Gateway RAK7258 not connected to TTN
Welcome Massim_10. A good choice for a gateway, however please note the language for the TTN forum is English. I have edited your post to add a simple translation per Google Translate. Please post in English or if that is not easy for you please dual post -GIYF! :slight_smile:
Bienvenido Massim_10. Una buena opción para una puerta de enlace, sin embargo, tenga en cuenta que el idioma del foro TTN es el inglés. He editado tu publicación para agregar una traducción simple según el Traductor de Google. Por favor, publique en inglés o si eso no es fácil para usted, haga doble post -GIYF. :slight_smile:
Please be sure to use search when finding a problem or looking for possible explanations or solutions. It may be you are a victim of
So the 1st thing to check is are you getting data through to your application(s) through the gw? If there are several receiving GW’s in your area you can look at the reception metadata in your app and look at list of GW’s forwarding the message to see if your gw is one of the GW’s called out. If if it is then it is working ok, if not we will need more info to help you try and diagnose the problem.
I solved my first problem thanks, finally the gateway is connected to TTN now I have to understand how to load a node
thanks
What was the problem, can you share your solution? Cheers
instead of entering the name serves ttn-router-eu I entered the IP address 52.169.76.203 and now it is connected
Hardcoding the IP address is not really a reliable solution; if something needs to change on the infrastructure side, they’d point the DNS name at the new IP and expect all gateways to adapt. If you’re going to leave it this way, then in any failure the first thing you have to do is use another box to check if the DNS name is still pointed at that address.
Really you should figure out why DNS isn’t working on the gateway - what sort of internet connection is it using? Did you correctly configure that?
if I show you the system log, can you check if the configuration is correct?
thanks
the strange thing is that I don’t see data traffic, it is connected but it doesn’t make traffic
is there any way to ping the gateway from the ttn console?
No, not without a device.
Do you have a device?
yes I have it and I recorded it on TT together with an application, but this is “never seen”
So either the config for the gateway isn’t quite right - check its log to see that it is in contact with the network server. Do not look at the gateway console last seen date/time as it is unreliable.
Once you are sure you have the gateway in communication with the network, then recheck the configuration of the device matches the setup on the TTN console.
You can then trigger your device to send by whatever means - using ABP and turning it on / resetting usually does the job - see if your gateway hears the device and relays the uplink and then you can check the TTN gateway log and the application / device log.
I am attaching the LOG of the gateway can you take a look at it please?
Wed Jan 20 18:22:29 2021 daemon.info evloop[32093]: evloopInit Done.
Wed Jan 20 18:22:29 2021 daemon.info md[32093]: mdInit Done.
Wed Jan 20 18:22:29 2021 daemon.info mqttEv[32093]: mqttEvInit Done.
Wed Jan 20 18:22:29 2021 daemon.info unknown[32093]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:22:29 2021 daemon.info bufrd[32093]: bufrdInit Done.
Wed Jan 20 18:22:29 2021 daemon.info bufrd[32093]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:22:29 2021 daemon.info gwBridge[32093]: MQTT Init Start
Wed Jan 20 18:22:29 2021 daemon.info gwBridge[32093]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:22:29 2021 daemon.info gwBridge[32093]: Mqtt - Retain 0
Wed Jan 20 18:22:29 2021 daemon.info gwBridge[32093]: Mqtt - Clean Session 1
Wed Jan 20 18:22:29 2021 daemon.info gwBridge[32093]: Mqtt - Qos 1
Wed Jan 20 18:22:29 2021 daemon.info gwBridge[32093]: Mqtt - keepalive 10
Wed Jan 20 18:22:29 2021 daemon.info loraSrv[32634]: child process 32093 exited  due to signal 11
Wed Jan 20 18:22:32 2021 daemon.info evloop[32121]: evloopInit Done.
Wed Jan 20 18:22:32 2021 daemon.info md[32121]: mdInit Done.
Wed Jan 20 18:22:32 2021 daemon.info mqttEv[32121]: mqttEvInit Done.
Wed Jan 20 18:22:32 2021 daemon.info unknown[32121]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:22:32 2021 daemon.info bufrd[32121]: bufrdInit Done.
Wed Jan 20 18:22:32 2021 daemon.info bufrd[32121]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:22:32 2021 daemon.info gwBridge[32121]: MQTT Init Start
Wed Jan 20 18:22:32 2021 daemon.info gwBridge[32121]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:22:32 2021 daemon.info gwBridge[32121]: Mqtt - Retain 0
Wed Jan 20 18:22:32 2021 daemon.info gwBridge[32121]: Mqtt - Clean Session 1
Wed Jan 20 18:22:32 2021 daemon.info gwBridge[32121]: Mqtt - Qos 1
Wed Jan 20 18:22:32 2021 daemon.info gwBridge[32121]: Mqtt - keepalive 10
Wed Jan 20 18:22:32 2021 daemon.info loraSrv[32634]: child process 32121 exited  due to signal 11
Wed Jan 20 18:22:35 2021 daemon.info evloop[32122]: evloopInit Done.
Wed Jan 20 18:22:35 2021 daemon.info md[32122]: mdInit Done.
