I confirm the issue having nothing fiddled on my (RAK2245) installation working flawless since months.
Browser failure message when trying to access the web console: “502 Bad Gateway” nginx
Checked via ttnmapper.org: according to “Last heard at 2020-05-18T02:02:37.000Z, Channels heard on: 8” my gateway itself is working as expected.
It seems to be an issue when trying to access the gateway configuration and status pages on the TTN webserver - maybe an user database handling/referencing failure or “console.thethingsnetwork.org” is simply down.
I might have it overlooked but is there a possibility to address incidents to a tracking system outside this forum?
The 502 Bad Gateway is still the same today it seems for the Netherlands.
Have checked using different computers and browsers on 2 different networks, but still can’t access the Console pages. Who is responsible for this and how can we reach the responsible people (I am a newbie)
I have just last Saturday setup my (Raspberry / Dragino PG1301 Concentrator) Gateway and wanted to start testing yesterday.
Hi @FlumeLogic, it sounds like your project is serious if something like this is a “showstopper”. Have you done a project risk analysis? Are you sure that it’s right to use a free, no contract, no SLA service in your project? TT people state very clearly “Develop on TTN, Deploy on TTI”. I have followed that advice. I use the TTN community network for development and use a paid, contract, SLA The Things Enterprise Stack Cloud Hosted (TT ES CH) v3 instance for deployment. Works really well. No showstoppers.
As expected, my Kickstarter gateway indeed needed a manual reboot to trigger connecting again. I guess that awaiting the daily firmware upgrade reboot would have worked too.
What gateway is that, and was it even offline? Most were working just fine:
Back for me too, about 30 minutes ago. My node was not joining during the outage, but now it has, and it should be sending data in 15 minute intervals. Thanks all.
Where do TTN say to develop on TTN and run live service in TTI? That’s a sensible approach for business critical applications but I don’t think that it’s clearly stated on the TTN website.
Back also on my side, but the node does not receive join ack, and the gateway says:
May 18 09:40:41 gateway0 ttn-gateway[1317]: ##### END #####
May 18 09:40:41 gateway0 ttn-gateway[1317]: INFO: [down] for server router.eu.thethings.network PULL_ACK received in 69 ms
May 18 09:40:41 gateway0 ttn-gateway[1317]: INFO: [down] for server router.eu.thethings.network PULL_ACK received in 67 ms
May 18 09:40:41 gateway0 ttn-gateway[1317]: INFO: [down] for server router.eu.thethings.network serv_addr[ic]PULL_RESP received :)
May 18 09:40:41 gateway0 ttn-gateway[1317]: INFO: [down] a packet will be sent on timestamp value 1075174492
