I produce a small series of my own specialised LoRaWAN end devices. Now yesterday I wanted to add 50 more nodes via CSV import (like the last time). Unfortunately, I keep getting the following error message:
thanks for your help and additional clue. But what is meant with the field “authentication_code”? Wich code is meant and where can i get such an authentication code?
I use the end devices for an private swarm project of mine. How much nodes can i add/use in “community use”?
I’d suspect that you’ve found a combination that triggers an unanticipated error and it’s giving misleading information, but I’d have to try a test import myself to see.
Where do you get your DevEUI’s from?
As for device numbers, the consensus seems to be that for personal use (which isn’t community use if they are private), 50 is really pushing the limits - who needs more than a dozen or so private devices?? Community use, as in a geographical area with a mixed range of devices from a variety of user groups, is taken on a case by case basis if issues arise. @rish1 can advise further.
Please do not delete a post and mark someone else’s post as the solution when there appears to a casual link between them, rather leaving people without any thing to go on if they face a similar issue.
I’d assume that there was an issue with the EUIs you were generating, but it would be useful to the community at large if you could tell us what the problem was.