Wed Jan 20 18:22:35 2021 daemon.info mqttEv[32122]: mqttEvInit Done.
Wed Jan 20 18:22:35 2021 daemon.info unknown[32122]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:22:35 2021 daemon.info bufrd[32122]: bufrdInit Done.
Wed Jan 20 18:22:35 2021 daemon.info bufrd[32122]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:22:35 2021 daemon.info gwBridge[32122]: MQTT Init Start
Wed Jan 20 18:22:35 2021 daemon.info gwBridge[32122]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:22:35 2021 daemon.info gwBridge[32122]: Mqtt - Retain 0
Wed Jan 20 18:22:35 2021 daemon.info gwBridge[32122]: Mqtt - Clean Session 1
Wed Jan 20 18:22:35 2021 daemon.info gwBridge[32122]: Mqtt - Qos 1
Wed Jan 20 18:22:35 2021 daemon.info gwBridge[32122]: Mqtt - keepalive 10
Wed Jan 20 18:22:35 2021 daemon.info loraSrv[32634]: child process 32122 exited  due to signal 11
Wed Jan 20 18:22:38 2021 daemon.info evloop[32150]: evloopInit Done.
Wed Jan 20 18:22:38 2021 daemon.info md[32150]: mdInit Done.
Wed Jan 20 18:22:38 2021 daemon.info mqttEv[32150]: mqttEvInit Done.
Wed Jan 20 18:22:38 2021 daemon.info unknown[32150]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:22:38 2021 daemon.info bufrd[32150]: bufrdInit Done.
Wed Jan 20 18:22:38 2021 daemon.info bufrd[32150]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:22:38 2021 daemon.info gwBridge[32150]: MQTT Init Start
Wed Jan 20 18:22:38 2021 daemon.info gwBridge[32150]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:22:38 2021 daemon.info gwBridge[32150]: Mqtt - Retain 0
Wed Jan 20 18:22:38 2021 daemon.info gwBridge[32150]: Mqtt - Clean Session 1
Wed Jan 20 18:22:38 2021 daemon.info gwBridge[32150]: Mqtt - Qos 1
Wed Jan 20 18:22:38 2021 daemon.info gwBridge[32150]: Mqtt - keepalive 10
Wed Jan 20 18:22:38 2021 daemon.info loraSrv[32634]: child process 32150 exited  due to signal 11
Wed Jan 20 18:22:41 2021 daemon.info evloop[32156]: evloopInit Done.
Wed Jan 20 18:22:41 2021 daemon.info md[32156]: mdInit Done.
Wed Jan 20 18:22:41 2021 daemon.info mqttEv[32156]: mqttEvInit Done.
Wed Jan 20 18:22:41 2021 daemon.info unknown[32156]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:22:41 2021 daemon.info bufrd[32156]: bufrdInit Done.
Wed Jan 20 18:22:41 2021 daemon.info bufrd[32156]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:22:41 2021 daemon.info gwBridge[32156]: MQTT Init Start
Wed Jan 20 18:22:41 2021 daemon.info gwBridge[32156]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:22:41 2021 daemon.info gwBridge[32156]: Mqtt - Retain 0
Wed Jan 20 18:22:41 2021 daemon.info gwBridge[32156]: Mqtt - Clean Session 1
Wed Jan 20 18:22:41 2021 daemon.info gwBridge[32156]: Mqtt - Qos 1
Wed Jan 20 18:22:41 2021 daemon.info gwBridge[32156]: Mqtt - keepalive 10
Wed Jan 20 18:22:41 2021 daemon.info loraSrv[32634]: child process 32156 exited  due to signal 11
Wed Jan 20 18:22:44 2021 daemon.info evloop[32179]: evloopInit Done.
Wed Jan 20 18:22:44 2021 daemon.info md[32179]: mdInit Done.
Wed Jan 20 18:22:44 2021 daemon.info mqttEv[32179]: mqttEvInit Done.
Wed Jan 20 18:22:44 2021 daemon.info unknown[32179]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:22:44 2021 daemon.info bufrd[32179]: bufrdInit Done.
Wed Jan 20 18:22:44 2021 daemon.info bufrd[32179]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:22:44 2021 daemon.info gwBridge[32179]: MQTT Init Start
Wed Jan 20 18:22:44 2021 daemon.info gwBridge[32179]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:22:44 2021 daemon.info gwBridge[32179]: Mqtt - Retain 0
Wed Jan 20 18:22:44 2021 daemon.info gwBridge[32179]: Mqtt - Clean Session 1
Wed Jan 20 18:22:44 2021 daemon.info gwBridge[32179]: Mqtt - Qos 1
Wed Jan 20 18:22:44 2021 daemon.info gwBridge[32179]: Mqtt - keepalive 10
Wed Jan 20 18:22:44 2021 daemon.info loraSrv[32634]: child process 32179 exited  due to signal 11
Wed Jan 20 18:22:47 2021 daemon.info evloop[32209]: evloopInit Done.
Wed Jan 20 18:22:47 2021 daemon.info md[32209]: mdInit Done.
