Hacking a smoke detector : https://www.b4x.com/android/forum/threads/jg-iot-alarm-or-the-power-of-firebase.70210/#post-502192
I have also hacked a simple €10 hardware store smoke alarm with an ESP8266 to protect my home. I have CCTV, Wireless Switch and all the POE power and data for my TTN Gateway in the attic space. A fire could destroy the roof structure here before we would be aware so I built this.
There is a pin on the control IC of most smoke detectors to allow sympathetic alarming (such as in shared spaces of an apartment complex). I used this pin of the IC to drive the enable input of a mini buck converter which then generates the 3.3volt supply for an ESP01 module.
The ESP01 module boots, uses a static IP address to connect to my home router and pushes a message to our mobiles and Chrome extensions via Pushbullet. Total time from alarm to phone is circa 3-6 seconds and is 100% reliable so far in testing.
There is absolutely no technical reason why this could not be LoRaWAN. I chose the WiFi as it is slightly more persistent and to push a message involves less routing (fewer possible flaws in an already NOT fail-safe system).
The quiescent current (we love this number here!!!) of this system is only that of the detector circuit as the WiFi module is off unless the alarm is triggered.
I just started to test this camera and it works nice. But the output is like this:
[22.00, 23.00, 22.00, 22.25, 22.50, 23.25, 27.00, 26.00,
21.75, 22.00, 22.50, 22.25, 22.00, 23.00, 24.50, 25.75,
22.25, 23.50, 24.25, 22.00, 22.00, 22.75, 22.25, 24.50,
22.25, 22.25, 22.25, 22.25, 22.25, 21.50, 22.50, 23.25,
26.00, 21.75, 22.00, 22.25, 22.50, 22.75, 23.00, 25.25,
22.75, 22.25, 22.25, 22.25, 23.25, 23.25, 22.75, 25.75,
22.00, 22.25, 22.25, 22.50, 23.50, 23.50, 24.25, 25.75,
21.00, 21.25, 22.25, 22.75, 25.50, 25.00, 26.50, 28.50,
is that not too much data for sending to a gateway?
is water wet ?
do you really need that resolution transmitted…
this is the output from the demo sketch. it is my idea to use it to measure the plant temperature: detection of diseases, Etc. I have to think about it: maybe I can detect the temperature deviation for some of the pixels to generate an alert (flag =1 or 0). thanks water is wet but ice?
No and no.
Wet: Cover, touch or soak with liquid.
Water as a liquid can make objects wet but it is not wet itself, neither is ice.
When something wet becomes frozen, the water will become ice.
Ice is not a liquid, so when the water freezes to ice that object state should not be called wet.
However, ice covered with (unfrozen) water is wet, and so is ice covered with alcohol.
So is ice wet? It depends, but at least it can be wet (water cannot).
Okay , thanks. back to my subject. I am playing with the thermal camera AMG8833. The simple sketch produces an array of 64 (8*8) datapoints. It was my idea to calculate an average and send that with a node, but I am not an arduino expert. Has anybody made already such a sketch to send data to a TTN gateway?
maybe its an idea to open a separate topic for that ?
I have seen the libs, think you need a bit of 'local processing ‘power’
This Walabot Starter version uses a three-antenna array to illuminate the area in front of it and sense the returning signals. The signals are produced and recorded by a VYYR2401 A3 System-on-Chip integrated circuit. They are then communicated to a host device (like your phone or computer) using a USB interface, which is implemented using a Cypress controller.
Soil sensor. Since a couple of weeks i work with the Soilwatch10 ( 3V) in combination with the Dragino mini dev. I made calibration ( With the WET sensor) for the volume soil moisture.
I did the search for you
maybe you want to write a story how to use and what your experiences are ?
I made bad experience with such a moisture sensor from Tindie.
The weak points of these are, that the SMALL side of the board is not sealed and it gets whet under the lackage and it blisters off (in my case after some month!)
Very sad, that the seller take no notice of the problem, nor action to replace it.
So you have to seal it with “tropenlack” to make shure it’s prepared for a long life.
good results with this kind of sensor right now
Those small soil sensors are pretty poor and only an indication that the soil is wet or dry and wont last very long. To do any serious long term soil moisture monitoring at any depth then you’d need to look at professional sensors from Irrometer, Sentek and others.
They may not be budget sensors, but you get what you pay for,
Andrew
Hello
At this moment i found this :
PiGI goes TTN - IoT Radiation Monitoring
At this point, 12 PiGI - Raspberry Pi Geiger-Müller Interface nodes are in active deployment at TDRM, helping to monitor the environment independently and so far reliably. Additional 12 nodes are on the current roadmap. That is a great success story and just in the spirit of the idea, development and open-source model of it.
Now the TDRM Working Group at Karel-de-Grote Hogeschool, Campus Hoboken in Antwerp pushed it even further and developed a LoRaWan based TTN (The Things Network) Adapter for the PiGI, to have it connected to the Internet of Things.
https://apollo.open-resource.org/mission:log:2018:03:12:pigi-goes-ttn-iot-radiation-monitoring
open source … open ideas , I like it
ML8511 sensor breakout is an easy to use ultraviolet light sensor
- https://learn.sparkfun.com/tutorials/ml8511-uv-sensor-hookup-guide
- https://github.com/sparkfun/ML8511_Breakout
- https://www.mcs.anl.gov/research/projects/waggle/downloads/datasheets/lightsense/ml8511.pdf
- https://plot.ly/arduino/uv-sensor-tutorial/
- https://www.ebay.com/itm/ML8511-UVB-UV-Rays-Sensor-Breakout-UV-Light-Sensor-Analog-Output-for-Arduino/400936528899
- https://www.vanallesenmeer.nl/UV-Sensor-Breakout-ML8511-Sparkfun-12705
Micro LiDAR Module measuring the distance to an object as close as 30 centimeters and as far as 12 meters
