Hi @KrishnaIyerEaswaran2, Understand about V2 not supporting Basics Station and therefore no CUPS server. I am testing using a Things Stack (V3) instance for testing and can’t find any instructions on how to set the cups.trust and cups.uri files
Does anybody know that ttn LNS support China region? is there a LNS wss://lns.cn.thethings.network:443? Is it possible that i use basic station and ttn in China?
After TTC presentation of @jmarcelino I got inspired and setup basics station with Balena on my RAK 831 gateway. Connection to V2 went flawless and the gateway runs fine. However, it fails to connect to V3.
I am informed that:
2021-01-26 20:24:13.108 [TCE:INFO] Connecting to INFOS: wss://eu1.cloud.thethings.network:8887
2021-01-26 20:24:13.152 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
The reason why we don’t want to make these cert chains official is that TTI CUPS (which will be available soon after the conference) will solve the cert management problems for you.
When in doubt, you can cross check the chain used by the server
Did you succeed? I get out one of my custom GW, spend a couple of hours trying and got same result as your. I followed this video but it’s for TTN V2/Basic Station
No success. I got the same error than you.
If someone with working configuration could post exact values to put in balena.io in env fields TC_CERT and TC_URI it would really help to debug
Anyway, sometime keeping things easy, I put back my old SD card, deleted GW on V2, created gateway on V3 with same EUI, changed server_address in local_conf.json as follow
"server_address": "eu1.cloud.thethings.network"
and voila, GW up and running on V3 in old school mode
root@loragw-61a4:/opt/loragw # systemctl stop loragw
root@loragw-61a4:/opt/loragw # systemctl start loragw
root@loragw-61a4:/opt/loragw # journalctl -f -u loragw
-- Logs begin at Fri 2020-11-06 15:33:48 CET. --
Feb 04 19:13:09 loragw-61a4 loragw[954]: INFO: Description configured to "ch2i-gw03-iC880a"
Feb 04 19:13:14 loragw-61a4 loragw[954]: INFO: Successfully contacted server eu1.cloud.thethings.network
Feb 04 19:13:14 loragw-61a4 loragw[954]: INFO: [main] Starting the concentrator
Feb 04 19:13:17 loragw-61a4 loragw[954]: INFO: [main] concentrator started, radio packets can now be received.
Feb 04 19:13:17 loragw-61a4 loragw[954]: INFO: [up] Thread activated for all servers.
Feb 04 19:13:17 loragw-61a4 loragw[954]: INFO: [down] Thread activated for all server eu1.cloud.thethings.network
Feb 04 19:13:17 loragw-61a4 loragw[954]: INFO: [down] for server eu1.cloud.thethings.network PULL_ACK received in 26 ms
Feb 04 19:13:24 loragw-61a4 loragw[954]: INFO: [#2601239B] uUP CRC:Bad Freq:867.50MHz ch:5 RFch:0 LORA[SF7 125Khz 4/5] RSSI:-87dB SNR:-4.0dB Size:21b
Feb 04 19:13:24 loragw-61a4 loragw[954]: INFO: [#2601279B] uUP CRC:OK Freq:867.30MHz ch:4 RFch:0 LORA[SF7 125Khz 4/5] RSSI:-36dB SNR:+9.0dB Size:21b Data:'QJsnASYA3rcBkckfCBYXXxueWW86'
Feb 04 19:13:24 loragw-61a4 loragw[954]: INFO: [#2515279D] RFU CRC:Bad Freq:868.30MHz ch:1 RFch:1 LORA[SF7 125Khz 4/5] RSSI:-99dB SNR:-6.8dB Size:21b
Feb 04 19:13:24 loragw-61a4 loragw[954]: INFO: [up] PUSH_ACK for server eu1.cloud.thethings.network received in 97 ms
Feb 04 19:13:27 loragw-61a4 loragw[954]: INFO: [down] for server eu1.cloud.thethings.network PULL_ACK received in 25 ms
Feb 04 19:13:37 loragw-61a4 loragw[954]: INFO: [down] for server eu1.cloud.thethings.network PULL_ACK received in 25 ms
Feb 04 19:13:47 loragw-61a4 loragw[954]: INFO: [#1A8D5DFD] uDN CRC:Bad Freq:868.30MHz ch:8 RFch:1 LORA[SF7 250Khz 2/3] RSSI:-100dB SNR:-11.2dB Size:225b
Feb 04 19:13:47 loragw-61a4 loragw[954]: INFO: [#30401B35] Prp CRC:Bad Freq:867.90MHz ch:7 RFch:0 LORA[SF7 125Khz 4/5] RSSI:-107dB SNR:-11.5dB Size:101b
Feb 04 19:13:47 loragw-61a4 loragw[954]: INFO: [#2AFF6E50] jAC CRC:Bad Freq:868.50MHz ch:2 RFch:1 LORA[SF7 125Khz 4/7] RSSI:-107dB SNR:-11.5dB Size:140b
Feb 04 19:13:47 loragw-61a4 loragw[954]: ##### 2021-02-04 18:13:47 GMT #####
Hi Charles, not sure what your conclusion is here.
My story is that I try to setup basics station with the Balena specific deployment om my gateway.
When I follow your video I link it to V2 which perfectly works fine without modification
However, when I follow instructions from TTC (https://youtu.be/e3HO3Q0qYqM) to connect basics station to V3 it fails. I get this message:
main 2021-02-05 07:17:30.253 [any:INFO] ./tc.trust:
main cert. version : 3
main serial number : 44:AF:B0:80:D6:A3:27:BA:89:30:39:86:2E:F8:40:6B
main issuer name : O=Digital Signature Trust Co., CN=DST Root CA X3
main subject name : O=Digital Signature Trust Co., CN=DST Root CA X3
main issued on : 2000-09-30 21:12:19
main expires on : 2021-09-30 14:01:15
main signed using : RSA with SHA1
main RSA key size : 2048 bits
main basic constraints : CA=true
main key usage : Key Cert Sign, CRL Sign
main 2021-02-05 07:17:30.253 [AIO:INFO] tc has no cert configured - running server auth and client auth with token
main 2021-02-05 07:17:30.288 [TCE:INFO] Connecting to INFOS: wss://eu1.cloud.thethings.network:8887
main 2021-02-05 07:17:30.329 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
main 2021-02-05 07:17:30.329 [AIO:DEBU] [3] WS connection shutdown...
main 2021-02-05 07:17:30.330 [TCE:INFO] INFOS reconnect backoff 20s (retry 2)
I have successfully connected gateways using UDP and protobuf with V3 but basics station keeps failing on certificates.