Wed Jan 20 18:22:47 2021 daemon.info mqttEv[32209]: mqttEvInit Done.
Wed Jan 20 18:22:47 2021 daemon.info unknown[32209]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:22:47 2021 daemon.info bufrd[32209]: bufrdInit Done.
Wed Jan 20 18:22:47 2021 daemon.info bufrd[32209]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:22:47 2021 daemon.info gwBridge[32209]: MQTT Init Start
Wed Jan 20 18:22:47 2021 daemon.info gwBridge[32209]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:22:47 2021 daemon.info gwBridge[32209]: Mqtt - Retain 0
Wed Jan 20 18:22:47 2021 daemon.info gwBridge[32209]: Mqtt - Clean Session 1
Wed Jan 20 18:22:47 2021 daemon.info gwBridge[32209]: Mqtt - Qos 1
Wed Jan 20 18:22:47 2021 daemon.info gwBridge[32209]: Mqtt - keepalive 10
Wed Jan 20 18:22:47 2021 daemon.info loraSrv[32634]: child process 32209 exited  due to signal 11
Wed Jan 20 18:22:50 2021 daemon.info evloop[32210]: evloopInit Done.
Wed Jan 20 18:22:50 2021 daemon.info md[32210]: mdInit Done.
Wed Jan 20 18:22:50 2021 daemon.info mqttEv[32210]: mqttEvInit Done.
Wed Jan 20 18:22:50 2021 daemon.info unknown[32210]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:22:50 2021 daemon.info bufrd[32210]: bufrdInit Done.
Wed Jan 20 18:22:50 2021 daemon.info bufrd[32210]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:22:50 2021 daemon.info gwBridge[32210]: MQTT Init Start
Wed Jan 20 18:22:50 2021 daemon.info gwBridge[32210]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:22:50 2021 daemon.info gwBridge[32210]: Mqtt - Retain 0
Wed Jan 20 18:22:50 2021 daemon.info gwBridge[32210]: Mqtt - Clean Session 1
Wed Jan 20 18:22:50 2021 daemon.info gwBridge[32210]: Mqtt - Qos 1
Wed Jan 20 18:22:50 2021 daemon.info gwBridge[32210]: Mqtt - keepalive 10
Wed Jan 20 18:22:50 2021 daemon.info loraSrv[32634]: child process 32210 exited  due to signal 11
Wed Jan 20 18:22:53 2021 daemon.info evloop[32238]: evloopInit Done.
Wed Jan 20 18:22:53 2021 daemon.info md[32238]: mdInit Done.
Wed Jan 20 18:22:53 2021 daemon.info mqttEv[32238]: mqttEvInit Done.
Wed Jan 20 18:22:53 2021 daemon.info unknown[32238]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:22:53 2021 daemon.info bufrd[32238]: bufrdInit Done.
Wed Jan 20 18:22:53 2021 daemon.info bufrd[32238]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:22:53 2021 daemon.info gwBridge[32238]: MQTT Init Start
Wed Jan 20 18:22:53 2021 daemon.info gwBridge[32238]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:22:53 2021 daemon.info gwBridge[32238]: Mqtt - Retain 0
Wed Jan 20 18:22:53 2021 daemon.info gwBridge[32238]: Mqtt - Clean Session 1
Wed Jan 20 18:22:53 2021 daemon.info gwBridge[32238]: Mqtt - Qos 1
Wed Jan 20 18:22:53 2021 daemon.info gwBridge[32238]: Mqtt - keepalive 10
Wed Jan 20 18:22:53 2021 daemon.info loraSrv[32634]: child process 32238 exited  due to signal 11
Wed Jan 20 18:22:56 2021 daemon.info evloop[32266]: evloopInit Done.
Wed Jan 20 18:22:56 2021 daemon.info md[32266]: mdInit Done.
Wed Jan 20 18:22:56 2021 daemon.info mqttEv[32266]: mqttEvInit Done.
Wed Jan 20 18:22:56 2021 daemon.info unknown[32266]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:22:56 2021 daemon.info bufrd[32266]: bufrdInit Done.
Wed Jan 20 18:22:56 2021 daemon.info bufrd[32266]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:22:56 2021 daemon.info gwBridge[32266]: MQTT Init Start
Wed Jan 20 18:22:56 2021 daemon.info gwBridge[32266]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:22:56 2021 daemon.info gwBridge[32266]: Mqtt - Retain 0
Wed Jan 20 18:22:56 2021 daemon.info gwBridge[32266]: Mqtt - Clean Session 1
Wed Jan 20 18:22:56 2021 daemon.info gwBridge[32266]: Mqtt - Qos 1
Wed Jan 20 18:22:56 2021 daemon.info gwBridge[32266]: Mqtt - keepalive 10
Wed Jan 20 18:22:56 2021 daemon.info loraSrv[32634]: child process 32266 exited  due to signal 11
Wed Jan 20 18:22:59 2021 daemon.info evloop[32267]: evloopInit Done.
Wed Jan 20 18:22:59 2021 daemon.info md[32267]: mdInit Done.
