yes , I have 2 possibillities, the Maynuo M9812 electronic load and the Turnigy Accucell 6
The Maynuo have a special battery testfunction and can, when connected to PC spit out information/graphs
You set the end voltage (normal between 2.75 and 3.2 V depends on the buildin protection circuit/datasheet)
and you set the discharge current (between 0.2 and 1 C)
then push start and go do the dishes/do some shopping and when reached the end voltage it stops discharging and give you the mAh.
what I really need is a logging power toolā¦ like Ladyada have been busy finding a diy solution
I have a clone I think, anyway, if you connect them with an old PC powersupply you can do many things.
a very nice menu option is āstorage modeā, the charger checks the lipo and if its full it start discharging to 70%, if its empty it starts charging to 70%.
one thing you must watch:
If you set it to LiPo discharge, it stops (preprogrammed) @ 3.2 V
What I do, i discharge LiPo with NimH selected , there I can set amps and voltage, so I set that to 2.8 V, then I know its really empty.
Then I set it back to LiPo and charge (it stops preprogrammed @ 4.2 v and when the current is < 0.01 A
Now you can read on the display the real capacity.
To spare your batteryās discharge @ 0.2 C and wait 10 minutes between discharging and charging.
Iām experimenting with a solar panel & supercaps.
The start looks promissing, but the main challenge is the power consumption of the LoraWan communication with the 3.3V RN2483.
The delay of the gateways is a problem for me because I live in the center of large white spot on the map in the Netherlands without existing coverage from TTN gateways. But better to wait and receive a solid product.
In case you want to check or add some suggestions, the URL is:
Still no sun today
Iām also curious how it is going to perform.
In case I need more current it is also possible to use multiple series banks in parallel but then it becomes more complex with balancing resistors in the supercap bank.
Today I tested a RN2483 for connectivity to ensure that is works, and it did! Still had to use the KPN LoraWAN network because there is no TTN gateway in range of my house. I used a terminal session and AT commands to insert the necessary config settings and saved in to the EEPROM of the RN2483. This simplifies the sketch on the Atmega328P.
Three challenges that Iām struggling with:
my 3.3V 8MHz breadboard Atmega328P can only be programmed with ArduinoISP programmer on 3.3V, I donāt have a working serial interface with my computer, think itās the reset pin that is blocking
Autobaud of the RN2483 isnāt working and 57K speed is too high for soft serial of 8MHz MCU
I thought my situation would be simple and easy because my board is already 3.3V so no level shifter needed to the RN2483 and ISP programmer use had benefit that UART is unused so available for the communication with the RN2483 but Serial.print didnāt work or is this logical?
And donāt know the person you mentioned but every help is welcome.
Looks impressive!
It should be could to first really fully charge them and leave them for a day.
With your 5.5V caps in parallel you donāt need such a balancing system if I correctly understood.
I have similar caps like you ordered but one small disadvantage is that they are not breadboard friendly to experiment with. That is way I now use other ones.
for those of you with more electrical engineering experience, would a goldcap or a super capacitor be a good choice to power a LoPy in the field, if it gets additionally supported by a solar cell?
Just thinking about what is better in terms of long liveā¦
The LoPy is only an example. Itās more about the type or class of device (low power device) and the powering options for really long periods without having to worry about charging cycles of a normal rechargeable battery.
Iām no electronics expert but would suggest a lower voltage solar panel and look for the amount of current it can supply under normal conditions.
If you standardize for lower voltage mcu & lora module like 3.3v and use simple components to lower voltage like a LDO than avoid a 12V panel because the voltage difference is largely wasted as heat.
If Iām correct then gold-cap is a brand name that also supplies supercaps.
Knowing if it fits depends on usage & sleep scenario, energy consumption of mcu & lora module, etc. This determines the needs for power supply.
Iām expertimenting & learning with something similar, project is now āon holdā till some components (328PB and RN2483A) arrive in June.
@lollisoft In normal situations youāll not have to worry about wearing out your battery, either LiPo or NiMH.
Iāve been running small solar powered NiMH projects for many years and the cells are still in excellent condition. The main issue is surviving the dark winter months (december and january). A Super capacitor has in many situations insufficient capacity for these dark months.
You could use a very large panel so that it would fully charge the supercap even on a very dark overcast winter day. That would work and would get you through the night, but the solar panel and super cap size and costs are probably much higher than a smaller solar cell combined with (a) chemical rechargeable cell(s).
You should look at LiFePo4 batteries - they are far easier to use and harder to destroy that either LiPo or NiMH. They are so safe compared to a LiPo to make LiPo look like an explosive.
I have only very respect after seeing some burned lipos (on youtube). They tried to kill them, but after the smartphone battery issues with samsung, I try to keep at least my quadcopter lipos in the basement.
And I got one copter killed by a shortage after a crash (burned down a connector) and I had to run stopping the fire!
If super caps are inpractical, then I opt in for a NiMH or two. They are not as dangerous in my mind as lipos
