error when trying to access its page.
Code snippet from own CLI that uses:
ttn-lw-cli end-devices create [application-id] [device-id] [flags]
foreach (var endDevice in endDevices)
process.StartInfo.Arguments = $"/C ttn-lw-cli end-devices " +
$"create {endDevice.ids.application_ids.application_id} {endDevice.ids.device_id} " +
$"--dev-eui {endDevice.ids.dev_eui} " +
$"--join-eui {endDevice.ids.join_eui} ";
process.Start();
string output = process.StandardOutput.ReadToEnd();
process.WaitForExit();
Console.WriteLine(output);
I am clearly missing something since I get status 200 on creation but error on web console - although I cannot solve this oneā¦
If anyone here can pin-point my mistake or point me in a better direction for csv bulk enrollment of 100+ devices then thanks in advance!
Sincerely,
I would expect device creation to require a lot more information like frequency plan, LoRaWAN version and regional parameter versions.
Have you added a device using the console and checked the developer (F12) mode of the browser? It uses the API so you can check all the calls with all arguments.
@kersing You are correct, I was missing a few fields. I have now matched the API calls that are made on the web console. This has, however, not solved the problem.
Inspecting the data returned when trying to fetch a device, I found that the AppKey is missing, though this is added in exactly the same way as when creating a device through the console.
Iāll look more into this and hopefully find a solution, which I can share here in case someone else experiences a similar problem-if anyone has already experienced this and found a solution, feel free to share.
Hi All,
Very long post cut short(er):
I was writing the details as I had the exact same issue as @tobiasfg + some more (couldnāt manually specify the app-key).
The solution was to move from ttn-lw-cli v3.19.1 to v3.20.0 and everything started working, where the same command with 3.19.1 would not (either because attempting to set the app-key manually and that reported an error, or successfully creating the end-device but the web console would report an error)
Hereās what Iām now using successfully:
./ttn-lw-cli \
end-devices add \
--application-id ${APP_ID} \
--device-id ${DEV_ID} \
--dev-eui ${DEV_EUI} \
--join-eui ${APP_EUI} \
--root-keys.app-key.key "${TEST_KEY}" \
--frequency-plan-id ${FPLAN} \
--lorawan-phy-version ${MAC_VER} \
--lorawan-version ${LW_VER} \
--supports-join
What I learned:
- update to 3.20.0 fixes all the issues for me, but do not use
--provisioner_id
- Command line parameters are not fully checked client side with 3.19.1
Good luck!
W.
As this thread was actually about a console error that tells you what to do to fix it which happens often enough and largely fixes itself but if you do the instructions, does fix itself, and is not related to the CLI, closing before we accumulate any more red-herrings.
