Hola @awagner,
Que frecuencias estas usando para tu GW?
saludos
We are using the US config: US902-928. What has been your experience with LoRaWAN so far?
@awagner echale un vistazo a esto
https://www.thethingsnetwork.org/community/santiago/post/subtel-y-frecuencias-disponibles
Excellent contribution Patricio! A pity that part of the range has been tendered. What do you think if we assemble and publish a CL_local_conf.json for Chile?
Hi Patricio,
This is the frequency we configured. Any comments?
INFO: radio 0 enabled (type SX1257), center frequency 921500000, RSSI offset -166.000000, tx enabled 1
INFO: radio 1 enabled (type SX1257), center frequency 922300000, RSSI offset -166.000000, tx enabled 0
INFO: Lora multi-SF channel 0> radio 0, IF -300000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 1> radio 0, IF -100000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 2> radio 0, IF 100000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 3> radio 0, IF 300000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 4> radio 1, IF -300000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 5> radio 1, IF -100000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 6> radio 1, IF 100000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 7> radio 1, IF 300000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora std channel> radio 0, IF 300000 Hz, 500000 Hz bw, SF 8
Hola Andres
english please
Sure, just give me a second
Hi Patricio, take a look at this document from the SubTel. Apparently it is clear for the SubTel that the 902-928 range canât be considered as exclusive in any way, as: âmany industrial, scientific and medical equipments are using itâ. The Subtel also goes further and states that, âanyone operating in this band has to accept the interference that is now assumed to be part of this bandâ. This documents is dated March 2014⊠before the one you mentioned which is dated December 2014. In my opinion this is another demonstration off poor/lack government management around these âmodern issuesâ, where first everyone is allowed to use a certain frequency band, and at the same time the government agency is tendering part of it. Certainly the worst part of it is the point where it states that: âis responsibility of the interested part in avoiding those interferencesâ, which clearly translates into cases like the one you mentioned, where one of the biggest telecommunication companies in Chile is demanding a home-owner for using some surveillance cameras at his home. Only in ChileâŠ
hey @awagner , Iâm Felipe, I donât know why you call me Patricio
Yes, maybe we need an organization https://www.eff.org like to protect some electronic rights. We should take care of keep 915-928 as ISM band at least.
Regarding the gateway conf, I think Australian config fits to Chile laws. Should we adopt AU-global_conf.json for Chile?
Hi again,
I have news:
I set up a gateway bridge in Chile to reduce traffic latency, to use national traffic only on gateway devices and help to collect network statistics. The hostname is thethings.cl.beehub.io . It is hosted on a Data center at Curico, Region del Maule, Chile.
I made a pull request to TTN for including a CL config https://github.com/TheThingsNetwork/gateway-conf/pull/31
The config is based on Australian one
Also you can get it from here: https://github.com/Orixen/gateway-conf/blob/master/CL-global_conf.json
Cheers
Brilliant @astroza. Australia is leading in many other ways too, we should follow their path. Great work!
Hi, guys. With @dhinojosacm we too have been working with Lora for some months now and we own 3 different gateways. We set them up using the US conf example, i.e.:
"SX1301_conf": {
"lorawan_public": true,
"clksrc": 0,
"clksrc_desc": "radio_0 provides clock to concentrator",
"antenna_gain": 0,
"antenna_gain_desc": "antenna gain, in dBi",
"radio_0": {
"enable": true,
"type": "SX1257",
"freq": 904300000,
"rssi_offset": -166,
"tx_enable": true,
"tx_freq_min": 923000000,
"tx_freq_max": 928000000
"radio_1": {
"enable": true,
"type": "SX1257",
"freq": 905000000,
"tx_enable": false
"chan_multiSF_0": {
"desc": "Lora MAC, 125kHz, all SF, 903.9 MHz",
"enable": true,
"radio": 0,
"if": -400000
"chan_multiSF_1": {
"desc": "Lora MAC, 125kHz, all SF, 904.1 MHz",
"enable": true,
"radio": 0,
"if": -200000
"chan_multiSF_2": {
"desc": "Lora MAC, 125kHz, all SF, 904.3 MHz",
"enable": true,
"radio": 0,
"if": 0
"chan_multiSF_3": {
"desc": "Lora MAC, 125kHz, all SF, 904.5 MHz",
"enable": true,
"radio": 0,
"if": 200000
"chan_multiSF_4": {
"desc": "Lora MAC, 125kHz, all SF, 904.7 MHz",
"enable": true,
"radio": 1,
"if": -300000
"chan_multiSF_5": {
"desc": "Lora MAC, 125kHz, all SF, 904.9 MHz",
"enable": true,
"radio": 1,
"if": -100000
"chan_multiSF_6": {
"desc": "Lora MAC, 125kHz, all SF, 905.1 MHz",
"enable": true,
"radio": 1,
"if": 100000
"chan_multiSF_7": {
"desc": "Lora MAC, 125kHz, all SF, 905.3 MHz",
"enable": true,
"radio": 1,
