I own two TTGO T-Beam version V1.1 boards and I am not able to make them work. The problem I encountered is while trying to read the EUI code (meaning I try to load the TTN DeviceInfo example) the rebooting… endless loop appears.
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:9720
ho 0 tail 12 room 4
load:0x40080400,len:6352
entry 0x400806b8
Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x400d1784: 00000000 00004004 00400400
Core 1 register dump:
PC : 0x400d1788 PS : 0x00060530 A0 : 0x800d1125 A1 : 0x3ffb1f00
A2 : 0x3ffbebfc A3 : 0x0000000a A4 : 0x3ffbebfc A5 : 0x00000009
A6 : 0x0000000a A7 : 0x00000004 A8 : 0x800d206c A9 : 0x3ffb1ee0
A10 : 0x3ffbebfc A11 : 0x400d19ac A12 : 0x00000000 A13 : 0x00000000
A14 : 0x00000000 A15 : 0x00000000 SAR : 0x00000016 EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
Backtrace: 0x400d1788:0x3ffb1f00 0x400d1122:0x3ffb1f40 0x400d0be0:0x3ffb1f80 0x400d16c7:0x3ffb1fb0 0x40088215:0x3ffb1fd0
What should I do ?
P.S. I am using Arduino IDE on Windows 10. I am able to see both devices and I can successfully run the search wifi example. I also tried to change the USB cable but there was no difference. Should I try to power externally via a power supply and then connect to the pc? (I’ve read that the voltage can be source of this problem but I’m not sure if I can power externally and also plug the usb into the pc).