Wed Jan 20 18:22:59 2021 daemon.info mqttEv[32267]: mqttEvInit Done.
Wed Jan 20 18:22:59 2021 daemon.info unknown[32267]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:22:59 2021 daemon.info bufrd[32267]: bufrdInit Done.
Wed Jan 20 18:22:59 2021 daemon.info bufrd[32267]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:22:59 2021 daemon.info gwBridge[32267]: MQTT Init Start
Wed Jan 20 18:22:59 2021 daemon.info gwBridge[32267]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:22:59 2021 daemon.info gwBridge[32267]: Mqtt - Retain 0
Wed Jan 20 18:22:59 2021 daemon.info gwBridge[32267]: Mqtt - Clean Session 1
Wed Jan 20 18:22:59 2021 daemon.info gwBridge[32267]: Mqtt - Qos 1
Wed Jan 20 18:22:59 2021 daemon.info gwBridge[32267]: Mqtt - keepalive 10
Wed Jan 20 18:22:59 2021 daemon.info loraSrv[32634]: child process 32267 exited  due to signal 11
Wed Jan 20 18:23:02 2021 daemon.info evloop[32295]: evloopInit Done.
Wed Jan 20 18:23:02 2021 daemon.info md[32295]: mdInit Done.
Wed Jan 20 18:23:02 2021 daemon.info mqttEv[32295]: mqttEvInit Done.
Wed Jan 20 18:23:02 2021 daemon.info unknown[32295]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:23:02 2021 daemon.info bufrd[32295]: bufrdInit Done.
Wed Jan 20 18:23:02 2021 daemon.info bufrd[32295]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:23:02 2021 daemon.info gwBridge[32295]: MQTT Init Start
Wed Jan 20 18:23:02 2021 daemon.info gwBridge[32295]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:23:02 2021 daemon.info gwBridge[32295]: Mqtt - Retain 0
Wed Jan 20 18:23:02 2021 daemon.info gwBridge[32295]: Mqtt - Clean Session 1
Wed Jan 20 18:23:02 2021 daemon.info gwBridge[32295]: Mqtt - Qos 1
Wed Jan 20 18:23:02 2021 daemon.info gwBridge[32295]: Mqtt - keepalive 10
Wed Jan 20 18:23:02 2021 daemon.info loraSrv[32634]: child process 32295 exited  due to signal 11
Wed Jan 20 18:23:05 2021 daemon.info evloop[32296]: evloopInit Done.
Wed Jan 20 18:23:05 2021 daemon.info md[32296]: mdInit Done.
Wed Jan 20 18:23:05 2021 daemon.info mqttEv[32296]: mqttEvInit Done.
Wed Jan 20 18:23:05 2021 daemon.info unknown[32296]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:23:05 2021 daemon.info bufrd[32296]: bufrdInit Done.
Wed Jan 20 18:23:05 2021 daemon.info bufrd[32296]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:23:05 2021 daemon.info gwBridge[32296]: MQTT Init Start
Wed Jan 20 18:23:05 2021 daemon.info gwBridge[32296]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:23:05 2021 daemon.info gwBridge[32296]: Mqtt - Retain 0
Wed Jan 20 18:23:05 2021 daemon.info gwBridge[32296]: Mqtt - Clean Session 1
Wed Jan 20 18:23:05 2021 daemon.info gwBridge[32296]: Mqtt - Qos 1
Wed Jan 20 18:23:05 2021 daemon.info gwBridge[32296]: Mqtt - keepalive 10
Wed Jan 20 18:23:05 2021 daemon.info loraSrv[32634]: child process 32296 exited  due to signal 11
Wed Jan 20 18:23:08 2021 daemon.info evloop[32324]: evloopInit Done.
Wed Jan 20 18:23:08 2021 daemon.info md[32324]: mdInit Done.
Wed Jan 20 18:23:08 2021 daemon.info mqttEv[32324]: mqttEvInit Done.
Wed Jan 20 18:23:08 2021 daemon.info unknown[32324]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:23:08 2021 daemon.info bufrd[32324]: bufrdInit Done.
Wed Jan 20 18:23:08 2021 daemon.info bufrd[32324]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:23:08 2021 daemon.info gwBridge[32324]: MQTT Init Start
Wed Jan 20 18:23:08 2021 daemon.info gwBridge[32324]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:23:08 2021 daemon.info gwBridge[32324]: Mqtt - Retain 0
Wed Jan 20 18:23:08 2021 daemon.info gwBridge[32324]: Mqtt - Clean Session 1
Wed Jan 20 18:23:08 2021 daemon.info gwBridge[32324]: Mqtt - Qos 1
Wed Jan 20 18:23:08 2021 daemon.info gwBridge[32324]: Mqtt - keepalive 10
Wed Jan 20 18:23:08 2021 daemon.info loraSrv[32634]: child process 32324 exited  due to signal 11
Wed Jan 20 18:23:11 2021 daemon.info evloop[32352]: evloopInit Done.
Wed Jan 20 18:23:11 2021 daemon.info md[32352]: mdInit Done.
Wed Jan 20 18:23:11 2021 daemon.info mqttEv[32352]: mqttEvInit Done.