"if": 300000
"chan_Lora_std": {
"desc": "Lora MAC, 500kHz, SF8, 904.6 MHz",
"enable": true,
"radio": 0,
"if": 300000,
"bandwidth": 500000,
"spread_factor": 8
"chan_FSK": {
"desc": "FSK disabled",
"enable": false
"tx_lut_0": {
"desc": "TX gain table, index 0",
"pa_gain": 0,
"mix_gain": 8,
"rf_power": -6,
"dig_gain": 0
"tx_lut_1": {
"desc": "TX gain table, index 1",
"pa_gain": 0,
"mix_gain": 10,
"rf_power": -3,
"dig_gain": 0
"tx_lut_2": {
"desc": "TX gain table, index 2",
"pa_gain": 0,
"mix_gain": 12,
"rf_power": 0,
"dig_gain": 0
"tx_lut_3": {
"desc": "TX gain table, index 3",
"pa_gain": 1,
"mix_gain": 8,
"rf_power": 3,
"dig_gain": 0
"tx_lut_4": {
"desc": "TX gain table, index 4",
"pa_gain": 1,
"mix_gain": 10,
"rf_power": 6,
"dig_gain": 0
"tx_lut_5": {
"desc": "TX gain table, index 5",
"pa_gain": 1,
"mix_gain": 12,
"rf_power": 10,
"dig_gain": 0
"tx_lut_6": {
"desc": "TX gain table, index 6",
"pa_gain": 1,
"mix_gain": 13,
"rf_power": 11,
"dig_gain": 0
"tx_lut_7": {
"desc": "TX gain table, index 7",
"pa_gain": 2,
"mix_gain": 9,
"rf_power": 12,
"dig_gain": 0
"tx_lut_8": {
"desc": "TX gain table, index 8",
"pa_gain": 1,
"mix_gain": 15,
"rf_power": 13,
"dig_gain": 0
"tx_lut_9": {
"desc": "TX gain table, index 9",
"pa_gain": 2,
"mix_gain": 10,
"rf_power": 14,
"dig_gain": 0
"tx_lut_10": {
"desc": "TX gain table, index 10",
"pa_gain": 2,
"mix_gain": 11,
"rf_power": 16,
"dig_gain": 0
"tx_lut_11": {
"desc": "TX gain table, index 11",
"pa_gain": 3,
"mix_gain": 10,
"rf_power": 20,
"dig_gain": 0
"tx_lut_12": {
"desc": "TX gain table, index 12",
"pa_gain": 3,
"mix_gain": 11,
"rf_power": 23,
"dig_gain": 0
"tx_lut_13": {
"desc": "TX gain table, index 13",
"pa_gain": 3,
"mix_gain": 12,
"rf_power": 24,
"dig_gain": 0
"tx_lut_14": {
"desc": "TX gain table, index 14",
"pa_gain": 3,
"mix_gain": 13,
"rf_power": 25,
"dig_gain": 0
"tx_lut_15": {
"desc": "TX gain table, index 15",
"pa_gain": 3,
"mix_gain": 15,
"rf_power": 26,
"dig_gain": 0
We werenât aware of any limitations regarding this range, and apart from the resolution @astroza linked, havenât seen any reports on it. Do you have any more information about this?
Also, we were under the impression that Chile uses the US 902-928 band, as seen here, here or here, and thatâs why at the beginning we set our gateways following that configuration.
I just found the modification to the grant that is cited in the resolution here. Similarly to what @awagner cited, it states the following:
3. El uso de la bandas de frecuencia asignadas deberĂĄ aceptar la interferencia perjudicial resultante de aplicaciones industriales, cientĂficas y mĂ©dicas (ICM) que operen en la banda 902 - 928 MHz, conforme a lo dispuesto en la Nota 42 del Cuadro de AtribuciĂłn de Bandas de Frecuencias, del Plan General de Uso del Espectro RadioelĂ©ctrico, aprobado por decreto supremo NÂș127, de 2006, del Ministerio de Transportes y Telecomunicaciones, y sus modificaciones
I havenât found something that refers to this decree, and as I understand it, it states that though there is a grant, they have to cope with use of the band by third parties. If someone can provide more recent information or any modifications to his or other decrees, thatâd be great.
I saw that but the fact is Subtel from 2014 [1] is asking to stop transmission on 902.1-912.1 range. What I donât want is once we are deployed a network along chilean territory someone comes to us to stop the project. There is a preceding complaint and resolution from Subtel, what could be different in our case ?
Would it be a good idea to ask directly to Subtel about this misunderstanding ? o maybe, meet to AUTOMOTRIZ PETRIC to know how they handled the requirement.
just in case, we still have two available plans AU915 and AS923 to evaluate
[1] http://www.subtel.gob.cl/transparencia/Perfiles/Transparencia20285/Normativas/Oficios/14oo_13939.pdf
I think thatâs the key. We have no problem with switching ranges, but itâd be good to know if there are real limitations or not, since everything weâve seen dates from 2014. Whoâs to tell that later on they donât grant another range to someone else and we must keep switching? Are they even able to do that? What could we as a whole community do against it? Those are the things that concern me if indeed that range is banned for our use.
Anyway, weâll let you know if we find anything else.
Hi, guys.
@dhinojosacm, from work, created a Telegram group called LoRaWAN Chile so that we can discuss everything involving LoRa adn LoRaWAN, not only TTN, and share our experiences. You can find the group here: https://t.me/LorawanChile.
Cheers!
HI,
I believe it is better to ask the question here than to create another new topic becuase you already spoke about my doubt.
Do you know if there is some update about the LoraWAN frequencies? I was not able to find any.
Thank you in advance!
Best Regards
Marta
Hola, como estas ?
Cual serĂĄ la frecuencia correcta para Chile ? au915 or us915 ?
Saludos,
Felipe
