I am actually see device update data every minute,which I setup interval on BEEP app.
and from BEEP app show Loraconnected., it look PCB is communicate with TTN V3.
Not sure where is missing
and when I try to backward to TTN v2, there are some information I need to configure on PCB, but not there are some item missing in BEEP app, such Device ID.
Thks again for your answers. I have been reading here and there, thinking on my projetc etc…
I am not decided yet, I guess I need to think further.
The learning of the system interests me a lot but I am still unsure of my ability to do it.
Thks to you, I discovered Cayenne portal as well MQTT, maybe it can help to achieve more easily what I need.
I will keep you posted, especially if I activate a new gateway
Which is not available in the v3 integrations and there is no visibility on when or if it will be - and the v2 console won’t be operational by the end of this year.
I have the same problem / request and want to buy or build any cat trakker that is small, the trackers available are too big for small cat. I received an email in this forum with an offer to sign up to prepay the development for a cat tracker ; but the sender never replied to my email.
I can build simple electronics or develop professional software, here it is mainly open flat land with some houses here and there, we got a 10 meter tall building to install gateways/antennas.
For a cat owner it is not funny if the pet disappears for hours, it is nerve wrecking.
I am willing to cooperate on any project to build one. Just write me an email
Excelent ! , I will ask them for more info, need a really small battery and probably custom made enclosure.
The antenna might be an issue with size , so will ask too about options. For the cats roaming around I guess the range is not a problem, perhaps 100 - 300 meters around the house.
This shop has many other interesting gadgets for other projects.
For the range, I would go for a couple of kilometres…
Indeed, the cats are covering long distances when they explore around the house…
Maybe you could take advantage of the necklace to extend the antenna…
I have made no progress on my project, as I have been busy with other stuff.
I have abandoned the tags idea for the cat of for the keys… (Apple’s Airtags are here now…).
But I still have my gate issue. I need to monitor the status (open or closed).
I have explored Zigbee & EnOcean solutions, as I have both Zigbee & EnOcean UBS keys on my Jeedom box.
The issue is that door sensors are usually in-door use only. The only one external door sensor I have (EnOcean) does not work on iron gates (it kills the magnet signal).
So the only solution left I think is the Lora sensor, at least for the range.
I still need to validate if the iron of the gate will not cause the same issue as for the EnOcean sensors.
Just get a stronger magnet, and especially put some care into installing it so that the magnet and the sensor are close together when the gate is closed.
Look at the magnetic switches they use for garage doors, the magnet is a bit bigger and the cables are a bit more protected, to withstand cars driving over them.
