I think He (bluejedi) mentioned and also I think why is there no status page at the TTIG to check it locally. I could be build in in a new firmware off the TTIG.
@jwijngaard / @bluejedi : You can check the firmware of the TTIG. Not at runtime but in the configuration window.
If you go into the activation window, at the bottom you can find all the info of your gateway
What we’re trying to do on the server side is to expose these versions through the Gateway API so you can query it at runtime.
then you need physical access to your device
And that is not always possible, I have install TTIG’s at familie houses ect.
But I see the work what you want to from server side to get the info top job.
Yes that’s a very good solution. When do you think this is available?
Hello there
The two who i give to u as “test beta firmware” or on this moment on the same release as you give in your example.
FW Build2018-12-06 09:30:37
FW Version2.0.0
Core Version2.0.0(minihub/debug)
We will see what it brings to you, if you can get the version’s online
Regards
Johan
I would like to. Couldn’t figure out how to send you a private messsage. Email?
- Click a user’s name and then select ‘Message’, or
- Go to Messages (select your user icon top-right, then double-click the message icon), select ‘New message’ and add the username to whom you want to send a PM.
Thanks. Well I was looking at those places and was not able to find either a ‘Message’ at the user nor a ‘New Message’ button. Why should this not be possible?
BR
Lukas
It seems the firmware is already reported in platform
on the NOC? (Or are these new details for the TTIG? I’ve used the same details to get a list of The Things Gateway firmware versions almost two years ago.)
http://noc.thethingsnetwork.org:8085/api/v2/gateways/eui-58a0cbfffe801206
"platform": "minihub - Firmware 2.0.0 - Protocol 2"
http://noc.thethingsnetwork.org:8085/api/v2/gateways/eui-58a0cbfffe80050e
"platform": "minihub - Firmware 2.0.4 - Protocol 2"
(If your browser tries to open these HTTP URLs using HTTPS, then opening in an incognito window may help.)
Same goes for version
in:
https://www.thethingsnetwork.org/gateway-data/gateway/eui-58a0cbfffe801206
"version": "2.0.0"
https://www.thethingsnetwork.org/gateway-data/gateway/eui-58a0cbfffe80050e
"version": "2.0.4"
And for ttnctl
ttnctl gateways status eui-58a0cbfffe80050e
INFO Discovering Router...
INFO Connecting with Router...
INFO Connected to Router
INFO Received status GatewayID=eui-58a0cbfffe80050e
Last seen: 2020-06-19 10:17:42.961471121 +0200 CEST
Timestamp: 0
Reported time: 2020-06-19 08:37:51.83752521 +0200 CEST
Platform: minihub - Firmware 2.0.4 - Protocol 2
Frequency Plan: EU_863_870
Bridge: gs.v3.
Rtt: not available
Rx: (in: 0; ok: 0)
Tx: (in: 0; ok: 0)
Oops, in your specific case your account’s options were restricted by a moderator back in January 2018. I don’t know why. I’ve waived those limitations just now.
@KrishnaIyerEaswaran2, can you check your PM’s?
Waiting for your reply and beta firmware update.
thxs,
Jeroen
@arjanvanb: Thanks for pointing that out.
platform
This is because of the bridge updates that we pushed on Thursday 18 Jun. I was waiting for a couple of days to check stability before announcing it in the forum.
But yes now people with TTIGs can check the firmware versions of the gateway via the NOC API or using ttnctl
and we can check this in our metrics as well.
So for those who were asking me what has changed in the new firmware, you can check the LoRa™ Basics Station releases page.
The TTIG currently runs 2.0.0
(for everyone except the beta testers). And the Beta software contains all the updates upto v2.0.5
- Yes I know the firmware version is read as
2.0.4
and the release says2.0.5
but2.0.5
has no functional changes. For more details, please check the repository. (Also, this is not maintained by me so I can’t answer questions on it). - And I’m sorry there isn’t a more concise explanation of the changes. I’ll create one later on.
Interesting to see this released on Github. I’m presuming that this intends to be a viable option for running gateways on Linux systems as an alternative to the Semtech forwarder and the deprecated TTN Packet forwarder software (which I’m still running on one gateway).
Yup that’s exactly why it’s open source.
This was available on GitHub (at least) since February 2019.
Be aware though, the ESP8266 platform specific implementation of BasicStation used for TTIG is not public and is not available on GitHub (that was at least the policy last year and I suspect this will not have changed). The implementation for Linux is fully open.
Well, I’m not sure what has changed as I haven’t had time to set up an end node to transmit over my TTIG with the new beta firmware, but the TTIG status is now showing connected on the web page. Tried using the HTTP call @arjanvanb posted, but it does not return the firmware version for me - just the usual location and last contact data.
Are you still looking for beta testers and is the beta test available for USA gateways?
Just send a PM and you will become aware.
Thank you - done.
