Hi everyone,
I have setup other test / demo TTI gateways fine in the past and the Packetbroker goodness has just… worked.
I have one where some of the sensors are within receiving distance of two gateways. A TTN gateway and a TTI gateway. When I look at the application of the sensors, I can read the data and see which gateways the sensor has been received on. Never the TTI gateway.
Odd I thought, so I can see the DevAddr of the device on TTN so I watch the live traffic on the TTI gateway and yes, the same DevAddr appearing there.
After a bit of checking etc - I start to realise that the TTI gateway isn’t relaying the data into Packetbroker - which is odd, as I say, I’ve done a couple of others and they have just… worked!
I have gone to the settings of the TTI gateway, Share Status within Network is ticked. Share Location with network is ticked.
The Packer Broker option is unticked. If you tick it, you actually disable Packetbroker. However, I have ticked it, clicked save and in the live feed of the gateway you see the text
disable_packet_broker_forwarding
So if I go back and untick the box (and therefore, in theory enabling the Packetbroker), the text in the live data feed reads
so I suspect the web GUI front end is not configured quite correct. I have installed TTICLI (used it before to add gateways and delete gateways so moderately familiar with it) and I can see the gateway listed there - but does anyone know the specific gateway command for the CLI to
enable_packet_broker_forwarding
I’ve Googled and ChatGPT’d - I get close- but never quite the prize!
Hope the hive knowledge can help - many thanks in advance.
