How to switch Relays via http
Unfortunately, I can only find examples of HTTP downlinks for TTNv2, not for TTNv3.
The aim is to control the two relays of a Dragino LT-22222-L I/O controller via http.
These are the 4 possible states:
relay1 Off relay2 Off AwAA “03 00 00” F-Port 2
relay1 On relay2 On AwEB “03 01 01” F-Port 2
relay1 On relay2 Off AwEA “03 01 00” F-Port 2
relay1 Off relay2 On AwAB “03 00 01” F-Port 2
This is how I’ve tried it so far:
curl --location \ --header ‘Authorization: Bearer NNXXX.My_Token_with_enable_Write_downlink_application_traffic’ \ --header ‘Content-Type: application/json’ \ --header ‘User-Agent: my-integration/my-integration-version’ \ --request POST \ --data ‘{“downlinks”:[{ “frm_payload”:“AwEB”, “f_port”:2 }] }’ \ ‘https://thethings.example.com/api/v3/as/applications/my-application-id/devices/eui-my_end-device_id/down/push’
Nothing appears on the console.
Maybe something has to be used for User-Agent: my-integration/my-integration-version?
Would be very grateful for any example or hint.
A forum search showed this topic.
https://www.thethingsindustries.com/docs/integrations/webhooks/
Which server is example.com?
From the question about example.com I gather that it can’t be right.
Good hint! So I tried https://eu1.cloud.thethings.network. So I try:
curl --location \ --header 'Authorization: Bearer NNXXX.My_Token_with_enable_Write_downlink_application_traffic' \ --header 'Content-Type: application/json' \ --header 'User-Agent: my-integration/my-integration-version' \ --request POST \ --data '{"downlinks":[{ "frm_payload":"AwEB", "f_port":2 }] }' \ 'https://eu1.cloud.thethings.network/api/v3/as/applications/my-application-id/devices/eui-my_end-device_id/down/push'
"code":3,
   "message":"error:pkg/errors:validation (invalid `end_device_ids`: embedded message failed validation)",
   "details":[
         "@type":"type.googleapis.com/ttn.lorawan.v3.ErrorDetails",
         "namespace":"pkg/errors",
         "name":"validation",
         "message_format":"invalid `{field}`: {reason}",
at least I get something back, but an error:
Checked it again, the endDevice-Id is correct
It’s a bit hard to read the JSON - can you edit your post and use the </> tool so we can pick through it.
Also, what OS are you using?
Thanks for the help.
It works as it should.
As soon as you do it right, it works.
Thanks again.
