yes, the communication is terrible. I don’t know why the react in this assaulting manner. But the people behind there seem technically experienced.
For me they don’t seem experienced since they obviously didn’t know which code they are using. The directed me to a source link which has a 30msec delay. That was a lie! Later they just say they changed it to 500msec and without explaining why they did so.
Yes I tried explaining to them on twitter that this affects all gateways I’ve tried but they don’t appear to be the most reasonable people on this issue.
I prefer a Hanlon’s razor approach to it but have to say there has been a running rumour that TTN protocol / TTN gateways would have a “preferred” path, even before MatchX took to twitter about it.
So far in my tests TTN protocol has actually had worse delay, likely because of all the overhead (can’t compete with simple JSON over UDP)
There have not been any changes in the scheduling logic since we doubled the time-before-tx on March 10 2016 (1bb19bf818
). After reading the discussion here (and on Twitter) I just added another 200ms (c8bd97b135
) to increase support for slow connections (or slow gateways). I’ll try to have that change deployed later today.
This is definitely not true. In the future we may give application owners the option to prefer authenticated/secure gateways (using MQTT or gRPC over TLS) over unauthenticated/insecure gateways (using JSON over UDP), but that won’t be enabled by default.
The MQTT server in between indeed adds a bit of delay. We’re working hard on reducing this by optimizing our MQTT server. Right now the extra delay is a few milliseconds at worst.
Of course TCP may also add some extra delay on bad connections (TCP packets are retransmitted, whereas UDP packets would simply get lost)
Wow this is like the best Xmas present from TTN I could ever hope (yes even better than the TTN gateway Thank you so much @htdvisser
Yes I think much of the overhead is on packet generation on the client side. But very good to know you’re on top of the server!
I still have the “too late” error with the MatchX Gateway.
Fri Dec 22 12:24:29 2017 daemon.info syslog[1428]:
INFO: Received pkt from mote: D000742B (fcnt=46037)
JSON up: {“rxpk”:[{“tmst”:2204454315,“time”:“2017-12-22T12:24:28.961510Z”,“tmms”:1197980687961,“chan”:2,“rfch”:1,“freq”:868.500000,“stat”:1,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“lsnr”:7.0,“rssi”:-47,“size”:23,“data”:“ACt0ANB+1bNwA+EbAAujBACLA2K81Hg=”}]}
Fri Dec 22 12:24:30 2017 daemon.info syslog[1428]: INFO: [down] PULL_ACK received in 49 ms
Fri Dec 22 12:24:34 2017 daemon.info syslog[1428]: INFO: [down] PULL_RESP received - token[182:216] : )
JSON down: {“txpk”:{“imme”:false,“tmst”:2209454315,“freq”:868.5,“rfch”:0,“powe”:14,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“ipol”:true,“size”:33,“ncrc”:true,“data”:“IHrmg/62xh41zRa0XrvdYkBYcgohzAzbMejsCECNSLGH”}}
Fri Dec 22 12:24:34 2017 daemon.debug syslog[1428]: src/jitqueue.c:233:jit_enqueue(): ERROR: Packet REJECTED, already too late to send it (current=2208964645, packet=2209454315, type=0)
Fri Dec 22 12:24:34 2017 daemon.info syslog[1428]: ERROR: Packet REJECTED (jit error=1)
Fri Dec 22 12:24:40 2017 daemon.info syslog[1428]: INFO: [down] PULL_ACK received in 49 ms
What firmware version is shown in the MatchX cloud interface for your gateway? I think that runs the old firmware.
Is there any way for people to see which backend version is active?
(I don’t think Releases · TheThingsArchive/ttn · GitHub tells us?)
I didn’t choose a update myself. They pushed it to 0.0.4 without notifying me after the long discussions. I think you have to contact them on all channels to make them react.
So, if TTN indeed did not make any changes that caused the problems: any chance MatchX changed the firmware first without all of you knowing that?
That is possible and the usual way they seem to act. Unfortunally you don’t have the chance to really know that. You have to believe the firmware version that is displayed.
I won’t expect them to acknowledge any bug that is found to be their fault. By definition it seems that only TTN can be the bad guy.
You can get the deployed versions from the discovery server using ttnctl discover [router/broker/handler]
ID ADDRESS VERSION PUBLIC
meshed-router thethings.meshed.com.au:1901 v2.9.0-0c455d496d... true
switch-router ttn.opennetworkinfrastructure.org... v2.9.0-0c455d496d... true
ttn-router-asia-se asia-se.thethings.network:1901 v2.9.1-8477a84c83... true
ttn-router-brazil brazil.thethings.network:1901 v2.9.1-8477a84c83... true
ttn-router-eu eu.thethings.network:1901 v2.9.1-8477a84c83... true
ttn-router-jp router.thethingsnetwork.jp:1901 v2.9.0-dev-e4cb53... true
ttn-router-us-west us-west.thethings.network:1901 v2.9.1-8477a84c83... true
v2.9.1
contains the 200ms extra time for slow gateways or gateways on a slow connection
Does that include earlier delivery of Join Accept messages to the gateway?
You have no idea what you are talking about Informed people pushing nonsense, do you even “tech” dude?
You can see the history of our scheduling code on github.
Yes, all downlink messages should arrive at the gateway earlier now.
This is not how we talk to our fellow community members here, @gatewayer. Please treat people with respect. Consider this an official warning.
Officially considered
To make thinks clear: @gatewayer works at MatchX. If it weren’t for @htdvisser’s reply I’d have blocked you right away.
riiiiight
