I just started tinkering wth Lorawan, so sorry if i’m asking the obvious.
I’m trying to connect a TrackerD Dragino GS tracker to TTNV3 (https://www.dragino.com/products/tracker/item/234-trackerd.html)
The TTNV3 console shows join requests being received and forwarded, and they seem to contain sensible data, but the TrackerD keeps showing through its RS232 interface: no JoinAccept.
The TrackerD should be preprogrammed to join the TTNV3 network, but no joy. I’ve tripple checked the EUI’s and recreated devices multiple times to be sure, but no joy.
I’m located near Rotterdam, surely Lorawan coverage shuld cover most parts of The Neterlands?
One of the Forward join-accpet messages in the TTNV3 console: (xxxxxxxx instead of real Dev eui)
“name”: “as.up.join.forward”,
“time”: “2023-08-13T08:41:54.772233633Z”,
“identifiers”: [
“device_ids”: {
“device_id”: “eui-a8404186dxxxxxxx”,
“application_ids”: {
“application_id”: “trackerdpeewee”
“dev_eui”: “A8404186DXXXXXXX”,
“join_eui”: “A840410000000102”,
“dev_addr”: “260B3283”
“data”: {
“@type”: “type.googleapis.com/ttn.lorawan.v3.ApplicationUp”,
“end_device_ids”: {
“correlation_ids”: [
“as:up:01H7Q0Y6TJ9HD4V0RFSEZRGY4N”,
“gs:conn:01H7EH0V415XCVVG9X57X7F0SD”,
“gs:up:host:01H7EH0V44TPWAPYFJAN6KAZGF”,
“gs:uplink:01H7Q0Y523KHCW97A86QKBMX0S”,
“ns:uplink:01H7Q0Y523BNARET5YCYBGTT9V”,
“rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H7Q0Y523F6TVWB7C5S6881DT”,
“rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H7Q0Y6THTBTV4FJR8354YVM9”
“received_at”: “2023-08-13T08:41:54.769515215Z”,
“join_accept”: {
“session_key_id”: “AYnuDxRJx92YoB98uBqyRQ==”,
“received_at”: “2023-08-13T08:41:52.963932776Z”
“origin”: “ip-10-100-13-164.eu-west-1.compute.internal”,
“context”: {
“tenant-id”: “CgN0dG4=”
“visibility”: {
“rights”: [
“RIGHT_APPLICATION_TRAFFIC_READ”
“unique_id”: “01H7Q0Y6TM6K4P4TPNF7W9C0CF”
One of many Serial output:
81387759: EV_TXSTART
81400301: TXMODE, freq=868300000, len=23, SF=10, BW=125, CR=4/5, IH=0
start single rx: now-rxtime: 4
81735861: RXMODE_SINGLE, freq=868300000, SF=10, BW=125, CR=4/5, IH=0
rxtimeout: entry: 81739462 rxtime: 81735854 entry-rxtime: 3608 now-entry: 5 rxtime-txend: 312375
81798361: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0
rxtimeout: entry: 81812714 rxtime: 81798354 entry-rxtime: 14360 now-entry: 5 rxtime-txend: 374875
81812733: EV_JOIN_TXCOMPLETE: no JoinAccept
I’m not sure where to look. I’ve read that every TTN provided AppEUI shoud start with 0x70B3D57ED ](https://www.thethingsnetwork.org/docs/lorawan/address-space.html#applications), clearly thats not the case here.
