Frankly that doesn’t really sound like a LoRa radio application, LoRaWAN or otherwise. Ranges are short enough that a lot of other wireless technologies, or even wired ones, are probably better. And they’re going to offer you far fewer usage limitations.
If these were say, irrigation pumps scattered over a large area of farmland, that might be more a LoRa radio (and potentially LoRaWAN) application.
For a serious industrial application of your requirements you may have a look into the SIMATIC IOT2050. It is an Linux based edge device and allows to attach Arduino Extension Shields (like LoRa Borads). At the Siemens IOT Forum Website I saw an Application note which describes how to setup the system.
I think there are more Pi3B running factories than what you realize, I have seen deployment of 40, they all been running for years and not a single failure.
Does it need to go to the cloud? You could collect PLC data on your rPi via OPC UA (I’ve done that easily with a PLC and rPi) and then send it to AWS/Azure/googlecloud
My other thpught is, you could use LoRa, not LoraWAN. Scatter a few LoRa nodes and a few LoRa receivers around your Hall. (But as was pointed out, this is a LoraWan forum, not LoRa.)
It took a while but now I see “things” more clearly (The Things Network haha). Jokes aside, this is a post to wrap up the thread for other community members who find themselfs in the same position.
Hardware:
Setup:
Just put the HAT on the RPi, no more wiring is needed. There are a lot of repos on github to set up the RPi as LoRaWAN node, this was the most suitable for me GitHub - computenodes/dragino: LoRaWAN implementation in python.
If this GitHub repo goes down, you can also find a copy in one of my GitHub repos. If you set your node up, always be aware:
In terms of connecting it to a PLC: I’m not there yet but if there is interest, I will share it here.
Right now I use the additional GPS module on the HAT for a GPS-mapper (send location every minute via LoRaWAN). This could be interesting for people who want to contribute to TTN Coverage.
So it’s possible to use the RPi as a LoRaWAN-node in IIoT applications.
Is it as low-power as other nodes? - No.
Are other solutions “easier”? - Definitely, e.g. PLC → OPCUA → Ethernet has way less limitations. Nevertheless the use-case decides. And a lot of great replies with things to consider were made here.
It’s not running 24h, just when needed (1-2h a day max) and with a low SF. The main objective is to place the gateway in the best position, where it covers the most needed spots on our plant.
Which doesn’t seem to be helped by uplinking its position once a minute unless you are positioning it by some radio prediction method on a very slippery surface such that it keeps moving …
I plug the RPi in and run around with it. If a package reaches the gateway, it will be forwarded and the GPS-data gets stored in a database. There is no other gateway near, so I can be sure it doesn’t get forwarded by another gateway.
This does not stop any other gateway that is in the area hearing your transmissions and forwarding them to its Network Server for processing.
Hence the FUP and the laws relating to Duty Cycle.
Before you point us at the map, you may want to search the forum for the number of times people point us at the map and then we tell them that not everyone is on the map, certainly not other network providers.
For sure, every gateway is hearing every LoRaWAN message transmitted in range. But doesn`t a private LNS mean, that only the own gateways connected to the private LNS forward accepted packages?
Are these not the basic principles?
Public LNS → shared gateways
Private LNS → gateways are not shared
Don’t be worried, I won’t point at any map. But the location is so isolated, even cellular communication is barely possible (which does not mean anything, just for reference).
Nope, not at all, not even a little bit, because gateways do not have any autonomy beyond checking the CRC of the packet - if it passes, the it’s forwarded - it can’t decrypt so it doesn’t know. So if forwards to the NS. This means your frequent transmissions fill the airwaves and require all gateways that hear the uplinks for pass them on.
It actually means that the situation is worse than we thought - any LoRaWAN gateways in the area will be using a backhaul that is has a significant ongoing cost.
Isolated locations often make use of the Long Range radio system known as LoRa.
But as you have PLC devices, it can’t be that isolated. Or it’s a poor application of PLC devices where a more direct data acquisition / sensing scheme would be appropriate.
What u say wrt the NS being the final arbiter and rejecting the message is correct, as Nick says the GW how ever makes no such decision ….it’s purpose is to be a transparent passer on of messages but what you are also missing is the hint wrt the spectrum as a shared resource….and more importantly EVERY GW that hears the initial preamble for your message will say ahah…. LoRa message is coming….it might be a LoRaWAN message and better yet might be one my NS would love to handle….so best I start demodulating and start allocating some of my channel handling (remember it may only have 8 or possibly 16) resource and allocate and fire up my SF demodulation resources to go with it…… that is every packet heard by a gw triggers it to start looking and start demodulating/decoding, only if the crc is errored (ok there a few other deep spec clues that may impact handling decision, not for here) will it drop at the gw and be ignored. In the meantime it might miss a packet that it legitimately may want to handle from a better behaved node that it is there to serve…. Even in what seems to be the middle of nowhere…… and guess what areas with poor cellular coverage are a ripe use-case for LoRaWAN deployments notably because the users and communities can do it themselves and at low cost without waiting for a Cellco to decide the business case for them to deploy a mobile tower and supporting RAN is justified. Hence the continent of Africa is a hotbed or innovative deployments for e.g. threatened species monitoring or poacher detection, subsistence agriculture improvements., etc. Also just ‘cause you think there is no gw next door today, doesn’t mean there won’t be tomorrow or next week or……
So for short interval you flood the network and the node that is responsible and abides to FUP (30sec) a day, don’t get is fair share of the 30sec?
Point to the map, as you need to be fairly remote not to be out of range (its possible you are), I have seen uplinks 130Km + from nodes on the ground (not flying in high altitude balloons).
What does LORA stand for?
Look at msg.payload.uplink_message.rx_metadata and you get surprise sometimes.
Just to be sure you understand what I am saying the GW has no part in the decision - the NS decides…
Yes and no - not shared as in they wont handle your messages if not part of your network - unless part of a roaming agreement or using something like packetbroker…BUT those same private GWs will allocate limited resources, handle the message and forward to their associated NS if valid - same for all whether public or private, on net or offnet…
Short answer for your your thesis is - yes it can be - and indeed in many installations around the worls it is - its just the devil is in the detail…and the associated radio regulations There are PLC and PLC node connectivity devices and solutions in the market using LoRa &/or LoRaWAN and have been for years. They just have to be used carefully and for the right use cases…
…search the forum and will see lots of instances where we push back on people who say "but I’m only doing it for testing/for my limited case/for my area where there is nothing else around/for my…
fine within reason, and in the case of TTN within FUP - but the individual or company making the judgement as to what might be reasonable in the eyes of others is often not the person best placed to make the call as to what others consider reasonable = hence regulations…(note we all push limits at times - even if accidentally - the key is to have a good grasp of the consequences and mitigations… appreciate this is a learning exercise for you, as for us all! )
