6 gateways in that area would mean that each gateway, even if placed optimally, would need to cover 70/6 = 11.66sqkm, so each gateway would need to provide a coverage range of 1.75km or so.
1.75km range at ground level in a city @ SF7 is maybe a bit optimistic.
But rather than theoretical calculations perhaps say what distance coverage you get at SF7 with your cities gateways ?
No doubt if you could install a great deal more gateways in a city then you could maybe make tracking viable @ SF7.
In reality for most locations using TTN for GPS tracking is really planning to breach the fair use policy.
In my efforts I saw that with SF7 I have 200m range to have safe delivery. So dense GW in my view is every 200m. I agree with you, this is very rare. But with GW’s every 1km, you can transmit with SF10 and occasionally with SF7/8/9.
I experienced an exception to 200m “rule”. A very “tall” GW is missing many transmissions even in <200 meters. Maybe noisy environment or something else.
I repeat: You can use SF10 and switch to SF7/8/9 if you are close to a GW or in “white zone”. Also in my efforts I saw very rare cases that GW’s that are 7-10km away are catching my signal (currently testing with SF9). So, again in those areas you can switch to SF7-9. I even will try to use FSK when close to GW. This is something unstested. Also you can transmit only when necessary, not every X time.
The TTN fair usage policy is easy to follow. Don’t transmit with SF11, SF12 and don’t exceed the 30secs limit.
My payload is 7 bytes and I transmit: location, position (stand, fall), gps fix (on/off), battery level (4 states), direction (accuracy 24 degrees) and speed (accuracy according to needs), quality of GPS fix. If the device has the same position (50meters). I trasmitt only one byte with the above info minus location but with full battery info (0-100%)
Those are not scientific measurements, just traveling 9km’s with differents SF’s with the tracker. The tracker was transmitting in RANDOM / unpredictable times.
And how will your device know it is close to a gateway?
Hmmmm, no fix is like saying “on planet earth, last seen in the vicinity of” and is made somewhat redundant by the quality figure.
Maybe roll that in to one bit rather than a whole byte. What do you report after they have fallen. How can you tell they have fallen. And the fact you have “fallen” in your payload turns this from a bit of ‘too and fro’ and some discussion repeated else where on the forum in to a “you are kidding”.
Hmmmmm, you get two free bytes at SF7, one at SF8, four at SF9 and one at SF10. But you have the port numbers to use as well. However unless something really radical happens to battery life, it’s not really needed on every uplink - there are techniques to transmit it as it changes regardless of the payload format in use at the time of the uplink that I have but commercial in confidence.
Apart from the general consensus that tracking using LoRaWAN has some very specific useful use cases but not as a general tracker and certainly not to track little old ladies and if they have taken a tumble, you are going to have to get very scientific if you don’t want your plans shredded on here.
If you do go ahead, can you tell us which papers to look out for in your area so we can read about the court case!
For a given distance, LoRa can transmit at a much higher data rate than FSK can, FSK needs to operate a fair few dB above noise level whilst LoRa operates a fair few dB below noise level.
So the FSK mode would use far more air time, and thus more of the fair access limit, than LoRa would.
(position to GW) not easy. But I think doable. Pre-configured and with downlinks.
(GPS fix) Yes, it’s overkill. The purpose is to understand that the device is on “difficult” area.
6 bytes are for Lat/Lon, all other information are stored in one byte (bits) and on ports. The next most efficient is to have less accuracy on GPS or to send difference (meters + heading) or to send relative to predefined area.
Yes, you have right, with different SF’s you can send more (or less) bytes. But this is not on my priority list. With 7 bytes I am ok. My Blind ADR version is on my priority and the MAC downlinks commands with SlimLora.
@LoRaTracker Thanks about the info. I had the impression that FSK was faster than SF7.
Be careful remember under TTN FUP downlinks are even more constrained - 10 per day - and that includes e.g. join process…and even that 10 should be used only sparingly as the cost to the network and all users in range of that GW is huge as the GW is deaf to uplinks during the downlink Tx 1 persons node doing a downlink might impact hundres or thousands of nodes doing an uplink (irrespective of SF…)
WRT FSK, yes device is technically capable of much faster FSK operation, and supports that for legacy interop deployments, however, as @LoRaTracker points out the real word conditions typically found in RF environments often mean that that advantage cannot be fully realised and LoRa at slower rate can be more effective due to the SNR issue - you really need to be right on top of the GW and in a low noise env to get advantage. Classically, most tests will tell you that fsk receivers typically need around a 7-10db positive SNR to allow reliable, consistent, discrimination and detection, I think I recall seeing one or two best in class in the 4-8db range, but constraints are tight. LoRa, even at SF7 is capabable of extracting useable symbols down to around -7- -7.5db SNR, so a mighty 14-17db headroom advantage allowing much more reliable extraction and range, hence LoRa being a Long Range solution SF12 of course is good to down around -20db With each intervening SF step giving approx 2.5db coding gain over the prior SF - giving atleast a 50%+ increase in range (if not closer to doubling FSL range).
a1) Those are known to me. The GW’s are not so often go up and down. Once per month (?) is not a problem when you configure a device to transmit less. Mind you this is a manual / local process not automated. I suppose my idea is not suitable to cover a country. a2) You / TTN can transmit on low traffic hours.
b) In my surprise TTN sends many downlinks. They are more verbose than me I never asked for downlinks, but TTN keeps sending. (TinyLoRa-gate)
Take it out of area at 100km/h and within minutes you’re backend will have to know a lot of information about the regions gateways - if any - and hit that happy moment when an uplink comes in near a gateway you have in range.
