Hai, I am quite new in this field. Looking to set up a gateway in Nusajaya, Johor with my lecturer. May I know, can I use RFM95 to operate at the prescribed 920-923MHz band?
I’m working on the Lora solution as well, happy to see many experts at here … Wish can learn more from you all ^^
This is the lora board from the company I’m working on …
Just curious is there any legal issue or cautious need to take note when using long range 433 MHz in Malaysia? Does MCMC got any technical document/specification for this long range device?
Disclaimer: I am not an expert in this subject but has found some materials regarding the spectrum assignment via MCMC website in the following document “Class-Assignment-No-2-of-2015” on page 8 saying that frequency band from 433 to 435 MHz can be used but with maximum EIRP of 100 mW.
I also stay in Nusajaya area and also interested to setup a Lora gateway. May I know if you have any success with the setup? please drop me an email tengthuan@gmail.com . Thanks!
Should this be able to connect to a gateway in KL so I can see the data? It comes with something pre-programmed and says "sending packet " with an increasing number every so often so I am guessing it is transmitting!
Has the frequency allocation been sorted out yet? I can’t see anything definitive but I did read 868MHz is being disallowed as of the end of this year…which leads me to believe 868MHz is the current frequency used?
Hi. I am new to TTN and dragino gateway. I am currently in Miri using 433MHz dragino shield and gateway. In TTN, there is no 433MHz router for asia or south-east asia. There is no much material i could refer to on internet. Could anyone advise me how to send and receive data using 433MHz ?
Hi. I am not an expert in these matters but with the help of a local expert I have setup my single channel dragino-shield on a raspberry-pi2. I am using 923.2 Mhz
works fine. There is one dragino node attached to it… I can see the device live on the TTN Map. Important baby steps forward.
The whole purpose is to learn about this type of device, LoRa IoT etc…
That’s a very good news! Do you mind sharing how did you setup a gateway for 923 MHz ?
I’m interested in making one for using in Thailand. There are only few people who know and start working on 923 MHz, but your success is indeed a good step forward.
