LoraWan Pager project
(Ccadic) #1
Hi all.
This short message to let you know we have started something which is probably crazy: A TelCo-less Simcard-free lora pager. It’ll be open source. We are at the beginning of the idea and currently brainstorming about hardware and software architecture.
I will keep you posted regularly if this is of interest
We have made a FB group on this.
https://www.facebook.com/groups/690526901150811/
Designing a breakout board for the ESP32 / RFM9X
(Jose Marcelino) #2
So you can get a maximum of 10 messages per day?
(Ccadic) #3
Yes this is my concern. We have to find teh way to save a maximum of bandwith and restrict or find a protocol to optimize connections to all available networks , maybe have a parallel GW for paging msg only
(Arjan) #4
I endorse any enthusiasm for any project, but as one needs a Facebook account to just see that page, just a few things that I assume you already considered:
  • Pagers are probably most used for emergency alerting, where long battery life and separated communication channels ensure they still work when cellular phones might not. But despite the notion of confirmed messages, LoRaWAN does not make any guarantees about delivery of messages?
  • You might need Class B?
     [quote="htdvisser, post:6, topic:3023"]Supporting Class B devices is unfortunately not easy in a network where you don't own/control the gateways. Additionally, you'd have to synchronize the time of each gateway very precisely. Telecom operators do this with GPS modules, but that doesn't work for TTN, as most of our gateways are placed inside where they can't keep an accurate GPS fix.[/quote]
  • How would you know which SF to use? ADR should not be used for devices that are on the move:
    4.3.1.1 Adaptive data rate control in frame header
    Mobile end-devices should use their fixed default data rate as data rate management is not practical when the moving end-device causes fast changes in the radio environment.
    (Using fixed SF11 or SF12 is prohibited by the LoRa Alliance.)
  • The easiest one: if you want to send text, you’ll need some compression format.
And:
This will need a private network, I think? (For Class A downlinks, TTN will only consider the gateways that receive the uplink. With a private network it might work; the IQ inversion probably also ensures that such downlink-only gateways do not interfere with the uplinks of end-devices in their neighbourhood, but I’ve not given it much thought.)
So indeed curious about any (future) progress… :worried:
Success!
#5
I suggested this simple SMS module
you don’t need LoRaWAN gateways and one message cost a few cents… works everywhere.
because something ‘could’ be done over LoRaWAN, it doesn’t always makes sense
the argument used on FB that you can send a message independent is not true… you need the internet
(Ccadic) #6
Yes, this is a challenge of course. There is a lot to do. Still not sure if we will manage
The idea is not only a question of cost per message, the idea is to have something not depending on telcos.
Something you can customize and a true P2P system with Blockchain etc …
My fear is the quantity of message (therefore the fair use limits) if the concept goes to its end.
I do also think you will need a private network to avoid over-use. Maybe we will have to implement additional protocol over Lora. We are still explorating :slight_smile:
(Arjan) #7
Well, you know we’re all sharing the same radio frequencies, even when people start creating private networks. The more networks, the lower the chance for success, I feel. And “P2P” sounds like messaging rather than low frequency paging. But hey, a thought experiment might be fun anyhow. :slight_smile:
(Peter Kmet) #8
I love the idea. By coincidence I came across the same idea some month ago, however I didn’t mind any specific protocol on top of LoRa, I was elaborating on power consumption given the need of instant message delivery (C-like in LoRaWAN). Such pager would definitely need to be recharged more often than ordinary LPWAN sensor. My intention was, however, to cover just simple area within reach of a single gateway, like farm or village.
(Sandgroper) #9
I like the idea and can see the value of the localized use case however I think it needs to be supported by more than a single gateway to ensure coverage in the area of interest. In this scenario the pager needs to discard duplicate messages.
#10
A precertified GSM module like the SIM800 can be had for €2, a precertified LoraWAN module like the RN2483 costs around €12 in quantities. Cellular modems can also be made low power, making a pager run for months on a single charge. You can have a worldwide cellular subscription for €1/month or less, and you can send thousands of SMS’es for less than that. Cellular networks are everywhere, so no coverage problems or the need to roll your own network.
While this is an interesting academic thought practice, in practice it is a very complicated solution for a non-existing problem.
(Jose Marcelino) #11
I’d say it’s an interesting thought experiment but limited practical use.
If you want to avoid carriers then run your own LTE base station, you can do voice and all using free software like http://www.openairinterface.org on LimeSDR board - cheaper than a LoRaWAN gateway.
There is of course the small matter of spectrum license but apparently you can do it in the Netherlands (going by the rough auto translation) https://tweakers.net/nieuws/86938/iedereen-mag-in-nederland-gsm-of-4g-netwerk-opzetten.html
#12
and a reason why security agencies must have acces to a LoRaWAN backdoor … ALL communication is accessible :wink:
(Xenek) #13
Most code around a single solution contributes to the whole, and all solutions, in some way or another. I would like to see this project progress at least to a draft stage, where basic functional code is released.
I wish for a pager with limited transmit function for a farm tractor, on a property that is 140 Acres large in Rural Northern Queensland. I think a single private, $1000 solar gateway on a central hill with microwave uplink to a place where 3G/4G actually can be received, would cover the property, allowing the pager to function. I’ll be implementing internet soon on this property, so will be installing the tower and microwave link in any case. Adding a things network basestation would be little extra effort.