Wed Jan 20 18:23:11 2021 daemon.info unknown[32352]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:23:11 2021 daemon.info bufrd[32352]: bufrdInit Done.
Wed Jan 20 18:23:11 2021 daemon.info bufrd[32352]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:23:11 2021 daemon.info gwBridge[32352]: MQTT Init Start
Wed Jan 20 18:23:11 2021 daemon.info gwBridge[32352]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:23:11 2021 daemon.info gwBridge[32352]: Mqtt - Retain 0
Wed Jan 20 18:23:11 2021 daemon.info gwBridge[32352]: Mqtt - Clean Session 1
Wed Jan 20 18:23:11 2021 daemon.info gwBridge[32352]: Mqtt - Qos 1
Wed Jan 20 18:23:11 2021 daemon.info gwBridge[32352]: Mqtt - keepalive 10
Wed Jan 20 18:23:11 2021 daemon.info loraSrv[32634]: child process 32352 exited  due to signal 11
Wed Jan 20 18:23:14 2021 daemon.info evloop[32353]: evloopInit Done.
Wed Jan 20 18:23:14 2021 daemon.info md[32353]: mdInit Done.
Wed Jan 20 18:23:14 2021 daemon.info mqttEv[32353]: mqttEvInit Done.
Wed Jan 20 18:23:14 2021 daemon.info unknown[32353]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:23:14 2021 daemon.info bufrd[32353]: bufrdInit Done.
Wed Jan 20 18:23:14 2021 daemon.info bufrd[32353]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:23:14 2021 daemon.info gwBridge[32353]: MQTT Init Start
Wed Jan 20 18:23:14 2021 daemon.info gwBridge[32353]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:23:14 2021 daemon.info gwBridge[32353]: Mqtt - Retain 0
Wed Jan 20 18:23:14 2021 daemon.info gwBridge[32353]: Mqtt - Clean Session 1
Wed Jan 20 18:23:14 2021 daemon.info gwBridge[32353]: Mqtt - Qos 1
Wed Jan 20 18:23:14 2021 daemon.info gwBridge[32353]: Mqtt - keepalive 10
Wed Jan 20 18:23:14 2021 daemon.info loraSrv[32634]: child process 32353 exited  due to signal 11
Wed Jan 20 18:23:17 2021 daemon.info evloop[32383]: evloopInit Done.
Wed Jan 20 18:23:17 2021 daemon.info md[32383]: mdInit Done.
Wed Jan 20 18:23:17 2021 daemon.info mqttEv[32383]: mqttEvInit Done.
Wed Jan 20 18:23:17 2021 daemon.info unknown[32383]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:23:17 2021 daemon.info bufrd[32383]: bufrdInit Done.
Wed Jan 20 18:23:17 2021 daemon.info bufrd[32383]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:23:17 2021 daemon.info gwBridge[32383]: MQTT Init Start
Wed Jan 20 18:23:17 2021 daemon.info gwBridge[32383]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:23:17 2021 daemon.info gwBridge[32383]: Mqtt - Retain 0
Wed Jan 20 18:23:17 2021 daemon.info gwBridge[32383]: Mqtt - Clean Session 1
Wed Jan 20 18:23:17 2021 daemon.info gwBridge[32383]: Mqtt - Qos 1
Wed Jan 20 18:23:17 2021 daemon.info gwBridge[32383]: Mqtt - keepalive 10
Wed Jan 20 18:23:17 2021 daemon.info loraSrv[32634]: child process 32383 exited  due to signal 11
Wed Jan 20 18:23:20 2021 daemon.info evloop[32385]: evloopInit Done.
Wed Jan 20 18:23:20 2021 daemon.info md[32385]: mdInit Done.
Wed Jan 20 18:23:20 2021 daemon.info mqttEv[32385]: mqttEvInit Done.
Wed Jan 20 18:23:20 2021 daemon.info unknown[32385]: gwManagerInit: Init gateway Manager
Wed Jan 20 18:23:20 2021 daemon.info bufrd[32385]: bufrdInit Done.
Wed Jan 20 18:23:20 2021 daemon.info bufrd[32385]: ENTER bufrdCreate `gwbridge-rd'
Wed Jan 20 18:23:20 2021 daemon.info gwBridge[32385]: MQTT Init Start
Wed Jan 20 18:23:20 2021 daemon.info gwBridge[32385]: Mqtt - Client ID gwbridge-60c5a8fffexxxx
Wed Jan 20 18:23:20 2021 daemon.info gwBridge[32385]: Mqtt - Retain 0
Wed Jan 20 18:23:20 2021 daemon.info gwBridge[32385]: Mqtt - Clean Session 1
Wed Jan 20 18:23:20 2021 daemon.info gwBridge[32385]: Mqtt - Qos 1
Wed Jan 20 18:23:20 2021 daemon.info gwBridge[32385]: Mqtt - keepalive 10
Wed Jan 20 18:23:20 2021 daemon.info loraSrv[32634]: child process 32385 exited  due to signal 11
Next time please format your post in stead of just dumping a lot of text in a message.
sorry I didn’t know about the formatting
Your log is full of messages about the MQTT bridge, which has no role when using TTN - the gateway bridge is only relevant when using LoRaServer/Chirpstack.