I was pointing out that you had a fix yes/no flag as well as a “quality of GPS” field. But as for “difficult” area - if a GPS runs out of its ephemeris (valid for 30 minutes, then warm fixes only) then it’s going to be very difficult for a rather long time unless you let the module run for a minute to update so it can hot fixes for the next 30 minutes.
What does any of this mean - one downlink a month?
No such thing and even if there was how are those going to be determined for an area?
That would be other members of the community that don’t know about or care about the FUP making - its not TTN deciding to downlink - it’s the users.
What is this precisely - from its name it looks horribly like it may be a Single Channel Packet Forwarder.
You seem to be talking one minute about active tracking with a standing/fallen flag and then the next about sending one positional fix per month (or so it seems). Like many of these aspirational designs, it’s so much easier to come up with a design if you provide some context - ie, you tell us what you are actually trying to achieve, then we can be rather more supportive.
Or is this perhaps one of the crippled/incomplete node lora(not)wan implementations much discussed and debated since V3 transition where device then incapable of correctly handling/responding to Network generated MAC commands etc. Such that backend then has to keep trying effectively spamming itself?
What’s your ideas about the Blind ADR on GPS trackers? You have something better instead of my idea? You prefer the trackers to transmit on one SF instead of dynamically changing the power and SF?
@Descartes, I don’t get what you gain with your question about my payload. I use 6 bytes for Lat/Lon. One nibble for speed and the rest byte (nibble) for the heading. Total 7 bytes for 5 data (+battery, +stand/fall, GPS qual, GPS fix). Data on parenthesis are bits on the port (zero [0] bytes]. Why you are still asking about my payload? It’s irrelevant. One commercial solution is using 11 bytes for 4 data and CayenneLPP uses 11 bytes only for the Lat/Lon.
One downlink per month (my guess) and uplinks only on movement. Maybe zero per month.
I wrote about an idea that can help all payloads and all LoRaWAN implementations, like LMIC, Tiny/SlimLoRa, commercial solutions. Semtech is proposing something like that with the name Blind ADR.
Personally, I’d prefer trackers to have a definite purpose but yet we all still have no clue what you are trying to create. As for blind/fixed/dynamic, in the right use case any one, or combo or all three have value.
If you don’t like the feedback, don’t post detail.
Just because there are other worse solutions around doesn’t make yours better.
One downlink to what end? Sending locations of gateways as suggested above. And as for uplinks maybe zero, how does that fit with the implications of a flag for standing/fallen.
I’m a bit lost, which idea? The whole “LoRaWAN for tracking” comes up every few months.
The only help for TinyLoRa is for migration away from it - it just doesn’t work well with v3. SlimLoRa, which I volunteered to assist in working on, was sort of announced Feb this year as a potential replacement for TinyLoRa and then the developer has been seen once since. I’m assuming you are using ABP because as far as I know OTAA isn’t working yet, which isn’t great for v3 use.
I’m not aware of Semtech proposing something with the name Blind ADR - mostly because it’s a phrase in general use and partly because their geo-location efforts seem to involve a new chipset plus upgraded gateways.
As for the LoRaTracker question, I asked it too - what is a TinyLoRa-gate??
No one is trying to rain on your parade to dampen your enthusiasm. If you have a specific use case for tracking that you can detail your plans for creating a solution that you want reviewing, we’ll all be happy to help. But at present you have ideas that some of us have seen discussed several times before, apparently no real-world attempts or experiments and a forum with a whole history of people struggling with trackers in general.
You have a better idea than mine? You can help me to fit Lat/Lon data in less than 6 bytes? I think this is the only drawback of my payload. (out-of-topic, but since you want to help: I am watching).
My idea is to store GW locations so the device can operate in “White Zones” (my version of Blind ADR for non optimal areas).
I really still don’t get why you want specifics from me. I think my idea is fine for those trackers. They are suitable for assets e.t.c. as @nashenden stated.
I wrote my idea of “White Zones” (for starters GW position is more easy) as a companion to Blind ADR. Something to elaborate on that?
TinyLoRa-gate is my expression like Diesel-Gate, Water-Gate for MAC commands avalanche in V3 e.t.c.
??? Downlink: from TTN to device. We have other downlinks ???
??? Well. Technically my payload it is better since it uses less bytes for more info.
So my 7 bytes payload is bad? (again: Out-of-topic but I am watching #2)
Well, at least you are placing the blame where it’s due - this disaster indeed happens if you try to use a node firmware that doesn’t actually implement LoRaWAN, on a LoRaWAN network.
Apologies, I thought you were trying to create something yourself:
So you may see why I thought you were designing your own tracker.
As for my geo payloads, if they are relatively stationary and/or only need to report where they are when stationary for a decent amount of time, then I use two integers aka 4 bytes, if it’s transmitting on the move, then I mostly send deltas and/or turns (because they are a pallet on a truck on a highway). This maximises battery life considerably. Most of my trackers are for assets, not people. I have used LoRa for tracking with a mesh and I have tried using LoRaWAN in combination with SMS & GSM/LTE but that gets complicated. Sometimes WiFi comes in to the mix which is useful for pre-movement ephemeris updates.
As for the side swipe at TTN for what you dub TinyLoRa-gate, perhaps you should ask the person who installed the firmware what they were thinking.
@descartes yes, I am trying to do something to share / help with people like the OP.
So you think that a 7 bytes payload is a problem for GPS tracking as OP wants and the 4 bytes is the solution and is more useful than my idea of white zones? (Blind ADR on steroids)
@cslorabox I don’t use it anymore. Enough with the TinyLoRa-gate.