The theory is that the tractor would have lorawan enabled box that has a ‘roll over’ sensor, where it sends an emergency sms alert to a few mobile numbers in the nearest city in event of the tractor falling over. And an ‘emergency’ button and a ‘non emergency help’ button would allow the user of the tractor to summon assistance from family members, either emergency or not so. Given this is a remote, rural area of Queensland, there are, and likely never will be, improvements to the 3g/4g networks that allow use of typical carrier technology. I believe we prohibit the use of imported Chinese 3g/4g repeater stations, and even if a farmer purchased one, it would be unlikely to cover such a large area (tiny in comparison to most rural Australian farms).
The situation is simple. My mother is soon 70 and uses a tractor on slopes on the hillside, alone. If she makes a mistake turning on the slope and the tractor falls over, I wish for an SMS notification to be sent to at least three family members. If she has any medical issue while operating the tractor I wish her to have a way to summon urgent or non-urgent assistance from family members.
People on farms across Australia are getting older and frequently they are working alone in remote areas. We can’t count on wifi or 3g / 4g in these areas as they are sparsely populated and even given high monthly connection costs, a carrier mobile base station can’t pay for itself, or be affordably subsidised by the government.
A lorawan gateway is perfect. If it has a microwave backhaul to a place where a 3g/4g or satellite link is available, large areas of land can be covered.
A tractor can have a large sealed box mounted to it with a solar panel, that is low maintenance and weatherproof, with two simple buttons and a display. The buttons can be emergency / non emergency summons. They could also work for yes/no in conjunction with a display.
It’s a fantasy for me today, however, I can copy/paste code, learn, and mix and match things, and might be able to create something like this with enough working examples.
I suggest the pager idea is a great one if it can develop to the stage of being a working example. Perhaps not for densely or moderately populated areas, but for fixed equipment such as tractors in rural areas that will never be serviced by retail carriers, it is perfect.
Cheers Xenek
(Jose Marcelino) #14
That is an interesting application but you can already achieve most of your use cases much more simply - and I’d suggest more reliably - using existing personal emergency beacons
(Xenek) #15
An epirb is an excellent idea, but here they often send a helicopter, and if it’s a non-emergency, send you the bill as well :slight_smile: :slight_smile:
This is a family member pager, for summoning multiple family members via a lorawan to sms gateway, for either private family emergency reasons (eg. non-life-threatening injury, rollover) or non-emergency reasons (eg. tractor broken down). An epirb summons emergency services provided by the state, and that isn’t a trivial matter here in any way.
But you are right, I should put an epirb on the tractor as a matter of urgency. Sadly, I know of no epirb that has a ‘tractor rollover’ sensor, but it is a great first step. I’ll research it.
(Jose Marcelino) #16
With only the lowest class amateur radio license you can use the free APRS service which is a perfect fit for your requirements - and they don’t send any helicopters
(Xenek) #17
So things like:
http://www.ebay.com.au/itm/Aprs-Tnc-Ant51-Tracker-Net-Digipeater-Weather-Station-With-Bluetooth-Ttl-8-15V-I-/302300017554?hash=item46627c3392:g:pdIAAOSw44BYI0gn
http://www.byonics.com/tinytrak/
Doesn’t really cut it price wise, IMO. I mean, how do I configure things like this into a simple single sealed low-maintenance box, with no ongoing costs, that can run off a small solar panel without the need for a large 12 volt lead acid battery? The APRS stuff needs a radio, and an antenna, and it all has to be turned on for it to work. I want something that turns itself on.
I am looking at a less pro home made thing like a esp-8266 or similar Ardunio, with an RFM-95, some sensors, and a $20 GPS. Total cost <$100 Australian for the electronics. The wifi facilitates upgrades and bug fixes without opening up the sealed weatherproof box. The finished product would have nothing but a few buttons and a couple of lights. There would be a power off button, but motion would activate it on automatically, and it would remain on until the power-off button was hit.
Also, we have remote gates, pumps, tanks, and livestock, all which could be IOT enabled. Presently, it takes a lot of walking or driving to check on these things.
A single or double gateway setup would enable a future of very low cost home made devices, at what appears to be a lower price point than the APRS system - where a radio would be needed for each device. I have a rough fantasy of as many as 50 devices (tractor being one) to be installed over a 5-10 year period. I have given it a little thought, and believe that leveraging open source software with budget hardware could result in sealed boxes running off solar panels with few to no controls - boxes that just ‘work’.
Lorawan seems to fit the bill, especially as a downlink from the internet via a gateway could allow a light to come on to confirm a series of SMSs had been sent, in the case of the tractor.
https://fred.sensetecnic.com/
Tall plan is $10 a month, and using node red to help diagnose, wire and manage the gateways and devices and messaging seems like a good option.
Getting back to the original post, I still think the pager is a device that I could borrow code from, or at least study, in a long term way.
(Ccadic) #18
Yes. But PGP is possible, Blockchain also. And relatively immune to “agencies” requests to CUT the GSM network for any reason :slight_smile: Let’s be paranoïd :slight_smile: Open source allows the polymorphism in the crypto methods, network architecture reorganisation. Not the GSM standards. They are PROS and CONS. I’m just discovering , I have no answers yet
#19
so you want to run your business with home made stuff hacked together from China parts and on a breadboard… interesting :grin:
a keyboard attached to a ‘node’ for sending txt messages ? no… that’s a very bad use case imho and I don’t think TTN will be very happy (not that I think this idea will ever get to a working prototype)
(Ccadic) #20
well not a business … hopefully . Doing this for my pleasure
From the beginning of the idea, I’m carefull about not to go against TTN policies. this is the reason why I’m more keen on having independant lora GW prototypes.
Just discovering at the moment. Not sure we will succeed. Now it is fun to try
“The luck smiles only to prepared minds” - Louis Pasteur
