@johan … Well thank you! Unfortunately the AWS Quick-start stack creation template again FAILED again with exactly same error (this is all under aws us-west-2 [Oregon]).
Error: “No Solution Stack named ‘64bit Amazon Linux 2018.03 v2.15.3 running Go 1.14.2’ found. (Service: AWSElasticBeanstalk; Status Code: 400; Error Code: InvalidParameterValue; Request ID: dc5908ef-0fc0-4d48-9de7-2aea4ce86846)”
I am quite new to AWS, so hopefully I am giving the right info that assists in fixing the problem. Otherwise, I appreciate if you are able to fix this and I welcome any other instruction or hints.
Thank you so very much, again.