Your log does not show any messages from the packet forwarder, which is what actually matters for TTN use.
As such, you’ve not provided any information that could help identify your problem - it does raise the possibility that mistakenly configuring the gateway to point at the gateway bridge and not at a TTN server could be one of the possible problems, but your gateway bridge log doesn’t readily yield any evidence that the packet forwarder is in contact with that, either.
hello, I downloaded another log after the new configurations can you help me understand what’s wrong?
S un Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: [truncated] , CRC_FAIL: 0.00%, NO_CRC: 0.00%
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: # RF packets forwarded: 0 (0 bytes)
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: # PUSH_DATA datagrams sent: 1 (174 bytes)
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: [truncated]
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: ### [DOWNSTREAM] ###
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: # PULL_DATA sent: 6 (100.00 0x0.0000000000005p-992cknowledged)
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: # RF packets sent to concentrator: 0 (0 bytes)
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: # TX errors: 0
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: # BEACON queued: 0
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: # BEACON sent so far: 0
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: # BEACON rejected: 0
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: ### [JIT] ###
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: # SX1301 time (PPS): 2792760918, offset us 0
Sun Jan 24 08:19:38 2021 user.info lora_pkt_fwd[8540]: src/jitqueue.c:452:jit_print_queue(): INFO: [jit] queue is empty
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: ### [GPS] ###
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: # Invalid time reference (age: 1611472778 sec)
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: # no valid GPS coordinates available yet
Sun Jan 24 08:19:38 2021 user.debug lora_pkt_fwd[8540]: ##### END #####
JSON up: {“stat”:{“time”:“2021-01-24 07:19:38 UTC”,“lati”:0.00000,“long”:0.00000,“alti”:0,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0,“cpur”:0.0,“memr”:0.0}}
Sun Jan 24 08:19:38 2021 user.info lora_pkt_fwd[8540]: INFO: [up] PUSH_ACK received in 47 ms
Sun Jan 24 08:19:39 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:19:44 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:19:50 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 44 ms
INFO: Disabling GPS mode for concentrator’s counter…
Sun Jan 24 08:19:50 2021 user.info lora_pkt_fwd[8540]: INFO: host/sx1301 time offset=(1611469937s:671254µs) - drift=-11µs
Sun Jan 24 08:19:50 2021 user.info lora_pkt_fwd[8540]: INFO: Enabling GPS mode for concentrator’s counter.
Sun Jan 24 08:19:55 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 44 ms
Sun Jan 24 08:20:00 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 44 ms
Sun Jan 24 08:20:05 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 44 ms
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]:
##### 2021-01-24 07:20:08 UTC #####
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]: ### [UPSTREAM] ###
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]: # RF packets received by concentrator: 0
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]: [truncated] , CRC_FAIL: 0.00%, NO_CRC: 0.00%
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]: # RF packets forwarded: 0 (0 bytes)
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]: # PUSH_DATA datagrams sent: 1 (174 bytes)
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]: ### [DOWNSTREAM] ###
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]: # PULL_DATA sent: 6 (100.00 0x0.0000000000005p-992cknowledged)
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]: # RF packets sent to concentrator: 0 (0 bytes)
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]: # SX1301 time (PPS): 2852763350, offset us 0
Sun Jan 24 08:20:08 2021 user.info lora_pkt_fwd[8540]: src/jitqueue.c:452:jit_print_queue(): INFO: [jit] queue is empty
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]: ### [GPS] ###
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]: # Invalid time reference (age: 1611472808 sec)
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]: # no valid GPS coordinates available yet
Sun Jan 24 08:20:08 2021 user.debug lora_pkt_fwd[8540]: ##### END #####
JSON up: {"stat":{"time":"2021-01-24 07:20:08 UTC","lati":0.00000,"long":0.00000,"alti":0,"rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"cpur":0.0,"memr":0.0}}
Sun Jan 24 08:20:08 2021 user.info lora_pkt_fwd[8540]: INFO: [up] PUSH_ACK received in 51 ms
Sun Jan 24 08:20:10 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:20:15 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 48 ms
Sun Jan 24 08:20:20 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:20:25 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:20:30 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 44 ms
Sun Jan 24 08:20:35 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]:
##### 2021-01-24 07:20:38 UTC #####
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]: ### [UPSTREAM] ###
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]: # RF packets received by concentrator: 0
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]: [truncated] , CRC_FAIL: 0.00%, NO_CRC: 0.00%
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]: # RF packets forwarded: 0 (0 bytes)
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]: # PUSH_DATA datagrams sent: 1 (174 bytes)
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]: ### [DOWNSTREAM] ###
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]: # PULL_DATA sent: 6 (100.00 0x0.0000000000005p-992cknowledged)
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]: # RF packets sent to concentrator: 0 (0 bytes)
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]: # SX1301 time (PPS): 2852763350, offset us 0
Sun Jan 24 08:20:38 2021 user.info lora_pkt_fwd[8540]: src/jitqueue.c:452:jit_print_queue(): INFO: [jit] queue is empty
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]: ### [GPS] ###
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]: # Invalid time reference (age: 1611472838 sec)
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]: # no valid GPS coordinates available yet
Sun Jan 24 08:20:38 2021 user.debug lora_pkt_fwd[8540]: ##### END #####
JSON up: {"stat":{"time":"2021-01-24 07:20:38 UTC","lati":0.00000,"long":0.00000,"alti":0,"rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"cpur":0.0,"memr":0.0}}
Sun Jan 24 08:20:38 2021 user.info lora_pkt_fwd[8540]: INFO: [up] PUSH_ACK received in 48 ms
Sun Jan 24 08:20:40 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 44 ms
Sun Jan 24 08:20:45 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:20:50 2021 user.info lora_pkt_fwd[8540]:
INFO: Disabling GPS mode for concentrator's counter...
