The hard RAK831 cafe part 1
no , it can be received data from another network/node far far away.
what’s important is what you see in the TTN console… your gateway and applications.
@tbalon… you can ad data storage in your application under integrations, then you have 7 days storage
datastorage
It’s good that your gateway is shown as connected, but what I was referring to was the device in your application… If you go to your “application” select the “device” that you expect has sent data and look at the “last seen” time… it should be recent. If it says “never seen” then no packets have arrived at TTN from that device.
The tcpdump output should look like this for a packet being uploaded. Note the receive packet field in the UDP packet “rxpk” this show the packet is being properly forwarded.
m.B.$.4…g…’…yy.{“rxpk”:[{“tmst”:2581612820,“time”:“2017-11-09T20:59:15.026490Z”,“chan”:2,“rfch”:0,“freq”:904.300000,“stat”:1,“modu”:“LORA”,“datr”:"_
SF10BW125",“codr”:“4/5”,“lsnr”:-12.8,“rssi”:-109,“size”:15,“data”:“QMwcAiYACAABvEdHk6e5”}]}
I only see “stat” updates in your output. This is your gateway sending its status to TTN… This is all good. Make sure you sending device is properly configured…
Thanks BoRRoZ ! I may use this… Right now I’m connecting via mqtt to get updates and process my data.
Thanks for clarifying.
At the moment, I don’t have a device. My interest is to verify that my newly installed gateway really works.
But I guess I’ll either have to wait for someone else’s device to send something that’s strong enough to be received, or build a device of my own.
So far, I have 210 packets failing CRC.
Which packet forwarder are you people using with the RAK831? The (discontinued) Golang one or the ttn-zh?
the one used by the guide I linked to, which seems to be ttn-zh.
Mp forwarder :wink:
ttn-zh
Today I’ll build a device to check my gateway. During the first 23 hours of operations, the gateway claims to have received 835 packets, with 100% CRC fail (and 0 packets showing in my open tab on the TTN console trafic).
If there are no (known) nodes that is to be expected. Packets with CRC errors are not a problem, just ignore them.
For you node, make sure to keep it at least 3 meters from the gateway, nodes closer to the gateway might have too strong a signal resulting in CRC errors as well.
I’m using RAK831.
could RAK831 send beacons without gps module??
(like disabling gps)
I want to use RPI3 timer to periodic beacon transmissions.
when I look at the packet forwarder code from semtech, it seems gateway cannot transmit beacons without gps.
any advice?
regards.
With VAT + import taxes, wouldn’t this end up more expensive than the IC880a?
No it can not. GPS is required to meet timing requirements.
Current price of RAK831 KIT is €113.29, shipping is €4.82 making a total of €118.11. In the Netherlands the Dutch Customs will add 21% VAT plus €13 handling fee for the local parcel shipping company which makes a total of: €156. If you buy the basic RAK831 (non-kit) version you can save €6 making the total €150.
When stationary gateway, why would NTP time be insufficient and GPS time be required instead?
Because the GPS module is connected to the SX1301 to provide the 1pps as well. This allows for a sync resolution which NTP can’t provide.
@kersing
okay.
but it’s possible to transmit beacons using local timer, not gps right?
Assuming there is just one gateway in the network.
Please see the question and answer section of Johans LoRaWAN 1.1 update if you are not convinced by my answers.
To all The Hard Rakker’s… this topic is a bit full :sunglasses:
we continue HERE
