Not the same issue but don’t know where else to go. I created a gateway (multitech [MTCAP-L4E1-868-041) in my TTN account but it did not connect for some reason. The message in the live data kept on saying ‘creating’ and nothing happened after 10 minutes so I decided to delete the gateway from my list of gateways and register it again with the same EUI. Now I get the message ‘Submit failed, Already exists’
What can I do to register my gateway again? Can somebody advise me…
Is the Gateway ID same in both instances? If so try registering again with a revised GW ID (Forum search). If that doesnt work you will need TTI Core to purge DB potentially…
yes, I’m using the same EUI or Lora node ID of the gateway to register it again but I have given it a different name. I still got the error message that it exists already. I think somebody from TTI Core should indeed purge it…
Hello.
How are you?
I faced same problem.
I just created gateway with EUI. Because gateway did not connect into TTN server, I deleted gateway.
After that, I tried, but creating failed with same EUI
Can you help me?
Register again and choose a different GW-ID per post 4 above your! System will ‘offer’ a defaut based on GW EUI but you can over write this. GW EUI =/= GW ID, GW EUI can be re-used, GW-ID cannot once deleted its gone and you have to try an alterate ID…
Forum search (top right of every thread) is your friend - if new to LoRaWAN/TTN use it wisely and often