Sun Jan 24 08:20:50 2021 user.info lora_pkt_fwd[8540]: INFO: host/sx1301 time offset=(1611469937s:671234µs) - drift=-20µs
Sun Jan 24 08:20:50 2021 user.info lora_pkt_fwd[8540]: INFO: Enabling GPS mode for concentrator's counter.
Sun Jan 24 08:20:50 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 44 ms
Sun Jan 24 08:20:55 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 44 ms
Sun Jan 24 08:21:00 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:21:05 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]:
##### 2021-01-24 07:21:08 UTC #####
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: ### [UPSTREAM] ###
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: # RF packets received by concentrator: 0
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: [truncated] , CRC_FAIL: 0.00%, NO_CRC: 0.00%
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: # RF packets forwarded: 0 (0 bytes)
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: # PUSH_DATA datagrams sent: 1 (174 bytes)
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: ### [DOWNSTREAM] ###
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: # PULL_DATA sent: 6 (100.00 0x0.0000000000005p-992cknowledged)
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: # RF packets sent to concentrator: 0 (0 bytes)
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: # TX errors: 0
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: # BEACON queued: 0
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: # BEACON sent so far: 0
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: # BEACON rejected: 0
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: ### [JIT] ###
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: # SX1301 time (PPS): 2912765747, offset us 0
Sun Jan 24 08:21:08 2021 user.info lora_pkt_fwd[8540]: src/jitqueue.c:452:jit_print_queue(): INFO: [jit] queue is empty
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: ### [GPS] ###
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: # Invalid time reference (age: 1611472868 sec)
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: # no valid GPS coordinates available yet
Sun Jan 24 08:21:08 2021 user.debug lora_pkt_fwd[8540]: ##### END #####
JSON up: {"stat":{"time":"2021-01-24 07:21:08 UTC","lati":0.00000,"long":0.00000,"alti":0,"rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"cpur":0.0,"memr":0.0}}
Sun Jan 24 08:21:08 2021 user.info lora_pkt_fwd[8540]: INFO: [up] PUSH_ACK received in 45 ms
Sun Jan 24 08:21:10 2021 user.debug lora_pkt_fwd[8540]: wdctl event 11
Sun Jan 24 08:21:10 2021 user.debug lora_pkt_fwd[8540]: wdctl connection closed
Sun Jan 24 08:21:10 2021 user.debug lora_pkt_fwd[8540]: print_dutycycle 656
Sun Jan 24 08:21:10 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:21:11 2021 user.debug lora_pkt_fwd[8540]: wdctl event 11
Sun Jan 24 08:21:11 2021 user.debug lora_pkt_fwd[8540]: wdctl connection closed
Sun Jan 24 08:21:15 2021 user.debug lora_pkt_fwd[8540]: wdctl event 11
Sun Jan 24 08:21:15 2021 user.debug lora_pkt_fwd[8540]: wdctl connection closed
Sun Jan 24 08:21:15 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:21:19 2021 user.info lora_pkt_fwd[8540]: INFO - packet logger: logread timeout, auto stop
Sun Jan 24 08:21:20 2021 user.debug lora_pkt_fwd[8540]: wdctl event 11
Sun Jan 24 08:21:20 2021 user.debug lora_pkt_fwd[8540]: wdctl connection closed
Sun Jan 24 08:21:20 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:21:25 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:21:30 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:21:35 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 42 ms
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]:
##### 2021-01-24 07:21:38 UTC #####
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]: ### [UPSTREAM] ###
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]: # RF packets received by concentrator: 0
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]: [truncated] , CRC_FAIL: 0.00%, NO_CRC: 0.00%
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]: # RF packets forwarded: 0 (0 bytes)
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]: # PUSH_DATA datagrams sent: 1 (174 bytes)
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]: ### [DOWNSTREAM] ###
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]: # PULL_DATA sent: 6 (100.00 0x0.0000000000005p-992cknowledged)
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]: # RF packets sent to concentrator: 0 (0 bytes)
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]: # SX1301 time (PPS): 2912765747, offset us 0
Sun Jan 24 08:21:38 2021 user.info lora_pkt_fwd[8540]: src/jitqueue.c:452:jit_print_queue(): INFO: [jit] queue is empty
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]: ### [GPS] ###
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]: # Invalid time reference (age: 1611472898 sec)
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]: # no valid GPS coordinates available yet
Sun Jan 24 08:21:38 2021 user.debug lora_pkt_fwd[8540]: ##### END #####
JSON up: {"stat":{"time":"2021-01-24 07:21:38 UTC","lati":0.00000,"long":0.00000,"alti":0,"rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"cpur":0.0,"memr":0.0}}
Sun Jan 24 08:21:38 2021 user.info lora_pkt_fwd[8540]: INFO: [up] PUSH_ACK received in 50 ms
Sun Jan 24 08:21:40 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:21:43 2021 user.warn lora_pkt_fwd[8540]: [up] Receive Downlink Packet! Drop it
Sun Jan 24 08:21:45 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:21:50 2021 user.info lora_pkt_fwd[8540]:
Sun Jan 24 08:21:50 2021 user.info lora_pkt_fwd[8540]: INFO: host/sx1301 time offset=(1611469937s:671215µs) - drift=-19µs
Sun Jan 24 08:21:50 2021 user.info lora_pkt_fwd[8540]: INFO: Enabling GPS mode for concentrator's counter.
