Upgraded my DLOS8 gateway and have connected to Basic Station.
I no longer see the status messages every 30 seconds, so hoping it is working correctly as I want the GPS location to populate my gateway automatically.
I believe it is working as I have seen one DevAddr packet hit TTN Console, though I do see odd things, for instance when I save data in basic station I see the following:
The “Finished station” concerns me?
Sat Nov 6 13:59:18 2021 user.notice root: Start station
Sat Nov 6 13:59:24 2021 user.notice iot_keep_alive: Internet Access OK: via 3g-cellular
Sat Nov 6 13:59:24 2021 user.notice iot_keep_alive: XX ping ETH1 139.130.4.5 via eth1 fail
Sat Nov 6 13:59:24 2021 user.notice iot_keep_alive: XX ping WiFi 8.8.4.4 via wlan0-2 fail
Sat Nov 6 13:59:28 2021 daemon.err uhttpd[1362]: Daemon pid=9545 running...
Sat Nov 6 13:59:28 2021 user.notice root: Finished station
I’m a novice on this stuff so I’m trying anything I can think of. I noticed this:
In TTN V3 console, the global_conf.json that can be downloaded has server address as “au1.cloud.thethings.network” . However if I use WinSCP to look at the global_conf.json on the gateway in /etc/lora, it lists the server as “router.au.thethings.network”. If I edit the file directly on the gateway and reboot, it just seems to overwrite the file with the original setting.
That doesn’t seem to have anything to do with the packet forwarder not starting though?
Maybe this hint can help you:
“Please note, the global_conf.json file will be overwrite by the match region files in /etc/lora/cfg-30x when change settings in the web. So user need to change the files in /etc/lora/cfg-cfg-30x instead of global_conf.json”
It’s from wiki.dragino.com
Today I installed the latest firmware on one of my LIG16s and startet BasicsStation. The data-packages are transferred to TTS-CE and the applications.
But: The Home-screen of the LIG16 shows the status of AWS-IoT Core Station service (Station is not running) and “Gateway-traffic” is still empty.
So back to Semtech UDP.
Hi Wolfgang, Thanks for taking the time to look into this, much appreciated! Dragino think that my hardware might be faulty, so I’ll park this up until I can get a replacement gateway…
Many thanks to all those that have tied to help
Got mine on Basic station but GPS just doesn’t work; support haven’t been helpful as yet.
I used minicom to connect to ttyGPS and can see the GPS data so I know its there;
but in TTN Console I dont get any antenna_locations at all
Dragino have helped to further troubleshoot my LPS8 problem and it seems to be a hardware problem (at least that’s what I understand - related to the the “failed to start concentrator” message I was getting. My new LPS8 is now working fine.
Just to confirm the latest firmware update for the LPS8 (lgw-5.4.1640315898 dated 24 Dec 2021) does not fix these issues. When configured as TTN Basic Station:
the ‘LoRa log’ page does not show any Logreads, all empty
the ‘Gateway Traffic’ page shows an empty graph
the ‘System Log’ page shows LoRa log under section ‘Previous Log: station’, with many ‘Time sync rejected’ messages
However, the TTN console is showing my gateway is active, and i get 0% packet loss so it seems to be working just fine for the moment.
I upgraded my firmware (not preserving any settings) because with version 4-Nov-2021 my gateway crashed every other day; i hope the latest version fixes this.
In my case i am back on November firmware - because the December version caused a lot of disconnections from internet. With both versions Basic station is not sending the status data every 30 seconds - so i am back to semtech UDP.
Today I made an update of my LIG16 to the latest firmware and switched to Basic Station.
Basic Station seems to work but still there is nothing shown in “Gateway Traffic”.
In the console the status is shown as “connected”, “Last activity” is only updated if there is a message from a node - that is ok for me.
It seems like no regularly status messages are sent from the LIG16 to TTS CE (or these messages are not shown anymore).
Even more than 1 hour of receiving no data from nodes, my LIG16 still shows “Connected” in the console. Then I unplugged the gateway and within less than 1 minute the console showed “Disconnected”.
I plugged it in again and after a few seconds the console showed “Connected”.
There is a communication between the gateway and TTS CE we do not “see” and maybe we dot not need to see it. @dreimal8 I dont understand why your gateway shows “Disconnected” after a few minutes of receiving no data.
I am in contact with dragino support and i made a factory reset and fresh install of the latest firmware and than recordet 5 minutes logfile and gave it to the support. So lets see if that can help. May be something is wrong on my side…
One thing is for sure, the gateway is keep connecting to the server, even though you can’t see the gateway status on the TTN console, but once the gateway receives the sensor node’s uplink which will forward to the server.
