Which gateways are TDOA compatible with collos?
As far as I know, none of the first gen gateways, even those with GPS, can use the TDOA feature. Is this right?
Hello guys.
One question about Collos location. I already did the regestration and i get tle location of my device (arduino with LoRa Shield). It shows at The Things Network console.
So my question is: Is there any possible ways to export the location (longitude & latitude) and store this two numbers to somewhere? I need these two numbers only. Any hints? Maybe another integration?
I hope guys you can help me beacuse i am really stuck here.
Right, first gen gateways are not able to put TOA, even with a GPS. Every gateway based on Semtech V2 reference design are compatible.
For example Kerlink iBTS or Cisco, but there should be other manufacturers…
If you connect to TTN thanks to MQTT, you will have GPS coordinates in the payload
Thanks for your response.
I did the HTTP integration to my test server and on that server i get payload data with latitude and longitude. But this coordinates are of my gateway not my device.
Did you mean something like that?
I do not understand what exactly you would like to explain to me here
If you are able to get coordinates from TTN, Collos integration is might not be configured properly. Did you follow those steps ?
I think u didn’t get me right or do you know what my question is?. Yeah I followed these steps and integretion is working OK. I get the location with Collos of my device. But now i want to parse these numbers (latitude & longitude) to somewhere (file or something like that). And i dont know how to do that
Is it working or not ? On your previous post you said you only get gateway’s coordinates. So yes, I do not get it
If so what does mean "I did the HTTP integration to my test server and on that server i get payload data with latitude and longitude. " ?
I wrote some thing a little bit confused xD Yes it is working OK. In my console i see the location of my device.
So there is see coordinates of my device shown be side the map. So my main question is how to store or parse or something like that coordinates which are shown be side the map?
I think I should not even mention the HTTP integration because there is no connection here. Let’s just leave that behind.
I really hope that you understand me now?
Seems that some confusion abounds…
What I understand is that
- you see GW coordinates in the uplinks from the GWs
- Collos integration is working and you see the device on the map in the console
- you would now like to subscribe to a feed of the device location directly.
I am not sure if you can/how to do that. But will look into it.
The Collos integration can forward said coordinates formatted as a GPS device to any Cayenne integration that you have though.
Hi Rich,
First of all thanks a lot Rich.
exactly as they mentioned all those things in 1,2,3.
Ok i will try to do Cayenne integration and I hope this will help me.
If you get any other ways to solve this problem can you please let me know?
One more thing Rich.
Can you please explain some things a little bit more to me?
- How TTN and integration with Collos + Cayenne really works ??
Does TTN calls Collos, etc.?
Does TTN calls Cayenne or Collos calls Cayenne?
What kind of data is transmitted, etc.?
And if it would be possible that Http Intgration payload would include (+ GW) DEVICE COORDINATES ?
Thanks a lot.
Only Cayenne?? Or any Webhook? (like IFTTT)
Actually it is pretty simple right now…
TTN receives the uplink from one or more GWs and instead of throwing away duplicates it keeps the meta-data from each one (primarily that is RSSI and SNR plus TOA if it is available).
If you have a payload that included WiFi sniff data for example then a payload script can be used to create the WiFi query format for WiFi base location.
TTN then forms a query with all the meta-data plus andy WiFi data that is available.
The Query is posted to the endpoint in Collos that you specify and Collos responds with a location.
TTN console then looks at the locations coming back and, if there are multiple, it posts the most accurate one to the console location.
The Cayenne integration is pretty dumb- firstly you need to add a Cayenne integration to the app (for the rest of the data such as the payload and signal strength etc.) Secondly, when you define the integration you get the option to specify a Cayenne channel number. It will quite simply, place the location returned from that particular endpoint in Collos to Cayenne to mimic a GPS device on the channel number that you specify in the integration.
I dont think we can specify any other Webhook right now, although… of course… that would be our desire…
@DenisStenkler, @DannyE : once TTN has queried Collos it coordinates in metadata:{latitude, longitude} fields of the payload.
"app_id":"",
"dev_id":"",
"metadata":{
"time":"2018-05-16T17:25:30.632668968Z",
"gateways":[
"latitude":45.184284,
"longitude":5.7182016,
"location_source":"registry"
You can get the payload by MQTT or HTTP, use TTN’s storage or any other integration
Well you guys solved my problem Thanks a lot. Now I see the location in my payload. Thanks again
Thank you @Oliv. Sorry for the delay but I’ve been working on other stuff - now want to finish this up. I ensured the configuration matched yours. I did eventually get the results I expected and you got - the location near Boston corresponding to Skyhook’s test vector. It did not work immediately however - to get the end-to-end location working I had to delete the device in Cayenne and create a new one.
There is some sort of caching going on somewhere in the chain. Now, I have replaced the Skyhook data with real data, that has worked before with Skyhook’s location system. What I’m seeing is that the ‘Metadata’ shown in the Console’s Application Data reports the old Skyhook test data location. See the screen shot below.
Anyways, all I know is that the TTN console still thinks the device is in ‘Needham Heights’. Somebody is caching this old location?
I have a working node with Collos in the backend and it works.Tested the payload decoder with the sample data and also returns valid data.
What I would like to do next is actually upload ssid payload but I am struggling with the the encoding side.
Does anyone have a an example of an arduino sketch that shows that part and is willing to share?
Guys, me again
Having one problem. Can someone explain how does really Collos work beacuse now i am a little bit confused??
My device see only 2 gateways. So Collos returns the location of one of the gateways (the one the device is closer), but not the correct location of my device. So does Collos works on “triangulation” method or how does it work? Where is the problem here?
Thanks a lot.
