It will be very useful (and common practice) to be able to see locally (‘on the device’) what version of the firmware is installed, e.g. on the configuation page (without requiring connection to any backend services).
If this is currently not supported, it should be added to the new firmware.
I think He (bluejedi) mentioned and also I think why is there no status page at the TTIG to check it locally. I could be build in in a new firmware off the TTIG.
then you need physical access to your device
And that is not always possible, I have install TTIG’s at familie houses ect.
But I see the work what you want to from server side to get the info top job.
Go to Messages (select your user icon top-right, then double-click the message icon), select ‘New message’ and add the username to whom you want to send a PM.
Thanks. Well I was looking at those places and was not able to find either a ‘Message’ at the user nor a ‘New Message’ button. Why should this not be possible?
BR
It seems the firmware is already reported in platform on the NOC? (Or are these new details for the TTIG? I’ve used the same details to get a list of The Things Gateway firmware versions almost two years ago.)
ttnctl gateways status eui-58a0cbfffe80050e
INFO Discovering Router...
INFO Connecting with Router...
INFO Connected to Router
INFO Received status GatewayID=eui-58a0cbfffe80050e
Last seen: 2020-06-19 10:17:42.961471121 +0200 CEST
Timestamp: 0
Reported time: 2020-06-19 08:37:51.83752521 +0200 CEST
Platform: minihub - Firmware 2.0.4 - Protocol 2
Frequency Plan: EU_863_870
Bridge: gs.v3.
Rtt: not available
Rx: (in: 0; ok: 0)
Tx: (in: 0; ok: 0)
Oops, in your specific case your account’s options were restricted by a moderator back in January 2018. I don’t know why. I’ve waived those limitations just now.
This is because of the bridge updates that we pushed on Thursday 18 Jun. I was waiting for a couple of days to check stability before announcing it in the forum.
But yes now people with TTIGs can check the firmware versions of the gateway via the NOC API or using ttnctl and we can check this in our metrics as well.
The TTIG currently runs 2.0.0 (for everyone except the beta testers). And the Beta software contains all the updates upto v2.0.5.
Yes I know the firmware version is read as 2.0.4 and the release says 2.0.5 but 2.0.5 has no functional changes. For more details, please check the repository. (Also, this is not maintained by me so I can’t answer questions on it).
And I’m sorry there isn’t a more concise explanation of the changes. I’ll create one later on.
Interesting to see this released on Github. I’m presuming that this intends to be a viable option for running gateways on Linux systems as an alternative to the Semtech forwarder and the deprecated TTN Packet forwarder software (which I’m still running on one gateway).
This was available on GitHub (at least) since February 2019.
Be aware though, the ESP8266 platform specific implementation of BasicStation used for TTIG is not public and is not available on GitHub (that was at least the policy last year and I suspect this will not have changed). The implementation for Linux is fully open.
Well, I’m not sure what has changed as I haven’t had time to set up an end node to transmit over my TTIG with the new beta firmware, but the TTIG status is now showing connected on the web page. Tried using the HTTP call @arjanvanb posted, but it does not return the firmware version for me - just the usual location and last contact data.
