Thank you. The pic clears up my confusion.
For those of you interested in low power operation of the Lora Feather 32U4:
I experimented with the libraries power.h and Adafruit_SleepyDog.h
In the setup I switched as many parts of the processor off as possible, and switched back to half clock speed:
power_adc_disable();
power_usart0_disable();
power_twi_disable();
power_timer1_disable();
power_timer2_disable();
power_timer3_disable();
power_usart1_disable();
power_usb_disable();
USBCON |= (1 << FRZCLK);
PLLCSR &= ~(1 << PLLE);
USBCON &= ~(1 << USBE );
clock_prescale_set(clock_div_2);
(WARNING: this also switches the USB off, so remember to put a delay(10000); statement first, otherwise you may have trouble loading a new sketch on the board!!!
Then instead of using the parameter TX_INTERVAL to determine the transmit interval, I set this parameter to 1 and I implemented my own cycle in the routine onEvent like this:
for (int i=0; i<35; i++) {
Watchdog.sleep(8000);
This gives about 5 minute recycle time. The watchdog can only do 8 seconds max.
Results:
The sleep current is 310 uA
The ‘active’ current is 3.5 mA for about 10 seconds. Don’t know why this interval is so long, because the actual transmit and receive windows are only a fraction of that. I use 1 byte payload, which gives 45 ms transmit time. During the transmit the current is about 40-50 mA, but hard to measure because it’s only a fraction of a second.
I’d be interested to hear power saving tips from others!
Some observations:
- With half clock speed, the AES encryption takes more time to complete. Will do some oscilloscope measurements to see what is more efficient.
- I have put TX_INTERVAL to 0
Further investigations ongoing
I did some additional measurements. My results:
- At half clock speed, the active time is about 12 s with 3.8 mA
- At normal clock speed, the active time is about 5.5 s with 5.7 mA
So actually, running at normal clock speed is more energy efficient: 8.7 uAh versus 12.7 uAh.
With SF7, the transmit time is 46 ms at 130 mA, so that consumes 1.7 uAh.
Is there an Cortex M0 equivalent to the AVR power.h?
I’m using Adafruit_SleepyDog.h
, but are there any more libraries for the M0 that helps with power saving?
I am looking to set up a network consisting of some nodes based on Adafruit feather 32u4 Lora based board. Being a beginner into creating a network, I wanted to ask if anyone has created a network based on LoRa. I have 4 LoRa modules as nodes and 1 as the gateway. I want to aggregate my data on the gateway using Long Range communication of LoRa. Thanks!!
it seems that this is your first post here @ The Things Network… welcome and start to read a little bit here
Hi @soumyasamirana, the difficulty with the Feather Lora board is that you have to provide the LoraWan stack yourself. This has bee done and it works, but I don’t know if that library is also capable to run on the Gateway side of things, Another risk may be that the gateway code does not fit in a Feathers memory.
@soumyasamirana you’ll want to read up on the different parts of LoRaWAN if that’s really what you want or if you want to just use LoRa without all the backend stuff. LoRaWAN consists of the data gatherers, nodes, which send packeted messages to a gateway device. The gateway adds location information plus a bit more to the node message and sends all that to a network server. This is generally sent over ethernet(LAN or WiFi) across the Internet. So if you want your Feather to be a gateway it has to have that software to wrap the node message and it has to have a network connection so software for that too.
But if you just want a bunch of LoRa nodes connected, look at Adafruit for help since this site is all about the LoRaWAN system.
Hi, Thanks for your input. Can you tell me where can I get the LoraWan stack that you said has been done before ?
Hi, Thanks for your help.
I am not getting any information from Adafruit as you have mentioned earlier. Is their any other open source stack that I can run with the Adafruit module ?
@soumyasamirana, maybe Adafruit is not responding as they have these nice pages where they explain all?
@soumyasamirana the LoraWAN software stack most popular is the LMIC ones you’ll find in many places and much documentation.
Search in Github for the LMIC implementation by Matthijs Kooijman. And do check other Feather-related posts on this forum for some important tips!
Thanks,
I will look into it
Thank you
Hey there, I followed every little steps you mentionned.
Anyway, I achieved to connect my boards to a gateway of mine. I used as mentionned all correct pio branchements:
.nss = 8,
.rxtx = LMIC_UNUSED_PIN,
.rst = 4,
.dio = {7, 6, LMIC_UNUSED_PIN},
Wired DIO to 6, and then, I join my gateway on OTAA or ABP.
Anyway, I would rather OTAA but it keeps trying to join.
Starting
Packet queued
155867: EV_JOINING
That is what I get from serial port.
In my opinion, the ACK is not encountered by the board, my gateway is a KERLINK one, then I don’t think that the problem is from the gateway.
So, is it a problem from the code itself, or from the wiring… from an alien ??
Any idea ? I take everything.
Thanks a lot.
Are you using the M0 Feather for LoRa, or the Featherwing that attaches to a Feather? (I’m using the Feather) Which pins did you connect to where? I couldn’t quite understand how the connections were made per @galagaking1’s guide.
Can you guide me in this. Even I am working on the same and I am very new to this.
i am trying to make it work with stm32duino. any idea how can i make it work?
