I dont think it says the E62 is SX1268 based, make little difference anyway and you still cannot use it for TTN.
why can’t I use it for TTN?
The UART front end does not allow the degree of configuration needed for TTN.
Too slow? The SPI version seems to have faster data rate
Nothing to do with speed.
To work with TTN you require control over LoRa parameters such as bandwidth, spreading factor, code rate, syncword, IQ. You dont have that level of control with the Ebyte UART front end modules.
What bare modules do you suggest to use with a tx power around 1-2W?
No idea, that amount of power is illegal just about everywhere, so there would be no point in buying or getting something that I cannot use.
There is no channel plan in TTN for 433MHz so you wouldn’t be able to use TTN. Also the iC880a is a 868MHz concentrator according to iMST documentation so you are mixing incompatible technologies.
I’m not going into the lorawan compatibility of the modules as that has been discussed already.
Where in the World are you ?
It seems those modules are configurable, take a look at this example
https://github.com/xreef/LoRa_E32_Series_Library/blob/master/examples/setConfiguration/ArduinoSetConfiguration.ino
And where in the documentation does it say the serial modules are configurable for LoRaWAN operation? Because that is what you need for TTN.
But you don’t have to accept our help, feel free to buy the hardware and try for yourself. May-be we’re overlooking something. However if it doesn’t work or you are stuck getting it to work you are on your own as we don’t know how to get it going.
If you are buying, make sure to buy components with matching frequencies. And if you want to use TTN check the available channel plans in the console before deciding on a frequency.
@Anelito I think you will be better off using good antennas and select a high location for your gateway antenna vs using higher power. I only do rural installations, and 10 miles is definitely possible. Using LoRaWAN will avoid issues with "simple " LoRa networks such as collisions and data corruption. Good luck.
As the modules wont work with TTN it makes little difference which antenna you use.
OK so nothing is compatible with TTN, what is then?
Starting cheap from aliexpress/ebay.
Try a search on LoRa 868Mhz.
How do I know if the gateway near me supports 433 or 868 on the TTN map?
Hungary, both 433 and 868 are valid.
Here’s a summary map of Europe with the 433MHz gateways showing:
And here’s the sort-of up to date map of gateways on TTN:
https://www.thethingsnetwork.org/map
and there is TTN Mapper:
Neither of which show the gateway frequency.
Most early gateways were on 868MHz so no one is going to be incentivised to use 433MHz.
Why do you want to use 433?
And as observed above, using 1W output would be illegal in most jurisdictions.