Sun Jan 24 08:21:50 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:21:56 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 48 ms
Sun Jan 24 08:21:58 2021 user.info lora_pkt_fwd[8540]: INFO: Received pkt CRC BAD
Sun Jan 24 08:21:58 2021 user.debug lora_pkt_fwd[8540]: 	F9 69 82 B2 7C 4D 24 7E
Sun Jan 24 08:21:58 2021 user.debug lora_pkt_fwd[8540]: 	7C BB 3B 95 E8 E0 4C DF
Sun Jan 24 08:21:58 2021 user.debug lora_pkt_fwd[8540]: 	6E CD 2E 50 68 E5 E6 CA
Sun Jan 24 08:21:58 2021 user.debug lora_pkt_fwd[8540]: 	E8 67 32 35 CB 44 46 51
Sun Jan 24 08:21:58 2021 user.debug lora_pkt_fwd[8540]: 	1A 59 EE B4 6A CC 35 37
Sun Jan 24 08:21:58 2021 user.debug lora_pkt_fwd[8540]: 	9B 00 A4 29 2A FD 9F 6D
Sun Jan 24 08:21:58 2021 user.debug lora_pkt_fwd[8540]: 	6F 3F 46 11 C7 67 77 24
Sun Jan 24 08:21:58 2021 user.debug lora_pkt_fwd[8540]: 	3F 1D A8 F7 9B B7 58 FB
Sun Jan 24 08:21:58 2021 user.debug lora_pkt_fwd[8540]: 	C3 C5 2C FF EA 04 53 CE
Sun Jan 24 08:21:58 2021 user.debug lora_pkt_fwd[8540]: 	02 4A 72 5C 09 17 8F 58
Sun Jan 24 08:22:01 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:22:06 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]:
##### 2021-01-24 07:22:08 UTC #####
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]: ### [UPSTREAM] ###
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]: # RF packets received by concentrator: 1
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]: [truncated] , CRC_FAIL: 100.00%, NO_CRC: 0.00%
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]: # RF packets forwarded: 0 (0 bytes)
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]: # PUSH_DATA datagrams sent: 1 (174 bytes)
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]: ### [DOWNSTREAM] ###
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]: # PULL_DATA sent: 6 (100.00 0x0.0000000000005p-992cknowledged)
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]: # RF packets sent to concentrator: 0 (0 bytes)
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]: # SX1301 time (PPS): 2972766905, offset us 0
Sun Jan 24 08:22:08 2021 user.info lora_pkt_fwd[8540]: src/jitqueue.c:452:jit_print_queue(): INFO: [jit] queue is empty
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]: ### [GPS] ###
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]: # Invalid time reference (age: 1611472928 sec)
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]: # no valid GPS coordinates available yet
Sun Jan 24 08:22:08 2021 user.debug lora_pkt_fwd[8540]: ##### END #####
JSON up: {"stat":{"time":"2021-01-24 07:22:08 UTC","lati":0.00000,"long":0.00000,"alti":0,"rxnb":1,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"cpur":0.0,"memr":0.0}}
Sun Jan 24 08:22:08 2021 user.info lora_pkt_fwd[8540]: INFO: [up] PUSH_ACK received in 47 ms
Sun Jan 24 08:22:11 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:22:16 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
Sun Jan 24 08:22:21 2021 user.info lora_pkt_fwd[8540]: INFO: [down] PULL_ACK received in 43 ms
    indent preformatted text by 4 spaces
on the web interface of the Gateway I have received 15 packets, transmitted 0 and active nodes 1
And can you see those packets arriving in your TTN application? (remember to see them coming in live the page has to be open at the time, unless you have a storage integration and pull the data after the fact or perhaps have an integration such as cayenne to capture in a dashboard for later review. Also picking up on some of your earlier logs and other posts are you running this as a TTN connected gw only or are you running as/with local NS (chirpstack) still enabled?
