Hi all,
Over the last few months, I’ve been learning about LoRa, LoRaWAN, and TTN, and it’s been very exciting.
I bought a Dragino LHT52 sensor and registered it in the TTN Console and physicaly installed it in Amsterdam-Zuid.
There is a gateway located about 700 meters away.
The problem:
When I insert the batteries, the LED sequence is green → red → blue → green, which seems correct.
However, the final green LED should stay on for about 5 seconds to indicate that the join was successful, but this does not happen.
In the TTN Console, I do not see any live data, and in the session information I get the message:
“This device has not joined the network yet.”
Gateway details:
EUI: 0000001EC03AFB86
Network: NS_TTS_V3://ttn@000013
Altitude: 10 m
Sensor details:
Frequency plan: Europe 863–870 MHz (SF9 for RX2 – recommended)
LoRaWAN version: 1.0.3
Regional Parameters version: RP001 Regional Parameters 1.0.3 revision A
Network server address: eu1.cloud.thethings.network
Application server address: eu1.cloud.thethings.network
Join server address: eu1.cloud.thethings.network
Activation mode: OTAA
What I tried:
Read the TTN documentation
Read the Dragino documentation
Read other relevant forum posts
Google searches
Asked ChatGPT
Verified that the AppEUI, DevEUI, and AppKey in the TTN Console match the values on the sensor package
Reset the sensor
Removed and reinserted the batteries
Does anyone have any idea what could be the issue?
Thanks.
